Results 1 to 25 of 25
    Nov 21 2009
    Arcadia/CA
    so what does it feel like when the fuel pump is going out?
    this has happened to me 3 times over the past 2 months. 1st time right around x'mas and twice last night towards the end of my 500mile road trip in the middle of no where...not fun
    i'm cruising along and car is not showing any signs of problems then without warning, the car/engine stutters badly when you try to get on the gas. it almost feels like the car is going to stall out but it doesn't. hold in the clutch and it will idle normal. there is no power, but you can still rev the engine freely (reluctantly), but with any load, it'll stutters and feel the the motor is going to cut out (kinda like lugging the motor by driving in a high gear @ low speed).
    the first 2 times it happened, the car acted 100% normal after shutting off and restarting the car...it actually fires right back up.
    this very last time tho, on a 2 lane hwy middle of no where in blizzard conditions i actually could not drive the car. took 5 restarts but she finally got going again. f-inf scared the sh1t outta me
    anyways, it feels like the car is not getting the fuel or air it needs??? thoughts?
    scary cause i gotta turn around and make the same 500mile drive back from tahoe to LA. i definitely should have done some trouble shooting the 1st time it happened but the symptoms never came back (until i'm 500 miles away from home of course)
    b5 s4 semi-noob...b5 a4 super-noob
    '01 a4 avant http://www.pbase.com/sy0296/b5_a4
    '01 s4 avant http://www.pbase.com/sy0296/s4
    '88 m3 on going project http://www.pbase.com/sy0296/e30_m3
    '02 m3 681rwhp 110oct + meth http://www.pbase.com/sy0296/m3&page=all
    Veteran Member Four Rings KNaudi's Avatar
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    any codes? Was the fuel filter changed out? I would start there before you jump to the fuel pump conclusion.
    My WTB List:
    -Sport (all black) shift surround for 6MT
    -Sport (all black) ash tray cover
    KNaudi's story
    Jan 03 2010
    Gloucester Ontario
    sounds more like split in the TBB or a coupler.
    If you find the car becomes undriveable and there is no way to fix it where you are, you can try running with the MAF disconnected and if you stay out of boost you can drive along just fine like that. If its an air leak issue, this will help.
    If its a fuel delivery problem, sticking a wide band on, or a fuel pressure guage is the best way to check it. Any garage worth its salt can pressure test/smoke test the intake tract to see if there is a big leak somewhere... Its harder to find fuel pump failures if they can make base pressure at idle, you have to go for a drive, put some load on the pump and see if the pressure drops. Or with a wideband, you will see it go lean.
    Jan 03 2010
    Gloucester Ontario
    Jan 03 2010
    Gloucester Ontario
    Quote Originally Posted by KNaudi View Post
    Unless that filter has been on there for an eternity, swilling around in old gasoline for years at a time, i highly doubt its the issue.
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    Quote Originally Posted by J-b5 View Post
    you're probably right. he just got me thinking about the fuel system and nothing else with the title of the thread.
    My WTB List:
    KNaudi's story
    Jan 03 2010
    Gloucester Ontario
    Im just mad cuz my idiot mechanic wasted my time with changing fuel filters constantly, when it turns out the moron pinched the return lines closed and burned out my brand new fuel pump. Causing load onset fuel starvation and cost me an entire season troubleshooting when a simple fuel pressure check sorted it out in minutes.
    Veteran Member Three Rings jaimeson's Avatar
    Jun 22 2009
    Bikes, Viper, Duramax
    Wow.....and these people call themselves mechanics, what a shame.
    R6 (Track bike)
    B5 A4 SC'D (Sold)
    B5 S4 STAGE III (Sold)
    GSXR 1000 (Commuter)
    Gen four SRT-10 (Go FAF)
    LB7 Duramax (Haul anything)
    "You miss 100% of the shots you don't take"
    Jan 03 2010
    Gloucester Ontario
    In his defense he was a raging alcoholic.
    Nov 21 2009
    Arcadia/CA
    thanks for the info....just went out again to get stuff out of the car and found a new symptom. the cabin smells like fuel fumes! that can't be good huh? it is possible that i have a bad fuel line? would that gas the cabin to smell like gasoline (no noticeable smell outside of the car btw)? car still started and drove normal around the parking lot
    any more thoughts based on this?
    hoping it's something like a tbb of coupler and fingers crossed that i can get it home safely on Monday. i can't imagine what a 500mile tow bill will look like.
    on a side note, anyone know of a audi mechanic in truckee, ca?
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    not much of a defense. if you'd said he has downs syndrome or is blind like this mechanic
    I would understand.
    My WTB List:
    KNaudi's story
    Jan 03 2010
    Gloucester Ontario
    Yup sounds like you have an issue in that department for sure. No puddles of fuel or wet spots?
    Nov 21 2009
    Arcadia/CA
    can't really see any puddles or any wet spots with all the snow around...but parked the car over night and fuel gauge held steady...i think.
    really need a mechanic to look at this today before everything shuts down for the weekend. sigh...i really love and hate this car
    Account Terminated Two Rings
    Feb 14 2011
    01.5 S4, 99 Tacoma
    Loyalton, CA
    I'm in Loyalton, about 40 minutes away in good weather to the north of L. Tahoe. If you are still stuck tomorrow I can try to come out there and scan and offer what I know. You probably blew/crushed an EVAP line or have moisture frozen in the system since you smell gas fumes. Happens to some cars up here at elevation.
