    Jul 02 2009
    TX
    CEL--IAT sensor (G42) ??
    Is the intake air temperature sensor integrated in the mass airflow sensor or what? Tried searching, but I can't seem to find a definite answer. Please help...thanks.
    Jul 02 2009
    TX
    Does anyone know?
    Some back story...I got a check engine light, car is misfiring, so I take it to a local shop and they say I need to replace coilpacks and MAF. Got all cp's replaced at the dealership (recall) and replaced the MAF I bought from JH Motorsports. I don't have a vag-com, so I unplugged the battery while changing the MAF. I drive for ~25 miles and a solid CEL comes back on. I stop by a local shop again and the only code I got was for the Intake Air Temperature Sensor (G42). Now, I'm not sure what I need to do. Where is the IAT? Is it part of the MAF? Is it the connections?
    I could use any suggestions.
    Thanks,
    Franky
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    Quote Originally Posted by si-low View Post
    Bumping for details on this.
    - Erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Its integrated into the maf
    Sep 13 2008
    Western Chicago Burbs
    Yes the IAT sensor is part of the MAF sensor. If you replaced the sensor and it is still thorwing a code, I would take a look at the wiring. It could also just be a defective part
