Results 41 to 80 of 103
  1. #41
    Veteran Member Three Rings TheKid23's Avatar
    May 26 2011
    PA to IA
    This doesn't mention anything about swapping ballasts? I was under the impression that different ballasts were used between halogen and bi-xenon?
    Owned
  2. #42
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by TheKid23 View Post
    There are no ballasts on the halogens
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
  3. #43
    May 26 2011
    PA to IA
    Cleared that up.
    So the ballasts for the bi-xenons just need to be tucked away somewhere?
    Owned
  4. #44
    Jul 27 2007
    Orange County, NY
    Cleared that up.
    They're directly attached to the housing on the bottom considering you are using OEM parts
  5. #45
    May 26 2011
    PA to IA
    Was also looking at the other DIY about the differences between halogen and bi-xenons, gathering as much info as I can before my swap. The bi-xenons have the DRL bulb, will I just not use that function? Obviously don't have it now.
    Owned
  6. #46
    May 26 2011
    PA to IA
    Quote Originally Posted by Coderedpl View Post
    Perfect, yes OEM. Just bought them today, should be here by mid next week.
    Owned
  7. #47
    Jul 27 2007
    Orange County, NY
    When you code the headlights you'll see the various options of setting them up so yours can be running on if you want them to
  8. #48
    May 26 2011
    PA to IA
    Ok I read up on the Vagcom thread earlier and noticed that. So if I code them on, it doesn't matter that I don't have the DRL function on my headlight switch?
    Owned
  9. #49
    Jul 27 2007
    Orange County, NY
    Its a little knob NEXT to the headlight switch, but yes it doesn't matter.that knob just allows you to shut them off.
  10. #50
    May 26 2011
    PA to IA
    Yea I'm familiar with it, I meant that I don't have it.
    Owned
  11. #51
    Veteran Member Four Rings kurupt_hawaiian's Avatar
    Oct 13 2007
    2017 Toyota Tacoma TRD Off-road
    Waianae, Originally Molokai
    If you don't have the knob and code them on...it will be on at all times, until you code them back off through vagcom.
    2018 Audi A6 Mythos Black
    (SOLD) 2007 Audi A4 Quartz Gray 2.0T 6MT
    Follow me on Instagram- @Kurupt_Hawaiian
    -Elias
  12. #52
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by kurupt_hawaiian View Post
    If you have 'em why not run them. they look great with led bulbs too
  13. #53
    May 26 2011
    PA to IA
    This is what I figured. So they'd turn on when I started car, would they stay on when I put the headlight switch to city light? And turned headlights on?
    Owned
  14. #54
    Jul 27 2007
    Orange County, NY
    Nope
  15. #55
    Veteran Member Three Rings rarak69's Avatar
    Jul 15 2007
    Snap-On
    Pittsburgh, PA
    Im not sure i understand the need to recode for these headlights.
    Do the actual OEM xenon headlights have some sort of CAN -BUS control board in it? On my B5/B6 you could swap xenon headlights, plug and play, thats it.
    My b7 which i did a retrofit on(proper) i just grabbed my bixenon from the high beam wire and soldered it over to the actuator, which is a method used for a few of my buddies cars too in the past.
  16. #56
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Halogen to Bi-Xenon - Kufatec Interface
    I converted my halogens to bi-xenons about 2 months ago. Before I did the vag-com it would flicker which is bad for the xenons. Vag it and it will work fine.
    Gotta vag mine I guess. Installed earlier, and things were fine. Now it's flickering pretty bad (almost like strobe at times). Dang it, I hope that fixes it and its not that the ballast are bad. That would suck...
  17. #57
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Quote Originally Posted by B7Joe View Post
    VAG-COM fixed it. Also followed the guide to wire the high beams. Worked great. The kufatec harness itself is excellent quality. The new ones have been upgraded and all the wires are wrapped in OEM black fabric tape. Nice touch.
  18. #58
    Oct 31 2011
    B8.5 S4, B9.5 SQ5, MK4 Jetta
    Redmond, WA
    DIY on this guide? i thought the high beam function was plug and play
    "if I wanted magic phallus shaped objects that didn't make me go any faster, I would just hit the gay club downtown, no need to spend $400." - Mec
    S4 Build
  19. #59
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Quote Originally Posted by AKOeuro View Post
    Yes, I used this guide (DIY) starting on page 1. Nope, high beam function requires some minor wiring to work.
  20. #60
    Oct 31 2011
    Redmond, WA
    It doesnt talk about the wiring in this diy?!