    Nov 21 2009
    Arcadia/CA
    Quote Originally Posted by Jibby View Post
    appreciate the offer. was recommended a shop in truckee and heading over there now. hopefully everything gets resolved without too much issue
    Nov 21 2009
    Arcadia/CA
    I made it back to LA! so it was a fuel delivery issue.
    it turns out one of the fuel lines was leaking at a fitting. Jared from VML Spec in Truckee, CA was kind enough to take a look at the car, diagnose and replace the broken part within 30 minutes of getting my car on his rack.
    thanks again for the help, AZ!! :)
    Nov 21 2009
    Arcadia/CA
    mini shop review for anyone who needs a shop in the tahoe area:
    http://www.audizine.com/forum/showth...94#post6218694
    Veteran Member Three Rings fatezero's Avatar
    Feb 12 2004
    Orange County, CA
    Snow Trooper is the man!! Glad you made it home safe Sam
    2021 C8 RS6
    2001 S4 Avant 3L Tial 770
    2004 Allroad 6spd EPL Stg 3 SOLD
    2001.5 S4 Avant AWE/GIAC Stg 3 SOLD
    2011 S4 6spd Suzuka Grey Pearl with GIAC Stg 1 SOLD
    2006 S4 Avant SOLD
    2001.5 A4 Avant K04/Jeff Moss Hammer File SOLD
    2001 Porsche 996 Turbo - SOLD
    2001.5 S4 AMS Stg 3 - SOLD
    Nov 21 2009
    Arcadia/CA
    Quote Originally Posted by fatezero View Post
    thanks for the help adam. if i needed to tow the car back from tahoe, i probably would have just listed it on the local craigslist, lol
    May 16 2008
    South Texas
    Usually when the pump takes a shit it it will whine like an X-wife looking for alimony.
    Nov 21 2009
    Arcadia/CA
    Quote Originally Posted by Scotty@Advanced View Post
    lol. i'll keep that analogy in mind for the future.
    Veteran Member Four Rings 99ebpsi24's Avatar
    May 04 2008
    10 S4 prestige, 12 A4 S-Line, 00 Stg3+ S4, 74 VW Thing, 74 Z28 camaro (32k original miles) 74 Z28 Ca
    Cincinnati
    Glad you made it home safe. I had a strong smell of gas in the cabin a while back but no ill effects like you were having. Ended up being a fuel line as well. I'd be it was the same line as it sounds like a common issue I'll attach a photo for refrence. Don't mind my goofy ass thumb in the picture lol. The line is on the passanger side right above the valve covers, if you look you'll see it. It typically leaks right at the fitting and will drip and puddle up on the plastic over over the valve cover. I just broke it loose and cleaned it and torqued it back down and have been golden since.
    Photo of leaking fitting found HERE...
    Current:
    19’ Ara Blue RS3 UniFlex stg1+, stg2 tcu, midpipes & IE intake
    21’ VW Atlas SEL Prem. R-Line
    15’ Sepang Blue S3 Prestige
    10’ S4 Prestige
    00’ S4 stg3+
    12’ A4 P+ S-Line
    08’ A4 P+
    Nov 21 2009
    Arcadia/CA
    Quote Originally Posted by 99ebpsi24 View Post
    imbedded your photo
    that's the exact same line i was leaking from. fuel was leaking from the fitting. at first we removed the line to check the integrity and torqued it back down. however, mine was bad so the mechanic replaced it with a working piece. problem solved! no idea why it would be bad, but if it's a common a common issue, the lines should be inspected regularly then...would suck to be driving and have the fuel/fumes spark especially since right below those lines is a hot exhaust manifold!
    at the same time, he also discovered my spider hose was popped off behind the intake mani which might have been the culprit for driving issues. it's all been resolved though
    May 04 2008
    Cincinnati
    Quote Originally Posted by sy0296 View Post
    Yeah the spider hose would make more sense on the driving issues as that would cause a boost leak.
    I just wanted to post the photo incase he fixed it and you didn't get a chance to check it out. Like said normally if there is a leak it comes from that line. Any ways, glad to hear everything has been resolved and you made it home safe. Enjoy the car!
    Current:
    10’ S4 Prestige
    00’ S4 stg3+
    12’ A4 P+ S-Line
    08’ A4 P+
    Senior Member Three Rings Fiyacracka's Avatar
    Feb 13 2008
    I remember when my fuel pump was on its way out. There was a really loud humming noise from the back. One morning tried to start her up, no luck. Banged it a couple of times and luckily drove her to the mechanic.
    SOLD! 2000 Audi S4 PJK04, Custom Stage 3, APR Bipipe, APR Snub Mount, RS4 Tranny mounts, VAST Stage 3 Clutch, AWE Intercoolers, 3 inch custom turbo back exhaust
    2001 Audi S4 SRM K24 Hybrids, Ringer Racing Stage 4 Clutch with CM Billet Steel flywheel, DAZ TUNED, APR Bipipe, SSAC 3" downpipes, Borla Catback, SRM Intercoolers, 17Z BBK
