Page 1 of 5 123 ... LastLast
Results 1 to 40 of 167
    Oct 16 2008
    South Florida - Ft Lauderdale
    B7 A4 Tiptronic - ATF Replacement
    Hi Guys,
    Finally did my Tiptronic transmission flush & Pan filter at 100 000 miles. Here below a little DIY.
    Disclaimer: you are using this DIY at your own risk. This is for information ONLY and does not replace any Manufacturer approved documentation/procedure
    Even if really expensive, I highly recommend to using ONLY the OEM fluid
    Parts
    G060162A2 ATF fluid 6 liters (confirm the type of ATF with your VIN number at the Dealer. Incorrect fluid will damage your tranny)
    09L321371 Pan Gasket
    09L325429 Pan Filter
    Difficulty: 4
    Time: 3.5 hours
    Tools:
    Flat head screwdriver
    Small level
    7 mm Allen head socket
    17 mm Allen head socket
    T-25 Torx head socket
    A good ratchet set with extensions
    Torque wrench
    Fluid pump (Harbor Freight - $8)
    Ross Tech Cable
    The car has to be level and high enough to crawl under. Here was my solution
    This procedure has to be performed only on an engine totally cold.
    Remove the rear splash guard covering the transmission belly pan
    Take a small level and check belly pan for level. Take measurements sideways and front to back. If the pan is not leveled, make appropriate adjustments until perfectly level. This is a very important step.
    Locate the 8mm Allen drain plug and the 17 mm Allen fill plug on the belly pan
    Blue arrow = Drain plug
    Red arrow = fill plug
    Loosen 17mm Allen fill plug first. Take an extension, the plug is tough to break loose. We want to make sure we can refill the transmission before we drain it. Do not remove it
    The, remove the drain plug (blue arrow) and drain the oil.
    Using the T-25 Torx head and ratchet, loosen the 27 fasteners holding the belly pan. Remove all but 1 fastener. Gently loosen the remaining screw and the pan will start to tilt, allowing draining of the ATF.
    Remove the old gasket and discard.
    Lifetime fluid…yeah right!!
    The next step involves wiping down the inside of the belly pan and cleaning the magnets. Solvents are not necessary and you do not want the risk of any residue solvents breaking down the new fluid. You can pull of the magnet, just remember to reinstall them.
    Pretty messy inside and you can clearly see the deposit on the magnets
    Just pull on the old filter and clip in place the new one
    Reinstall the Belly Pan and New Gasket
    Install all the screws by hand to make sure the gasket is properly centered all around
    Once all bolts are in place Torque to 10 Nm (7 ft lb). In order to achieve uniform torque, choose 2 fasteners opposite of each other as start points. Torque the fasteners in an alternating fashion until all are fully secured.
    Here are the CRITICAL STEPS:
    Hook up the VagCom cable and go to: Select Control Module > 02 Auto Trans > 08 Meas. Blocks > Group 004. This will allow you to monitor the temperature of the ATF fluid.
    Do NOT start vehicle yet, just keep the key in the ON position.
    With the car still OFF, begin pumping fluid back into the transmission. You will need to insert the hose up through the fill hole and towards front of the vehicle. It should take about 2.5 – 3 liters before some overflows. Hand tight the fill plug.
    Start the car. While keeping your foot on the brake, cycle through all the gears, holding each gear for 15 seconds. Go from “P” through “D” and back up from “D” to “P”. It is not necessary to run through the gears via the TIP mode. With the car in “P” and motor still running, remove the fill plug again and start pumping again until overflow. Also, be mindful that the ATF fluid temp must be below 40 degrees Celsius. Cycle through the gears again and pump fluid in until overflow while the car is still running. Repeat this process as many times as you can before the fluid reaches 40 degrees. Once you are approaching 40 degrees Celsius, re-install the fill plug before shutting off the motor. If you fail to do this, the car will dump fluid. Allow the car and fluid to cool down.
    Once the car and ATF Fluid cools down (I waited until 32 degrees Celsius) start the car again and cycle the gears, same as before. Open the fill plug and continue pumping fluid into the transmission until over flow. Continue to cycle the gears and pump fluid until you reach 40 Degrees. Once you reach 40 degrees, pump until overflow, and reinstall the fill plug. Once the fill plug is re-installed, shut off the motor. Torque the fill plug to 80Nm (59 ft lbs).
