Results 1 to 16 of 16
    May 11 2009
    Long Beach, Ca.
    Adding power to a stock A4 2.0 Turbo.
    What is the reality of how much power you can actually add to a stock 4? Im thinking Chip+Exhaust+Filter...what will that get me? Thansk for any help.
    09' Deep Sea Blue Avant 2T
    Blacked VMR V708's / 19x8.5 +38
    255/35/19 Kumho SPT
    H&R Coilovers "3+”
    Sep 16 2006
    San Diego
    At least 55 hp, you also should change the diverter valve. If you wanted to go big you can go for full Stage 3 upgrade(GT28,fueling, tune, downpipes), that would push the car close to 400hp.
    Veteran Member Four Rings hoppy6698's Avatar
    Sep 10 2009
    2015 BMW M235i
    Yorktown, VA
    Chip - Depends on which type, but most add about 40+ HP and 70ish TQ.
    Exhaust - 5-10 HP, if that much
    Downpipe - 10-15 HP, 8-10 TQ, this frees up the most restrictive part of the exhaust ... the beginning
    Intake - 5ish HP, if that
    The new turbo intake from APR, i think, adds some real sick numbers to trump most of these, mostly because it comes with the chipping and a more efficient turbo.
    "A man who won΄t die for something is not fit to live." - MLK Jr.
    Mar 02 2007
    Fresno, CA
    Wow, talk about not bothering to search. Seriously?
    Quote Originally Posted by Bells7246 View Post
    This is simply not true. There have been no reports of the new DV's failing on the B8 forum. In fact, many have indicated that the OEM design is superior to the current aftermarket offerings.
    Veteran Member Four Rings A5MD's Avatar
    May 21 2009
    2009 Acura MDX Tech, 2015 X5, 2014 Police Interceptor, 2018 Civic Sport Hatchback
    MD
    I can't see 400. The K04 doesnt even produce 400
    May 05 2009
    Cupertino
    Quote Originally Posted by A5MD View Post
    I think K04 is a "smaller" turbo than true stage 3 ..i.e. GT28
    2015 SQ5 :034 Trans Insert, 034 RSB, 034 X-Brace, H&R-1, Photosync front, Xpel front, OptiCoat, Windsea Sunshade, EPL....$$$$$
    SOLD : B8 A4 2.0T Quattro / Huper Optik 50% / Eurocode FMIC /Eurocode USS system/ APR Quad Tip Turboback / APR K04
    May 21 2009
    MD
    Quote Originally Posted by babadudu View Post
    My bad. Thanks for clarifying.
    OP: What were your previous cars? Have you driven any cars that have either the GIAC or APR tune? Since you have an 09, you can do the 30 day free trial period from APR and see how it feels. From there you can add a HFC then upgrade to stage 2 if you go with the APR tune. I have this setup and spent @ $1,300 and it was well worth it
    Jun 02 2009
    San Francisco
    Yup, and not to be a d#$k, but this is what happens when trolls get the ball rolling in a thread.
    Veteran Member Four Rings ThePiombino's Avatar
    Dec 01 2008
    North JerZ
    Quote Originally Posted by keihoop View Post
    Filter more for sound than performance. If you get 5 actual HP, that would be a lot. ECU flash, FULL exhaust and FMIC would be your easiest/cheapest way to approx 300 HP. ECU flash will net you about 25-30 HP, plus FULL exhaust (with either test pipe or HFC) will net you another 25-30 or so. FMIC I believe is 20 HP ballpark. And don't kid yourself- even though these numbers add up to 70-80 HP, it doesn't not mean you'll be adding 70-80 HP. Each add-on maxes its HP at different RPMs and whatnot, so odd are you may only see 75%-80% of this. That said, short of going APR Stage III, this is the cheapest and fastest way to approx 300 HP, prolly really more like 275...
    You must not be familiar with the B8... OEM DV is more than efficient and does NOT need to be replaced. Also, the only "Stage III" out right now is the APR K04. Unless of course I've missed something, which is totally possible...
    09 A4 2.0T Quattro - Tip - Black/Black /// MODS: APR Stage II+ | AWE CB Exhaust | 034 HFC l EC HFIC Pipe | Forge DV Spacer | 3M Di-NOC Carbon Fiber Interior Trim | 3M Chrome Grille Trim | SG Supreme 28 | Debadged | Fly Eyes Kit (f&r) | Needle Sweep | Window/Moonroof control w/Keyfob | Seat Belt Chime Disabled | "Wink" Disabled | Double Unlock "Beep"
    Veteran Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    Forget adding power. Get a set of lightweight 16s, strip the interior, remove the spare, and do P90x.
    OEM+ '09 Meteor Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hόper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards • VAG-COM'd
    Bilstein PSS10s • Eurocode IC Pipe • Avant Dual Exhaust • StopTech Pads • Lamin-X'd • Smoked Ambers • Blesk 5000ks • 034 Trans Mount
    Dec 17 2008
    Charlotte, NC
    HFC + Exhaust + FMIC + Stage 2 software, that's about as high as you can go without changing the turbo at this point and no one makes a GT28 kit yet that I know of for this 2.0T. I'm sure you could get one made and have it custom tuned.
    Ol' Whitey - 1996 A4 2.8 quattro 5MT Arctic White w/ Remus
    #2 - 2008 A4 2.0T Quattro 6MT Quartz Gray - w/ AWE exhaust (1/08 - 1/11)
    #3- 2011 A4 6MT Quartz Gray - Prem Plus, B&O, Titanium - Full Gen1 AWE dual exhaust, Eurocode Everything, 3M Clearbra, Piano Black Dash Surround, MY10 rear headrests, Huper Optik, S-line Stoneguards
    #4 2014 Audi S4 6MT - Monsoon + Black optics Neuspeed exhaust, Eurocode bits
    Audi Brand & Audi Sport Specialist at Northlake
    B8 Titanium Club Member #4
    Sep 30 2009
    b
    Quote Originally Posted by ItsDubC View Post
    lol
    Veteran Member Three Rings Cabal_san's Avatar
    Sep 06 2009
    TX
    bah! n1
    i was just gonna throw out, get an s4 if you want to stay b8 4 door. Or any other ricer out there will get you more HP.
    Sep 06 2009
    TX
    bah! n1
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Unless you hit the track often, when are you going to use 400hp?
    I'm willing to bet you guys are quicker than 95% of what's out there already.
    I say just go Stage 1 or 2 and call it a day.
    -cW
    2023 X3 M40i Alpine White
    Dec 18 2009
    2015 Jeep Wrangler JKU
    Atlanta, GA
    this + apr stage 1
    2018 Audi S5 SB - Gotland/Rotor
    Previous Cars █
    2010 Audi A4 2.0TQ 6MT
    2008 Audi TT 2.0T S-Line DSG
    2005 VW Jetta GLI 1.8T 6MT
