Results 1 to 17 of 17
    Nov 07 2008
    2002 A4 Sport 3.0; 2000 Saleen #415
    SE Michigan
    What does "Headlight Dipped" mean?
    Driving to work this morning and my indicator on the dash goes off and shows "Right Healight Dipped" then went off right away. When I got to work I pulled up to the building and both headlights were aimed level. What does that normally mean? The automatic level is going bad?
    Sep 10 2008
    TX
    For me that has meant bulb out.
    internet sales at boardwalk VW in Richardson, TX/ cell 214-901-3449/ direct 214-453-6014
    05 A8 4.2 NBP everything but sport package
    02 A4 1.8 quattro tip
    08 aprilia scarabeo 100
    89 RX-7 vert
    85 RX-7 GSL-SE (i miss you)
    92 NSX (i really miss you)
    70 Chevelle (i dont miss you)
    Nov 07 2008
    SE Michigan
    Both lights are still on though.
    Sep 10 2008
    TX
    Its only out when the bulb is out. Then the warning goes off when the bulb comes back on. Can also be a ballast if you have xenons.
    89 RX-7 vert
    Jan 24 2008
    Pennsylvania
    i think dipped headlight means they need to be adjusted/aimed, depending on how close to the building you were sitting when you judged whether they were level, they clould look fine if you're too close to the wall you shined them on.
    I think it can also mean the difference between the voltage signal coming from your front and rear auto level sensors has exceeded the specified limit.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Established Member Two Rings chokung's Avatar
    Dec 27 2010
    [US]:2005 VW Bug Convertible;[Th]: 2000 E230, 1997 VW Sharan VR6, 1995 Saab 9000CDE, 1989 VW Vanagon
    Bethlehem/PA
    I lean to the adjustment in need!
    My 3.0 with xenon use to have this warning on several time, I do nothing (yet) and there is no warning so far.
    I think if both light still on you should be good. I google some past threads, found that 'automatic leveling' or something may went? I'm not positive though.
    Chk these out: frm audiforums ; frm AZ old thread
    Aug 19 2010
    Vancouver
    it does not mean your bulb is out... how do people confuse dipped headlight with bulb out? what are you people smoking?
    Nov 07 2008
    SE Michigan
    That's what I was thinking, but oh well just taking advice from people.
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    you have to vag the car. You might get lucky and just clear the code and it goes away... but most the time you have to actually jack the car up while vaging it and re-level them to clear the warning light.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Sep 10 2008
    TX
    Quote Originally Posted by ayfour View Post
    while driving in my parking garage a few months ago I got the headlight dipped warning and could tell that there was no light coming from that side of the car every time. the warning would go away and the light would come back on.
    89 RX-7 vert
    Established Member Two Rings dwalmop's Avatar
    Apr 15 2010
    2013 A6 Prestige, 1990 Audi CQ, Gone: B6 A4 Avant 1.8TQM
    Hudson, WI
    Because if you don't have xenon's, it does, in fact, mean your headlight bulb is out.
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    Quote Originally Posted by dwalmop View Post
    what am I missing then? because everytime my "dipped headlight" warning comes on, my passenger bulb goes out for a second. And yes i do have factory Xenons.
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
    Veteran Member Four Rings Lusticles's Avatar
    Nov 04 2009
    a lemon
    For cars equipped with halogen headlights "headlight dipped" does in fact mean "bulb out."
    2002 Dolphin Gray A4TQM - Totaled
    Jul 14 2009
    Pasadena
    if u ever started the car with the headlights unplugged youll get a warning. do what audi skate snow did and just vag the car
    IG: @matthewee
    Apr 15 2010
    Hudson, WI
    Quote Originally Posted by alpinestar180 View Post
    Have you tried the ballast? I read a lot about this when i first got my car, and it seems that ballasts seemed to cure the issue for other people. I don't have factory xenon's though, so i can't say for sure.
    Senior Member Three Rings Marlon177's Avatar
    Nov 04 2010
    2016 CLA250 4Matic
    NY/South Jersey
    i had the same problem, it was my bulb, the easiest way to find out either the ballast or the bulb, simply switch the bulbs, if u still get the same msg, then its ur ballast, if u get left head light dipped instead, then its ur bulb. good luck.
    P.S i do have factory xenon.
    Nov 07 2008
    SE Michigan
    I have factory Xenon also. It only did it once for about 1 sec then never came on again. It was dark out at 6:30 am and I never saw any headlight flicker off then back on. Hell who knows, these are the best cars ever made, but damn can they give you a headache too.
