    Registered Member One Ring SickAzzTT's Avatar
    Jan 08 2011
    97 Honda Civic
    Greensboro, North Carolina
    Lowering Spring Vs. Coilovers
    Im gettn ready to lower my ride and i have been getting mixed reviews from friends on which was to go. So im asking my Audizine family whats better, Should i get lowering springs of Coilovers. What im looking for is a smooth comfortable ride after i apply them.
    If you not drivng an Audi get 1......
    Senior Member Three Rings pnoyworx's Avatar
    Feb 13 2010
    09 A5, 12 370z, 13 Pathfinder, 13 Nismo Juke, 08 ML63
    Bothell, Wa
    Initially you will get a smooth ride if your not looking to drop so low. But after a couple or so thousand miles, you will start to feel it get rough. Reason is your stocks shocks are not made to specifications of being on a shorter springs. This also will vary on the way you drive, the types of roads you have or drive on etc. Coilovers will always be better if your looking for real performance but the price will cost 9x-20x the price of that of springs. I went with Ohlins, best ride ever, smoother than stock, responsive, ability to adjust height, ability to fit different size wheels, corner balancing, etc.
    Veteran Member Four Rings dumpedb5's Avatar
    Nov 22 2009
    B5 Imola Avant and a MK4.
    City Of Roses
    Coilovers
    SQUISHEDTWINKIE
    Veteran Member Three Rings coachvtt's Avatar
    Jan 18 2008
    shotgun!
    Jupiter,FL out of Pittsburgh
    Ditto coilovers,but more expensive,I have Apex Springs 1.6" drop on stock shocks,but the roads are pretty smoothe
    here in South Florida. Shocks? I will eventually change when they start gettin squishy! I'm at 105,000 miles now.
    Veteran Member Four Rings Sandeman's Avatar
    Feb 15 2009
    2003 MB SL500
    where the horseman roams
    Quote Originally Posted by pnoyworx View Post
    he said it all, ive done both, honestly coilovers are worth the money. not trying to be dramatic, but its like day and nite difference. all coilovers vary, some are stiffer than others, i would research spring rates and reviews on forums like this one to seek what type of coilover you would like. i would go midrange price if youre not planning on tracking, a set of H&Rs, Konis, ST or KWs should be great and youll be satisfied
