Results 1 to 10 of 10
    Established Member Two Rings silvers2k's Avatar
    Dec 02 2005
    chicago
    How long does it take for springs/coilover install?
    I initially wanted to go for the coilover but can't seem to justify the cost (at least not now), so I'm planning on getting the springs instead.
    My local shop estimated I needed to drop off the car for about 3 days including an alignment - is this typical for the rs4?
    2007 Mugello Blue RS4
    Mods: Magnaflow exhaust/mtm spacer/35% tint/euro RS4 steering wheel/ecs tuning clear reflectors.
    Mar 11 2008
    B7RS4 & e46Ms
    It depends...for a spring install...they may be thinking they're going to disconnect the drc lines up front and are leaving a day or two in there to send it to audi to be recharged?? For coilovers, the install itself will only take 4-5hrs taking your time...maybe 6 if bolts are stubborn. If they are going to be meticulous with the ride height adjustment, you could say another 3-4hrs going back and forth. This is also assuming they're going to torque all your control arm bolts at ride-height. If you're getting motorsports installed, add another 2-3hrs just to get the reservoirs through the engine bay. Another hour for alignment in the end unless you have adjustable upper control arms...
    FRRG AZ Ring
    Dec 02 2005
    chicago
    ^Thanks for the info.
    Is it necessary to have the drc recharged at the dealer (or recommend it)?
    Veteran Member Three Rings noznab's Avatar
    Jul 08 2007
    Tri-State
    Coil overs should only really take about 30 mins per corner on S4's. I realize RS4's have a more sophisticated suspension than S4's but I imagine it still shouldn't take more than 45 mins per corner
    A few mods here and there
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    05 B6 S4, BMW F15 X5
    Southern NH
    Quote Originally Posted by silvers2k View Post
    Depends, are you getting just springs or replacing the DRC with coilovers/shocks?
    B6 S4 Winter Beast: Supercharger, Carbonio-hybrid Intake, Fast Intentions DP & CB, CF Vented Hood. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/LW rings) & rear BRK, SS lines. Snow tires.
    Daily Driver: BMW F15 X5 M50d clone, DUDMD tune, water/methanol injection, 38mpg highway
    Dec 02 2005
    chicago
    Just getting the springs.
    Active Member Two Rings ejbende@aol.com's Avatar
    Apr 06 2008
    07 RS4, 08 V8 Treg
    Chicago, IL
    Which shop are you using for the install?
    Natural Progression:
    1985 VW Cabriolet 1.8 - 1994 VW Jetta 2.0 - 1999 VW Passat 2.8 - 2007 Audi RS4 4.2
    I would guestimate about four hours for install. Also, I was under the impression that you want to wait a few days to a week before alignment to let the car settle.
    Dec 05 2006
    So. Cal.
    Here's the deal. Your local shop is not going to be able to do it because you're not supposed to move the car on an uncharged DRC system. It can damage the suspension. In addition, having 2 shops work on the suspension is a no no. If something goes wrong and gets damaged, neither shop is going to take responsibility. They will always blame it on the other shop.
    Your best bet is to have Audi do your springs and recharge the system all in one day.
    That being said, it's not cheap and unless you install the SS springs, your warranty will be voided. On another note, have you had your DRc recall done yet?
    Dec 02 2005
    chicago
    Unfortunately, my drc was replaced a few months ago.
