Results 1 to 10 of 10
    Established Member Two Rings ssbillet's Avatar
    Jul 12 2009
    Marysville
    The Bulb List - 2001 Audi TT with HID - LED lights
    So, looking to switch out some of my lights with LED's here is a quick reference list for my car, may be the same. It's a start.
    http://www.sylvania.com/en-us/applic...el=4079&make=9
    2001 AUDI TT (With HID (high intensity discharge) headlamps)
    Low beam headlamp HID-D2S
    High beam headlamp H7
    Parking light 2886X
    Front turn signal H21W (64136)
    Rear turn signal 7506
    7506ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
    7506LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Tail light 7528
    7528LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Stop light 7528
    High mount stop light
    Assembly
    Fog/Driving light H3-55W
    License plate 6418
    6418LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Back up light 7506
    Front sidemarker 2886X
    Rear sidemarker 2825
    2825LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Glove box 2821
    2821LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Map light 64111
    Dome light 6411
    6411LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
    Step/Courtesy light 6418
    Trunk/Cargo area 2825
    H7SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
    H7ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
    H7EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
    H7XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
    H7CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
    Last edited by ssbillet; 07-12-2015 at 11:34 AM. Reason: Updated URL for the Sylvania list
    Jul 12 2009
    Marysville
    So here is the site that I am reading up on for installing the LED's in the car.
    http://www.superbrightleds.com/
    If you have done this before then please post what you learned so that others can make some great upgrades!
    Thanks!!
    Jul 12 2009
    Marysville
    1157-cw30smd-sp
    These are pretty slick. Has anyone installed them?
    1157-CW30SMD-SP
    Senior Member Three Rings HardPark'd TT's Avatar
    Apr 18 2007
    w202
    Central Coast
    I've done LED license plate lights and reverse lights and have had no problems...
    I like those spider LED's, I just wonder what they look like when installed. I also was thinking of doing a custom LED strip for the rear turn signals.
    EURO.TECHNIKS
    www.eurotechniks.info
    Veteran Member Four Rings AvanTTix's Avatar
    B9.5 Q5 55 TFSIe, B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    Quote Originally Posted by HardPark'd TT View Post
    Is the light output improved drastically w/ the LED reverse lights?
    MY2024 B9 Q5 55 TFSIe: GlacierWhite||7-Speed S-tronic||Prestige||Black Optic||Sport Plus
    MY2003 B6 A4 1.8T Avant: DenimBlue||Ebony||5-Speed MT||Quattro||Premium||Sport
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium
    Jul 12 2009
    Marysville
    Yes, those are tight. Thanks for the pictures. A well lit area when backing up is preferred
    I will have to measure out the tail lights to see if the spiders will fit. It would be a better way to go if they do. I know that they are a little spendy but they would be sick.
    Veteran Member Four Rings Mantvis's Avatar
    Jun 05 2009
    mk1 Audi TT 180hp, mk1 Audi TT 225hp, mk4 VW GTI
    Chicago, Naperville
    can any one point me to the right direction? :D
    i need license plate bulbs, and the inside the cabin lights
    If you don't need both hands on the wheel, then you're NOT driving.
    Apr 18 2007
    w202
    Central Coast
    Quote Originally Posted by AvanTTix View Post
    I like to think so. I also get compliments/comments on them every time I back in at a night meet lol.
    EURO.TECHNIKS
    Jul 12 2009
    Marysville
    Quote Originally Posted by Mantvis View Post
    The list above should tell you what type (stock) bulb you need to cross with LED if that is what you want to do. The site http://www.superbrightleds.com/ should have what you are looking for. This is where I would start. Good luck! Post pics~
    Jun 05 2009
    Chicago, Naperville
    these would work right? i know cheap, might not last long, but thats not the point hahaha
    http://cgi.ebay.com/ebaymotors/2x-WH...item3a5da93aec