    If you did the process correctly, you should have gotten 5-5.5 liters into the transmission, minus the spillage. If you did not get at least six (6) quarts in, or if issues arose on the test drive, jack the car up again and allow to cool for several hours or overnight. Start the car, cycle the gears, remove the fill plug and keep pumping fluid until you get overflow at 40 degrees Celsius. Remember to re-insert the fill plug before shutting down the motor
    Then, I test drove the car and what a difference: No more kicking, not even slight, on any mode!
    Let me know if any question
    Phil
    Last edited by kristokes; 04-23-2011 at 09:25 PM. Reason: Approved for B7A4 Tech sub-forum
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    Wow, and I actually started a topic about this a few weeks back. Asked a shop about it and it came out to be over 500 bucks.
    So questions: You pretty much pump the fluid in while the car is on, if it gets too close to 40 degrees, you remove the filler hose, close the plug and kill the engine to let it cool, once it cools, repeat until you get to about the 5 liters?
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Oct 16 2008
    Quote Originally Posted by Coderedpl View Post
    Exactly, if done correctly, you will refill with at list 5 liters minimum and 6 liters maximum.
    My exact amout 5 1/4 liters
    Phil
    Jul 27 2007
    Orange County, NY
    Will save me 500 bucks. Where did you buy the parts?
    Oct 16 2008
    Everything from the dealer
    Phil
    Jul 27 2007
    Orange County, NY
    Cost on parts?
    Veteran Member Four Rings Inked's Avatar
    Dec 11 2010
    Polaris Outlaw 525 Quad
    Central FL
    Nice DIY....after seeing the quality(or lack ther of) of the old trans fluid, Do you still think 100k is the time to change it? or earlier?
    Veteran Member Four Rings event's Avatar
    Jun 21 2009
    OR
    From what I've read the tip fluid never needs changing, I know it's not even on the maintenance schedule I have. I could be wrong though.
    No longer my "DTM" S4
    Rolling STOCK B8.5 S4 for over a year and happy!
    Oct 16 2008
    Quote Originally Posted by event View Post
    You are right but this is total bullsh**** from Audi. A Tip tranny needs to be flushed, just look at the fluid!
    For sure, Audi will prefer sell you a new tranny.
    Phil
    Oct 16 2008
    Cost on parts?
    $350
    Phil
    Jul 27 2007
    Orange County, NY
    I'll change mine at 100k
    Established Member Two Rings DioTrix's Avatar
    Oct 30 2008
    Audi S4 b8 | A4 black DTM
    Russia, Moscow
    this for audi a4 2.0 tfsi tiptronic ?
    G 060162A2 ATF fluid How much? 5 or 9 liters (full change)
    09l321371 oem gasket
    and plz give me OEM № Pan filter ?
    2010 Audi S4 RED|Awe/GIAC stage 2 |Ecode intake|Ecode Long tubes|APR CPS|DSG flash| 475hp/555nm
    Oct 16 2008
    Quote Originally Posted by DioTrix View Post
    Correct Audi A4 2.0 Quattro Tiptronic
    Get 6 liters of the ATF fluid and you can always return 1 if you did not use it.
    I left the invoice at the shop, I will post the pan filter Part Number tomorrow
    phil
    Established Member Two Rings mmadlang's Avatar
    Jan 15 2011
    Dallas, TX
    Awesome DIY... Great job Phil!
    Veteran Member Four Rings D0lphinGrey's Avatar
    May 31 2007
    B7 2.0TQ S_line
    Sydney
    Phil
    Great write up! Can you elaborate on the "kicking"? I might have the same problem, maybe changing ATF will fix it?
    B7 A4 GT28
    Oct 20 2008
    Denver
    nice writeup Phil. with the kicking I mentioned earlier i might just fill some more fluid and properly cycle through each gear
    Oct 16 2008
    Quote Originally Posted by D0lphinGrey View Post
    Let me try to define "kicking" the best I can:
    In "D" mode: first drive in the morning, the car was shifting pretty hard (up or down gear), even sometimes she was like slipping, RPM increasing by 200 between gear. When engine hot, arriving at a stop light for example, always kicking (not a smooth transition) from 3rd to 2nd and 2nd to 1st.
