Results 1 to 19 of 19
    Veteran Member Three Rings killerkali's Avatar
    Jan 01 2011
    Nor cal
    Misfiring and rotten egg
    More problems with the S, i drove to pick up my buddy today and the car ran fine. Started it back up and have a CEL and the car is misfiring very bad. Starting out in 1st gear i have to really baby it to not shake myself to death. And if I get on it, i get the flashing CEL. At the same time it now smells like rotten eggs but I'm pretty sure that its related to the misfiring? From my knowledge the smell means its an ignition issue. Anyways here the dreaded vag . Ive had the cyl 3 misfire and the 02 bank 2 for a while but it never caused any issues and no CEL. Any help is always appreciated.
    Component: 2.7l V6/5VT G 0003
    Coding: 06711
    Shop #: WSC 06435
    5 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 - -
    16687 - Cylinder 3 Misfire Detected
    P0303 - 35-00 - -
    16540 - Oxygen (Lambda) Sensor B2 S2: Malfunction in Circuit
    P0156 - 35-10 - - - Intermittent
    16689 - Cylinder 5 Misfire Detected
    P0305 - 35-00 - -
    16534 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit
    P0150 - 35-10 - - - Intermittent
    Readiness: 0000 0001
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    The rotten egg smell is due to cat failure, either clogged or just shot. You have misfires obviously and you have 02 sensor codes but that could be from the cats failing. Replace your cats or just do piggies.
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
    Veteran Member Four Rings Mantis's Avatar
    Aug 04 2007
    x2
    I don't think I care anymore
    Jan 01 2011
    Nor cal
    Would a dead cat really cause all that? I was thinking the the misfires are dumping fuel into the cats.....? And would it be the precats in the dp's or the main ones dying?
    Jan 29 2007
    08 S4 00 S4
    MD
    Since you have a VAG-COM, log misfire recognition@idle. Do each bank and watch the misfire count on each cylinder. Look for a large number of misfires, like 1/second, you want to make sure all your cylinders are firing.
    08 S4- Stock SOLD
    Veteran Member Four Rings 1sadavant's Avatar
    Jun 21 2005
    '01.5 S4 & '05.5 M3
    Murrysville, PA
    Quote Originally Posted by killerkali View Post
    Yes, when you misfire, you are dumping more fuel (this is not good...) this is what killed your cat on your drivers side (Bank 2, B2), So now you have to replace both the primary and secondary O2 sensors on the driver's side. On top of that you have to either replace your downpipe or gut it, and gut the passenger side as well.
    Then you have to get to the route of the misfire on cylinder 3.
    The moral of this story, is if you don't take care of your possessions, they will drain your wallet. Why would think driving around with a misfire would be ok?
    2001.5 Audi S4 6spd ASP Stg 3 Imola
    IG: dr.yellowbird
    Senior Member Two Rings BlakMarketKlash's Avatar
    Apr 18 2009
    00 S4 ,350 SIERRA, 98 GTI
    Calgary
    usually when rotten egg smell comes, its a bad egr. my .02
    EDIT
    and or burning cat.
    Veteran Member Four Rings P0234's Avatar
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    Holy cow, this is a new problem, I bet there aren't any threads on how to resolve these issues.....
    Veteran Member Three Rings tosh2.7's Avatar
    Sep 12 2009
    Nogaro stg 3- 00' S4(dead but being rebuilt), Silver stg 3 00 S4 GF 2010 civic
    new york
    Quote Originally Posted by 1sadavant View Post
    Yes, when you misfire, you are dumping more fuel (this is not good...) this is what killed your cat on your passenger side (Bank 2, B2), So now you have to replace both the primary and secondary O2 sensors on the passenger side. On top of that you have to either replace your downpipe or gut it, and gut the driver's side as well.
    Bank 2 is actually the driver side(cylinders 4-6). Misfiring codes can cause catalyst/o2 sensor faults do to the raw fuel being dumped into the cats(egg smell). Like mholme said check your misfire counter and see if all your cy. are firing. check spark plugs coils broken, etc related to spark. Also do you have a tune?
    Vast tested. Driver approved
    BUY my BBS REs
    tosh2_7 on instagram: Get at me
    -RAY-
    Jun 21 2005
    '01.5 S4 & '05.5 M3
    Murrysville, PA
    yes, corrected.
    IG: dr.yellowbird
    Veteran Member Three Rings ski&drive's Avatar
    Feb 22 2010
    00 S4
    Metrowest Boston
    Ive seen rear o2 codes before because of misfiring due to a bad coil. Dont assume your cats are clogged without diagnosing.
    1. Log 015 and 016 to see what cylinders are misfiring
    2. Swap coils at misfiring cyl and change out plugs
    3. Swap ICM's
    4. Log 115 egt's the magic number is 945
    Jan 01 2011
    Nor cal
    Thank you to the people that are being helpful! .I logged misfires and cyl 5 was getting around +/- 10 a second at idle. I swapped the icms right after that. I put the one closer to the front of the car with the orange plugs, to the back position. Went back and logged misfires and now the misfires were at cyl 2! Same amount around 10 a sec. So this means its one of the Icms correct? If so which one controls cylinders 1-3? Btw car is stock, no tune
    Jan 29 2007
    08 S4 00 S4
    MD
    The driver side ICM is bad, cyl 4-6. They are the ones with the brown harnesses. Passenger side is the black harnesses, cyl 1-3.
    08 S4- Stock SOLD
    Jan 01 2011
    Nor cal
    ^Awesome thanks bud. Ill take care of that and see how it goes.
    Jan 01 2011
    Nor cal
    Was able to pick up an icm for 70 bucks! Car runs amazing better than before, no 02 codes. I also logged the misfires and did some wot runs and had NO misfires. Pretty happy haha
    Feb 22 2010
    00 S4
    Metrowest Boston
    Its a good feeling. One of mine actually went bad saturday night, ended up having to go to the dealer this morning to pick it up. 180 bucks but i got my old employee pricing so i was pretty happy.
    Sep 12 2009
    new york
    sweet
    BUY my BBS REs
    -RAY-
    Apr 18 2009
    Calgary
    Quote Originally Posted by ski&drive View Post
    big ups! for having a black 00 s4 and a k1500 just like me, hahaha
    Veteran Member Three Rings spokismB5S4's Avatar
    Jun 06 2009
    01.5 S4 6mt, 03 RS6, 91 coupe quattro, 12 STI, 02 S6 01E, 97 328is w/6266, 87 325is, 86 325e
    thanks for letting us know how you resolved it. Lots of people do not do that and then the thread is worthless info that you have to look through when u need to find some info through the search function. +1 imaginary rep lol.
    Anchor Audi Technician
    DM Technik Tuned BB 2001.5 S4 6mt ** ER's, Rostens, Frankenturbos, Tubi Mani's...
    Ben Swann Tuned Black 1990 200 Turbo avant 5mt ** Turbo-xs Bov, Cherrybomb, Catless...
