Results 1 to 14 of 14
    Oct 27 2006
    Currently only S4
    Fort Walton Beach FL
    Bleeding cooling system
    Tried search but could not find details on how to bleed air from the cooling system. If anyone has tips, please let me know. It is not completely empty, but I had an aux water pump leak. Thanks.
    Rob
    Jun 24 2010
    You should be able to run the car after filling up the coolant bottle, and it should circulate itself.
    Turn the car on, high heat, full fan, with the cap off the reservoir and just keep adding mixture. As it draws more fluid down make sure you keep filling the bottle up.
    Squeezing the hoses should move any air out of stuck spots.
    Once the fluid seems to level off and doesn't take anymore, put the cap on and continue to let the car warm up. The system is designed in such a way that the air should end up in the bottle, and the fluid should end up in the system.
    Veteran Member Four Rings 99ebpsi24's Avatar
    May 04 2008
    10 S4 prestige, 12 A4 S-Line, 00 Stg3+ S4, 74 VW Thing, 74 Z28 camaro (32k original miles) 74 Z28 Ca
    Cincinnati
    There is also a bleeder screw in front of the TBB I believe it's a 5mm. Just back that out a bit and the air will bleed out there once coolant comes out tighten back up. Or you could also use the heater core bleeder, if I remember correct it's on the left hose slide it back and you'll see a little hole. Air will come out there and when coolant comes up slide the hose back up and top off the coolant tank and you're good to go.
    Current:
    19’ Ara Blue RS3 UniFlex stg1+, stg2 tcu, midpipes & IE intake
    21’ VW Atlas SEL Prem. R-Line
    15’ Sepang Blue S3 Prestige
    10’ S4 Prestige
    00’ S4 stg3+
    12’ A4 P+ S-Line
    08’ A4 P+
    Oct 27 2006
    Currently only S4
    Thanks, guys!
    Rob
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    The problem with our cars is that the heater core is the highest point in the system, so air will always get trapped there.
    On one of the hoses to the core (I believe the passenger side one) there is a hole in the neck that is there for final bleeding. That is the only way to get rid of all the air in the system.
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    Quote Originally Posted by NOTORIOUS VR View Post
    this.
    and on the hose connecting to the aux pump theres one
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Jun 24 2010
    how do you use that bleeder hole? just push screwdriver to open it until fluid comes out?
    May 04 2008
    Cincinnati
    The one on the heater core you just pull the hose back until you see a small hole in the pipe. Obviously you'll want the car running so coolant is circulating and when the whole starts pissing just slide it up to cover and top off the coolant if need be.
    Current:
    10’ S4 Prestige
    00’ S4 stg3+
    12’ A4 P+ S-Line
    08’ A4 P+
    Jun 24 2010
    wow thats a little sketchy trying to pull those hoses off part way isn't it?
    i know after you take the clamp off, you go to pull it and it seems to just come all at once and slide off, at which point you'd just be pissing hot coolant out.
    Sep 16 2009
    Delray Beach, FL
    No.. You are not pulling the hose partly off. The pipe it attaches to has a small hole in it. You simply slide it back a little to expose the hole.
    Said hole is on the passenger side hose
    May 04 2008
    Cincinnati
    Quote Originally Posted by DiscoPotato View Post
    This... If the hose is on there real tight and not wanting to move get a pair of pliers and grab it lightly and twist it to break it free then slide it back to expose the hole so the system can bleed.
    Current:
    10’ S4 Prestige
    00’ S4 stg3+
    12’ A4 P+ S-Line
    08’ A4 P+
    Veteran Member Three Rings zdriver's Avatar
    Jan 17 2010
    Boston, MA
    Anyone have a photo of this bleed vent?
    May 04 2008
    Cincinnati
    Current:
    10’ S4 Prestige
    00’ S4 stg3+
    12’ A4 P+ S-Line
    08’ A4 P+
    Jan 17 2010
    Boston, MA
    thank ya sir