    In "S"mode, shifting pretty hard on 2nd and up.
    On a separate post, I was complaining about RPM fluctuation when the car was cold in the morning. I found a loose vaccum hose but sometimes, I was still having RPM fluctuations. This morning, in 6th gear, 1800 rpm, the needle was rock steady.
    Hope this will help
    Phil
    Oct 16 2008
    Pan filter PN: 09L325429
    Phil
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    bravo. i wonder what the dealership charges for this service if its 350 just for the parts!?! this will be on my to-do list shortly. for those of us that dont know, what is the comparison of the old fluid to the new fluid? im guessing its not supposed to be that dark??
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Oct 16 2008
    Quote Originally Posted by RedS-line View Post
    Got a quote from dealer: 3.5 Hrs x $135 = $472.5 + Taxes + Parts
    The new oil looks similar to the motor oil when new except the smell: this crap stinks bad !!!
    Phil
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Another excellent DYI by our friendly neighbourhood pilot!
    Good job, Phil.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Oct 16 2008
    Quote Originally Posted by airborneriflema View Post
    Good job, Phil.
    Your welcome
    Phil
    Oct 16 2008
    Good job, Phil.
    Your welcome
    Phil
    Senior Member Three Rings tarunpatel's Avatar
    Jul 11 2008
    Surrey, B.C.
    Now would the procedure still be the same if you have a automatic CVT trans also?
    Oct 16 2008
    Quote Originally Posted by tarunpatel View Post
    I am not sure since I was not able to read/test the CVT model
    Phil
    Jan 15 2011
    Dallas, TX
    This is not the same as CVT trans. ATF fluid, gasket, filter, fill and drain locations, and tools are different. The procedure is the similar though. I looked at Bently, and other forums, it seems that CVT requires a different tool to fill the fluid. It's using VAS 5162 vs VAS 6262.
    Phil, what tool did you use to refill the ATF?
    -Mark
    Sep 02 2008
    Boonies VA
    Another great DIY! One thing I did not see mentioned though, do you need a full version of VAG-COM from Ross Tech? or does the Ebay cable work?
    White Wagon
    Jul 27 2007
    Orange County, NY
    Out of curiosity, why is it so important and crucial to have the car level?
    Oct 16 2008
    Quote Originally Posted by mmadlang View Post
    -Mark
    Hey Mark,
    No VAS tool required. This pump is perfect, Harbor Freight = $7
    Phil
    DUH! an Audi
    los angeles, CA
    phill, why must we live so far from each other?
    Oct 16 2008
    As you will see on the schematic here below, the top of the filling tube it's what makes the correct level. Since the tranny is pretty long, in case the car ls not level, the amount of oil will be incorrect, either too little or too much. The black arrow is showing the filling tube.
    Phil
    Senior Member Two Rings Grada89's Avatar
    May 04 2009
    B7 A4
    Ft.Lauderdale
    I may contact you when i reach 100k. :p
    May 04 2009
    B7 A4
    Ft.Lauderdale
    my service manual says 35k and 70k. Replace ATF
    Oct 16 2008
    Quote Originally Posted by Grada89 View Post
    Tiptronic is lifetime....yeah right!
    Phil
    May 04 2009
    B7 A4
    Ft.Lauderdale
    Phil
    lol i will take pictures.
    Its also on here. http://www.bentleypublishers.com/ima...ance.sched.pdf
    https://wiki.bentleypublishers.com/d...Cabriolet,+RS4
    easier to see on the link above ^^^
    Oct 16 2008
    Again, this is for CVT, DSG or Manual and NOT Tiptronic !
    phil
    Dec 11 2010
    Central FL
    phil
    LOL at Phils frustration..now someone is going to see the not tiptronic part and ask what transmission you have LOL hahaha
    May 04 2009
    B7 A4
    Ft.Lauderdale
    phil
    Makes more sense now....but totally agree there's no way ATF is lifetime no matter what transmission it is.
    Active Member Two Rings swsherif's Avatar
    Sep 01 2009
    canada
    Just a question here Phil, why you did not use the 8mm drain plug to drain the transmission fluid before removing the oil pan. ?
    Oct 16 2008
    I just forgot to add the step but yes I did that first
    Just made the correction, Sorry
    Phil
