Originally Posted by
4rings2turbos
He sort of alluded to the fact that the compressor was running hard while my airspring started to leak worse and worse, and the heat caused the damage.
The "harness" for the allroad compressor consists of a heavy gauge "ground and hot" pair for the motor, a light-gauge pressure switch pair, and a black thermistor that looks like an additional ground connector that is bolted directly to the heat radiator at the top (bottom, when mounted) of the compressor piston housing.
It's possible that the compressor ran hot enough to damage the cabling, but unlikely, as the thermistor would have told the suspension computer to shut down the compressor until the heat radiated off. You get a suspension dummy light, and the level indicator light flashes without allowing you to change the ride height at all.
Considering that you have already replaced the compressor with a new one, it is likely that either the shop misunderstood the purpose of the thermistor and cut it off, or that you have an error with the level sensor LF as mentioned before.
You can:
A: buy a Vag-Com from Ross-Tech, read the suspension error codes and figure out where the fault is yourself
or
B: take the car to a shop that actually works on Audis and have them read the codes out for you
Either way, you want the specific error codes that the suspension computer is throwing. Otherwise, the possibility exists that the shop is blowing smoke up your ass, and doesn't want to admit they don't have a clue what they're doing.
The fact that you're replacing only a single front airspring shows that you either don't have the $$$ or don't care if the front suspension/steering is off because of the mismatched front airsprings. So, considering that you're stuck with an undriveable car until you get this resolved, I suggest:
1: Buy another front airspring for the RF so your suspension will be even
2: If the error code indicates the level sensor is bad, replace it. If that doesn't do the trick, take the car to an automotive electrical shop and have them splice in new wires to the ECU. This should not break the bank.
3: If the errors show problems with the compressor, have the same electrical shop replace the lines to the compressor, as well as the temp-sensing thermistor. This also should not break the bank.
The labor to get at the compressor is ridiculously easy...if you have a lift. You remove three nuts that hold on a debris shield, and then three more nuts to remove the compressor itself. Read my
build thread if you wish to see pictures of what it looks like. Personally, I replaced the entire wire harness from the compressor back to where the harness enters the chassis, as I installed the MBZ version of the compressor, rather than the Arnott spare. I should have done the Arnott, in retrospect.
Otherwise, I know guys in Calumet City that'll take that car off your hands reeeeal smooth-like.
