Results 1 to 6 of 6
    Established Member Two Rings silverback85's Avatar
    Aug 22 2008
    2018 S4 | 2002 A4
    Southern NH
    Should I replace the strut/shock mounts when replacing OEM sports suspension???
    I'm in the process of replacing my OEM sports suspension and control arms with a new set of control arms and vogtland coilovers, should I also change the front and rear strut mounts as well....
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    My fronts went bad right after i installed Bilstein PSS9 CO. Apparently, its not super common for this to happen, but I would change them out while doing the install if I was doing it again. how may miles on your car? Rears do not have strut mounts, just the fronts.
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    There are strut mounts in the rear that need to be replaced according to ECS Tuning and the Bentley. I replaced the fronts when I did my suspension. I will do the rear strut mount the next time I replace my rear rotors and I recommend the same if doing rear suspension.
    http://www.ecstuning.com/Audi-B6_A4-.../OEM/ES257832/
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Mar 27 2005
    The Cold North
    I am on my 3rd set of front strut mounts in 40k miles. My rears have been replaced 2x.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Aug 22 2008
    2018 S4 | 2002 A4
    Southern NH
    @onlyaudis I have 122K on my car...
    Veteran Member Three Rings B6_Dolphin's Avatar
    Apr 10 2005
    PNW
    I would replace the mounts... I had my KW V2's installed, and then when the temperature dropped below 40 degrees, the front end started to creak (and no, the creaking was not from the control arms - they were recently replaced, too).
    So do yourself a favor, replace the front mounts!
    2023 RS5 Coupe - Ascari Blue/Black; Mods: IE A2A IC, 034 Strut Brace, ECS Poly Trans Mount, APR CF Intake, EuroCode FRT & RR STB + Endlinks, PB Pedal Tuner; AskCarbon Steering Wheel
    2021 SQ5 S/B Prestige - Daytona Gray/Black