    S4 Build
  21. #61
    Oct 02 2012
    Austin TX
    ?xxxx: Chassis
    0 = Limousine (PR-K8B)
    1 = Avant (PR-K8D)
    2 = Cabriolet (PR-K8K)
    x?xxx: Driving Light Switch
    0 = Rain/Light Sensor (G397) not installed (PR-8K0/8K1/9C6/8K4)
    1 = Rain/Light Sensor (G397) installed (PR-8K3/8K7/9C7/8K9)
    xx?xx: Trailer Hitch
    0 = Trailer Hitch not installed (PR-1D0)
    1 = Trailer Hitch installed (PR-1D2)
    xxx?x: Headlights
    0 = Halogen Headlights w/o Daytime Running Lights (PR-8Q0/8Q1+8K0/8K7)
    1 = Halogen Headlights with Daytime Running Lights (PR-8Q0/8Q1+8K1/8K3/9C6/9C7)
    2 = Bi-Xenon Headlights with Daytime Running Lights (PR-8Q3/8Q5+8K9/8K4)
    3 = Bi-Xenon Headlights w/o Daytime Running Lights (PR-8Q3/8Q5+8K0/8K7)
    4 = Bi-Xenon Headlights with Daytime Running/Tail/License Plate Lights (PR-8Q3/8Q5+8K1/8K3)
    xxxx?: Country
    1 = Rest of World/Nordic Countries/Denmark/Croatia/Baltic Countries with Bi-Xenon
    2 = Nordic Countries/Denmark/Croatia/Baltic Countries without Bi-Xenon
    3 = USA/Canada with Bi-Xenon
    4 = Canada without Bi-Xenon
    5 = Special Vehicles
  22. #62
    Oct 31 2011
    Redmond, WA
    How did you guys get to the last bolt that hold the headlight? the ones thats nearest to the fender. Theres no way i can seem to get to it to tighten it
    S4 Build
  23. #63
    Oct 16 2008
    South Florida - Ft Lauderdale
    You need an extended Torx tip
    You can also try with a long flat screwdriver that will fit the torx head
    Phil
  24. #64
    Veteran Member Four Rings mpv314's Avatar
    Apr 06 2012
    Audi A4 2006 Quattro
    New York, United States
    The running of the yellow wire is basically enabling the high beam function. Just follow this DIY exactly, VAG COM your car and you should be good to go. I'm about to do this mod, just waiting on my VAG COM wire to come in the mail. I want to test everything to be working perfectly before I go ahead and start taking my halogens out.
  25. #65
    Aug 19 2005
    07 A4 Avant S-line 6MT
    CNY
    Does this process also add the adaptive portion of the OE HIDs or does that require different Kufatec harness and parts??
    '21 SQ5 Ultra Blue
    past: B7 Avant 2.0t S-line Manual [CTS K04, 034 K04 Tune, Golf R intake cam, CTS HFC, Stasis Exhaust, BFI Snub, 034 Street Mounts, Apikol Race Diff Mount, Hotchkis 29mm RSB]
  26. #66
    Oct 16 2008
    Quote Originally Posted by boostin20v View Post
    No, adaptive function will require additional harness and modules
    Phil
  27. #67
    Senior Member Two Rings jnm's Avatar
    Nov 30 2013
    B7 A4 Avant
    Marin, CA
    I'm curious if the yellow wires come with the kufatec harness? Also, is vagcom something I can download onto my laptop? Sorry for the noob questions.
  28. #68
    Oct 16 2008
    Quote Originally Posted by jnm View Post
    The 2 wires are the 2 signals for the High Beam function
    You need the VAG interface cable to be able to use the software
    Phil
  29. #69
    Nov 30 2013
    B7 A4 Avant
    Marin, CA
    Phil
    Ok great thanks for the info Phil. I ordered the cable off amazon and hoping to get the lights in the next few weeks. Great DIY!
  30. #70
    Established Member Two Rings Skodamaniak's Avatar
    Jul 10 2014
    Montenegro
    Hi. I instal xenon on my b7. Original ballast, d1s bulbs, adapters cable. And i have problem. On left side xenon is flashing... I don't now way?!
    Tnx!
    eurodubs.com
    we still play with cars!
    new foto from Worthersee 2015 https://www.flickr.com/photos/eurodu...57652316051991
  31. #71
    Veteran Member Four Rings jaycurn's Avatar
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Quote Originally Posted by Skodamaniak View Post
    Tnx!
    I am having a similar problem and wondering if any of you guys that have completed this retro might have experienced and resolved this? I am getting the following code:
    02071 Local Databus
    57-00- Electric Circuit Failure
    Symptom: After the lights have been on for over 10-15 minutes the DS beam will start to flicker and cut out while driving. When the car is idle it will still flicker but not nearly as often.
