Originally Posted by
FlyboyS4
**racing industry** is not the same as mass market consumer industry. I'm not saying they can't work when applied in sufficient thickness. I don't think what goes on a consumer product is sufficiently thick to provide a real benefit.
As above, I understand ceramic coatings will work when applied in sufficient thickness. But, for example, taken from the Swaintech site, their White Lightning Exhaust coating is a whopping 0.015" thick. I'm sure with several coatings you could get some decent insulation going, but is that what the average consumer gets when they buy this type of product?
I agree it is not the same industry. Do companies that supply these services offer the same service publicly they would to someone in the racing industry? I'm not sure.
Again, for some one that is mostly going to be daily driving the vehicle and enjoying sprinted driving on Saturday afternoons would not necessarily benefit from this coating.
As one mentioned earlier about the stock manifolds thickness- that's where you can make up for not having any coatings or wraps since the thickness will control the heat as opposed to say a tubular style manifold with thin piping wall thickness- which is what would need coatings and wraps to hold the heat in.
For this same reason this is why 99% of all cars turbo and NA have cast "log" style manifolds. I'd imagine its cheaper too to cast something then individually weld up a tubular style manifold.
Bottom line leave the coatings and stuff of that nature for race cars and cars that see the track often IMO.
Pete
