Results 1 to 13 of 13
    Veteran Member Three Rings PhunkFX's Avatar
    Oct 11 2005
    2019 TTRS, 1989 VW Cabriolet, 1986 VW GLI, 2015 Cayenne Diesel
    Post Falls, ID
    Is it common for the lower radiator hose to be cold in the winter?
    Some may have seen from prior posts that I have been having some heat and coolant leakage issues. Well, after weeks of bleeding and parts replacements, I am begining to wonder if I have a blockage somewhere in my cooling system. I have no heat or poor heat at times, the lower radiator hose is not warm in the slightest, freezing cold actually, and the car is not over heating... read on.
    Here are the symptoms: hot upper rad hose and ice cold lower rad hose, very intermittent heat. Some times there is heat, usually its ice cold or takes 3 times the amount of miles over 10 - 15 miles for the air to BEGIN to get somewhat warm. Sometimes when I have heat, I'll go up or down a steep hill and the heat will then change to cold air. Occasionally I will go out to my car in the morning and there will be coolant on the ground or in the snow. I gets pushed out from the reservoir overflow. Sometimes, in attempt to bleed the heater core from the top hose under the cowl, sometimes there would be coolant and sometimes you could take the hose off entirely with no coolant coming out from the hose or the port.
    Lately there has not been any coolant that was overflowed from the reservoir... though doesnt mean it wont happen again.
    The following are a list of parts that were replaced in January in attempt to fix a flow or leaking issue:
    Coolant expansion tank and cap
    Thermostat (with the whole housing)
    J-Plug
    Water Pump
    I have also checked all turbo connections and other engine o-rings, holes clamps, and snap connections for leaks. Everything is good. Why would the lower rad hose be cold and my car NOT be overheating. No heat, cold lower rad hose, and NOT overheating. Confusion. Thanks.
    -Ricky
    2019 Audi TTRS Prestige | Stage 3
    2015 Porsche Cayenne Diesel | Stage 2
    2015 VW Golf SEL TDI 6MT | Stage 2
    1986 VW Jetta GLI Wolfsburg Pirelli w/11k Orginal Miles
    1989 VW Cabriolet | 1.8T K04 w/nitrous
    Oct 11 2005
    Post Falls, ID
    Here is a photo of the coolant flange and J-Plug change:
    Here is the broken J-Plug we pulled out, it was siliconed into the housing:
    -Ricky
    Veteran Member Four Rings Duchenbagen's Avatar
    Feb 29 2004
    ATL/FLL
    Have you bled your heater core at the firewall?
    John
    USP CLUB MEMBER #5
    How much does the illusion of integrity cost?
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Quote Originally Posted by Duchenbagen View Post
    He said he did and sometimes there is coolant and sometimes there isn't.
    You have two options left and you won't like either of them. It's the head gasket(my guess) or heater core. You could have a very small leak in your head gasket which is causing your cooling system to always build up air. My Jetta had the same issue. I would be able to drive for months without overheating, but when i took the head off, exhaust port 4 showed signs of a small leak. Small enough to go undetected. Do a compression test first (lower compression are signs of a leak) and check your spark plugs (white means you may have found you're culprit). I went through trial and error for about 9 months replacing everything in my cooling system until these were the only two left, I decided head gasket first because it was less of a PITA than the heater core and I was right.
    The heater core would explain your heating issues, but not your cold radiator hose or overflowing tank.
    Sep 12 2008
    South Central PA
    I had this same exact issue. it was my headgasket.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Oct 11 2005
    Post Falls, ID
    Quote Originally Posted by Dan[FN]5857 View Post
    Please no. I must not understand... how would my symptoms and issues be related to a failed head gasket???
    -Ricky
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    ^^^Head gasket failure would cause air pockets in your cooling system/lower the coolant level.
    Thus creating the problems u describe.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Sep 12 2008
    South Central PA
    what headbolts are you using? OEM? ARP?
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Dec 08 2006
    Jersey
    Quote Originally Posted by PhunkFX View Post
    Read my post!!!
    Quote Originally Posted by akaEsCo01 View Post
    ...You could have a very small leak in your head gasket which is causing your cooling system to always build up air...
    Oct 11 2005
    Post Falls, ID
    ARP.
    -Ricky
    Sep 12 2008
    South Central PA
    how many miles? I only had this problem when I ran ARP headbolts, I never once had this problem when running OEM TTY headbolts. I'm putting back in OEM headbolts this time around.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Oct 11 2005
    Post Falls, ID
    I have over 3500 miles on the car with these bolts. About 1000 miles before I started having problems.
    So you totally think this is a HG issue? I've replaced and have tried all other possibilites.
    -Ricky
    Sep 12 2008
    South Central PA
    that's roughly how many miles I went when I started having problems
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
