Results 1 to 29 of 29
    Jan 01 2008
    Long Island NY
    Pros and Cons of a testpipe...
    I have a testpipe siting at home. My last 2 cars both had testpipes and I was beyond happy with the benefits it presented. This time though I have a brand new car and I'm not sure it's the pros outweigh the cons. I'm pretty sure I'm going to install it eventually but I want to hear what you all have to say.
    The reason I went with the testpipe was for the large performance gain when combined with APR Stage 2.
    Pros: Big power gain, great sound, louder (positive IMO), better pull through the rev band, no cel with APR
    Cons: bad smell, pollution..
    Can a testpipe do any damage to the car compared to running a stock cat?
    If I run a testpipe with no software for a few weeks, besides getting the cel will the car run crappy or damage anything? reason I ask is I want to put it in now and the software release is March 1st
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    I don't think it would run crappy as the secondary o2 only tells the car that the cat isn't doing its job... the primary o2 does all the work for air/fuel mixture. I'd prolly just toss it on and enjoy for a month.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Jan 01 2008
    Long Island NY
    Quote Originally Posted by bigblue View Post
    That's what i was thinking aswell.. Just a cel but no negative effects or influence on drivability..
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Lol besides the smell... I'm pulling my testpipe out for a new 034 high flow cat because my car smells so bad and my exhaust tips are always black as hell.
    Jan 01 2008
    Long Island NY
    Lol it smells good ;)
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    I have charcoal cabin filter and it doesn't help. Plus I drive around with windows down all summer.
    Established Member Two Rings B8_RDC's Avatar
    May 25 2010
    San Jose, CA
    I just ordered a testpipe but going to modify it with Magnaflow cat. Used a maganaflow on my old grand prix with excellent results. I hear all the cats on existing pipes are junk.
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    How are you going to make that fit? its not a straight piece of pipe? Its angled so you would have to install a cat between the downpipe and the rest of the exhaust.
    May 25 2010
    San Jose, CA
    Hacking up the testpipe to add quality HFC from magnaflow. The metallic spun core is approx 3" long so should fit between the two existing bungs. Parts arrive Fri. will create separate post if works out and doesn't set CEL. The PN i used is popular with the Porsche crowd and has some 3rd party flow data that looked promising.
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    I have an HFC and my tips still get very black
    [B]Current: Shopping now....
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    i cant handle the smell... heard it was cancerous too
    2010 A4 quattro, Tiptronic, Ibis White
    Senior Member Two Rings fredjones's Avatar
    Apr 24 2009
    Mobile, Al
    I painted my chrome tips black, now I don't have to worry about soot buildup
    2009 Audi A4 Prestige, Brilliant Black
    Mods: APR Stage 2, APR Downpipe, H & R Rear Sway Bar, License Plate LED.
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    I for one is a big fan of the Test pipe, I enjoy every aspect of it; from the power gains it provides, instant spool up, lower EGT and last but not least the smell of unfiltered 94 octane + WMI along with the after-fire/backfire loud shot-gun pop on a WOT 2nd-3rd shift which would potentially keep unwanted tail-gaters off my butt. The only thing which would keep me away from another test pipe would be the soot it shoots out against the wall of my parking spot, I have now put a card board there to keep unwanted soot off the wall.
    Jul 04 2009
    I have a question for the OP, did you run Test pipe with a catback exhuast on your your B7? Did it drone? I am considering on purchasing the AWE downpipe or the Neuspeed 70mm exhaust from Eurocode.
    Veteran Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    I can never do a testpipe due to the smell. Not crazy about smelling it on other people's car, so I won't subject others and myself to it.
    I get why people do it, though.
    Ryan - flickr
    Jul 04 2009
    Quote Originally Posted by dracolnyte View Post
    hey Ken, I sacrifice smoking to install a test pipe on my ride. Hopefully I lower the chance of getting Lung cancer. Isn't that a good enough of a reason to quit smoking. lol
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    Oh definitely. As long as it's somebody else getting the smoke.
    Ryan - flickr
    Veteran Member Four Rings promoda's Avatar
    May 26 2010
    2015%20Audi%20Q5%2C
    Montreal
    I have a TP and it only smelled for the first couple of weeks, but now no smell no smoke? and in regards to the 02 censer when I installed my stage 2 chip they programmed it so that it doesn't come on any more... my only complaint is the sound it makes, it should more throaty...
    Veteran Member Four Rings ThePiombino's Avatar
    Dec 01 2008
    North JerZ
    Quote Originally Posted by k9lovr View Post
    +1
    09 A4 2.0T Quattro - Tip - Black/Black /// MODS: APR Stage II+ | AWE CB Exhaust | 034 HFC l EC HFIC Pipe | Forge DV Spacer | 3M Di-NOC Carbon Fiber Interior Trim | 3M Chrome Grille Trim | SG Supreme 28 | Debadged | Fly Eyes Kit (f&r) | Needle Sweep | Window/Moonroof control w/Keyfob | Seat Belt Chime Disabled | "Wink" Disabled | Double Unlock "Beep"
    Aug 09 2007
    Mount Airy, MD
    Running a test pipe will not do any damage to your car. and the cel from the secondary won't do anything either. Have you guys seen our testpipe/hfc option?
    click here for more info
    It's got a few cool features that set it apart.
    Optional third o2 sensor bung available for Wideband applications
    Included threaded J-pipe for 100% CEL Free Operation.
    304 Stainless Steel Machine Finished Eccentric 4” to 3” Reducer reducer matches with exhaust turbine outlet.
    *Optional 300cell HFC flows 600 CFM's
    I have the b7 version in my avant, and I can personally attest to the benefit of the reducer. (I had an ebay tp prior to putting in the RAI unit) it feels much smoother, especially as the revs climb.
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    The smell goes away after awhile
    My current rides...
    Audi
    Jetta
    Apr 24 2009
    Mobile, Al
    Quote Originally Posted by Jacon View Post
    This is wishful thinking. I had a testpipe and the smell never went away. Maybe you just get accustomed to the smell and it does not bother you as much.
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    Jeez I never knew the smell was that bad. I had a test pipe for 3 years and only noticed the smell when I was standing behind my car. Even then it wasn't that strong of a smell.
    Jan 21 2011
    CA
    How bad is the smell?
    Aug 09 2007
    Mount Airy, MD
    I hardly ever smell it.
    - Will
    The Avants Timeline
    Apr 24 2009
    Mobile, Al
    I guess I have to agree with all you guys that noticing the smell is very subjective and user dependent. Just may not bother some folks. But the advertisers chiming in with their opinions are not exactly an unbiased source, they are trying to sell a product.
    Aug 11 2007
    California
    He already has the product. I'm not trying to sell anything. I just thought it was weird that so many are bothered by the smell. When I had it on my B6 A4, it was only slightly noticeable when I'd stand behind my car while it was on.
    Veteran Member Three Rings NickZag's Avatar
    Feb 22 2010
    2006 S4 Avant
    Northern, CA
    The smell can't be much worse then the 383 Stroker in my 69' Camaro lol
    2021 A4 | 2006 S4 Avant
    Veteran Member Three Rings piotrowr's Avatar
    Jul 18 2008
    Scottsdale
    You're just use to the build up in you nasal cavity and lungs ;)
    2010 A4 Avant Prestige - 19" Sport Package, Quartz Gray Metallic