    I tried swapping the bulb first with a spare I had in the side that was flickering and the code persisted, but I did not have them on long enough to see if they would flicker.
    I then tried swapping the ballast with a spare, same results. Will see on my drive home tonight if they will start to flicker again, but I am fully expecting they will since the same code is present.
    Anyone?
  32. #72
    Veteran Member Three Rings tehbry's Avatar
    Aug 12 2012
    Atlanta
    So I'm about to pick up my B7 Friday and I'm already planning the xenon conversion. I plan to source the xenons from eBay as I want them to be ecode. Does anyone happen to know what part number(s) for xenons will work just as its laid out in this DIY. I would hate myself if I picked up a set of xenons and it ended up being the wrong set.
    Any help is appreciated, I'm looking forward to making the change from B6 to B7
    Sorry to resurrect such an old thread but didn't want to start a new one
    B7 A4 2.0tQ tip - Motoza stg 2 93oct - JHM FMIC/HPFP/T-pipe - HPA K04 - BBoat downpipe/exhaust - 034 motor/trans/snub mount - GFB DV+ - S4 Calipers/EBC pads/SS lines - Avant Garde M540 19x9.5
  33. #73
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by tehbry View Post
    Hey man. Congrats on the new purchase.
    As to the e-codes, its a bit different for the B7 xenons. So you can get Euro headlights, but my understanding is the light is aimed differently (for those left side drivers). What a LOT of members will do is open their xenons, take out the amber lenses and replace it with a clear one. They will often also "joey mod" or paint some of the chrome black in the headlight. I've personally done this before and it's not terribly difficult. There's a DIY on here somewhere. You can (or use to be able to) get the clear corner lenses from @fly300kts on this form. You may also want to buy your xenons off this form as they're usually decent pricing.
    Also, be aware that the euro headlights I've seen on eBay don't have ballasts or bulbs (those will cost another ~$300). and you'll obviously need the harness listed in this thread.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
  34. #74
    Aug 09 2012
    Sylvania OH
    Has anyone done this recently? I just purchased the kufatec harness here: https://www.kufatec.us/shop/en/audi/...-audi-a4-b7-8e
    What I received seems a bit different from this DIY. Did I order the wrong item?
  35. #75
    Oct 16 2008
    Quote Originally Posted by Sylvania A4 View Post
    Yes you ordered the wrong cable
    Phil
  36. #76
    Apr 24 2016
    California
    Major problem with this whole procedure. I'll create another thread as well.
    -Installed Bi-Xenon's (OEM) with kufatec harness wired into control module.
    -VCDS would not open Module 09 - Central Elec. Did a ton of troubleshooting on my computer to no avail
    -Unplugged two yellow wires and the kufatec harnesses and plugged the halogen housings back in.
    -VCDS opened up Module 09, finally.
    -Reprogrammed for 00033 (BiXenon w/o DRL), plugged harness back in w/ BiXenon housings back in, reconnected two yellow wires to pins 21/22
    -No lights, nothing.
    -VCDS will not open module 09 at all. tried unplugging yellow wires again and putting halogens back in, no lights. tried bi-xenon housings, no lights. no communication with module 09 at all to recode it back to halogen.
    So now I'm stuck with no headlights, no interior lights, heck no central electronics at all, and many hours wasted on this process.
    Anyone got any ideas?
    2005.5 A4Q 2.0T 6MT JHM 2+, Autotech internals, CTS front mount, GFB DV+, 034 Street Density mounts + snub, H&R coilovers, B7 Recaros, Phil's V4's, maybe a k04 soon?
  37. #77
    Senior Member Three Rings Jimmyjamms's Avatar
    Sep 20 2014
    Hilux SR5 3.0TD
    Sydney AU.
    Quote Originally Posted by RakkCity View Post
    Double check the harness is clipped back into ecu properly. Sometimes the little hook on the swivel tab thing don't grab and the plug isn't pushed all the way in
  38. #78
    Apr 24 2016
    California
    Quote Originally Posted by Jimmyjamms View Post
    Dude I must've unplugged and replugged that connector a dozen times in the last few hours. For shits and giggles I tried one last time after you said, pushed harder than I thought necessary and it worked! Thank you so much
  39. #79
    Sep 20 2014
    Hilux SR5 3.0TD
    Sydney AU.
    Haha sick dude. So your xenons are working?
  40. #80
    Apr 24 2016
    California
    Work like a charm now I just have to adjust them so I'm not blinding people
    Edit: there should be a PSA about those style clips. Every time I installed it the orange clip was clicking in like it was secured but it needed some more force to make contact with the pins.
