[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
(06 Audi A4) Quattro/2.0T Quartz Grey/Black-------Lots of plans
---------- VMR V710s, D2 Coilovers, APR 93, RS4 Swaybars, 034 HFC---------
Remember, you cant turn a pig into a racehorse but you can build a mighty fast pig!
Neuspeed * 034 Motorsports * KW V2 * EBC RED * RS4 Rear Sway * "D" * MR118 18x8 * VAG'd and a bunch of other stuff ...
Non S-Line Club Member:006
05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
- Slammed STG3 B7 A4 on Works
-"if you were anywhere near a teenage age you would understand that my hair is fucking sick, so go fuck yourself."
APR 93 oct. Stage II; 034 High Flow Cat; Custom dual 2.75'' exhaust with Magnaflow 14816 mufflers, Servotronic Fuse pulled; Cupra R Lip; and the oh so stereotypical Euro plate and THULE roof rack
2006 DG Audi B7 A4 2.0T 6spd
- Performance: APR Stg2+ 93oct using 94oct gas / AFE Dry Filter/ 034 HFC/ APR HPFP/ Treadstone TR6 IC / OBX Cat-Back
- Handling & Braking: Stasis SS Coilover / RS4 Sway / Carbotech Bobcat Pads
- Look: Drop / 19" VMR V713 / OEM S4 mirror / DDM 6000k bi-xenon
- Other: Evolution skid plate/ Ross Tech VAGCOM/ Snub Mount
2006 A4 Brilliant Black 6MT
- Revo Stage 2+ - AWE HPFP - ST Coils - K&N - 034 TIP - Newsouth Vent Gauge - Neuspeed Snub - OEM DV Upgrade - E-Code test pipe - AWE Quad tip - s4 rear valance - de-badged - vag'd -
-Wake up an address the biggest issue of our freedom. National DEBT.
2008 Audi A4 S-Line/Ti 2.0T Quattro
2003 Audi A4 1.8T Quattro (crushed by tree)
2006 Brill Red B7 2.0T 6MT, Color DIS, factory RNS-E (upgraded to version 0200), BT, Adaptive B-Xenon, Koni FSD/Eibach springs, RS4 rearr swaybar, H&R 32mm front swaybar
2003 Dolomite Gray TT 1.8T 225hp Cpe 6MT--da Wife's daily driver, with Fogs as DRL's, Votex front bumper
1973 Mini--1275cc, HIF44,1.5° rollertip rockers, stage 4 head, LCB, RC40, solid mount front subframe, poly mounted rear, negative camber all around, adjustable ride height coil spring conversion.
05.5 B7 A4 longest running with no motor issues at 373whp
Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
F.T.W.L.T.B.D.W.I.C.T.W
B7 RS4
