Results 1 to 17 of 17
    Veteran Member Three Rings TEB's Avatar
    Sep 19 2010
    '70 Cutlass, Yukon, MDX, Pilot
    Ponte Vedra Beach, FL
    How to replace the dashboard cupholder?
    The spring insert thingie broke out of my cupholder this weekend. How do you remove it from the dash? Cheapest place to buy one?
    While on the subject of cupholders, the one in my rear arm rest sticks and required quite a hard poke to get it to come out ** easy fix for this?
    B6 noob, be patient with me.
    May 23 2010
    2004 S4 6spd
    Dougalsville, GA
    my back cupholder also requires a good poke to get it to come out...
    i would also like to know if there is a fix for this
    Established Member Two Rings moondev's Avatar
    Nov 29 2010
    Charlotte
    Make this an excuse to do the b7 console swap. The b6 pop-out cupholders are useless imo.
    Registered User Two Rings antidote's Avatar
    Sep 01 2010
    F-350 | Aero 95 | 505 Sport | Touareg | 67 Fast Back Custom | S4
    Fullerton, CA
    Quote Originally Posted by moondev View Post
    interesting, i've never even thought of that maybe i'll do that.
    Oct 12 2008
    B9 RS5 B8 S4s, S5
    Saratoga NY
    I would go the B7 route if you have the time and money but I just followed this DIY. Be careful if you need to reuse the face. I scratched up mine pretty good when my screwdriver slipped and had to get another cupholder from Joey.
    eBay has a few of them also, just need to make sure you get one that matches the b6 (without the chrome strip)
    http://www.audiworld.com/tech/int60.shtml
    Sep 13 2008
    Western Chicago Burbs
    Get the b7 console. All set and done, mine was ~380
    Jan 29 2010
    north ga
    eh.....just replace the dash cupholder for $15. I like the B7 center console but $15 beats $380 anyday, especially since if you buy the B7 center console you'll still have the broken dash cupholder
    Sep 29 2010
    Portland, Oregon
    Quote Originally Posted by B6JoeS4 View Post
    really wanting to do this to mine.
    Tried looking for a center console retrofit thread. So far no luck.
    Nov 29 2010
    Charlotte
    Quote Originally Posted by mpower3o2 View Post
    http://www.audizine.com/forum/showth...-list-in-black
    Sep 13 2008
    ^that's what I used
    FYI, the Hand brake button is not available through GAP. I had to get it at the audi dealer
    Deactivated Four Rings
    Apr 13 2008
    Bayern
    if you take any part of the dash apart, you should leave the cup holder broke.
    Senior Member Three Rings ozo101's Avatar
    Jan 24 2009
    nj
    what the hell did you just say ??
    Drop den Vorschlaghammer!
    Sep 29 2010
    Portland, Oregon
    ^that's what I used
    Thanks Joe.
    Veteran Member Four Rings jfunkey's Avatar
    Jan 21 2009
    R32 B7/S4....2000 2.7t gone :(
    putting you into the wall
    Quote Originally Posted by TEB View Post
    Lazy noob is more like it. Try searching. This was on the front page of the tech page. it even said cup holder install.
    http://www.audizine.com/forum/showth...holder-install
    JHM war machine. Total transformation. JHM/Tune/headers/intake manifold.
    My B7S4. Faster then my old RS4 and First B7 S4 in the 12's
    AMA member
    USMC member (active)
    Facts first member. Built and supported by many
    Sep 19 2010
    Quote Originally Posted by jfunkey View Post
    Thanks, I appriciate it. Any advice on the rear cupholders?
    Jan 21 2009
    Advice as for how. Do you need to replace them.
    AMA member
    Established Member Two Rings scamsel's Avatar
    Jan 22 2011
    '04 S4
    atlanta GA
    i was wondering if anyone knew how to make the rear cupholders come out? mine seem stuck, i push and push on them, is there a switch somewhere or something? is anyone elses stuck?
