Results 1 to 9 of 9
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Emissions Testing in Phoenix, Arizona - Advice / Guidance / Tips?
    Anyone have any experience getting emissions tested in Phoenix or Tucson, AZ?
    Let's just say "theoretically" a "friend" of mine has a test pipe (e.g. no catalytic converter) and an after market exhaust on his 2006 Audi A4 2.0T. He has heard from some people that for the emissions test they just look to see if you have a Check Engine Light or not, then let you on your merry way if there is no CEL...other people have told him they actually monitor emissions from your tail pipe through a sensor, in which case my "friend" is probably screwed.
    Anyone have any advice? Are there certain testing stations more lax than others? Any ways around needing to get the test done? Should he just try to pass it as-is, then re-install his OEM catalytic converter if he can't pass? Are there any negative consequences to failing it and then re-testing and passing it? Removing the test pipe is a major PITA and he'd probably need a shop to do it, so it would be a bit of a pain both monetarily and time-wise to go this route...
    Thanks in advance fellow AZers from AZ...
    Current: 08 R8 6MT, 14 Cayenne GTS, 98 Saleen XP8
    Past: B7 RS4, '12 Audi TTRS BT Build | 2006 Audi S4 HPDE Build | 2006 Audi A4
    Visit my blog: NicksCarBlog.com
    Jul 22 2008
    1993 S4/1985 300TD/1984 380SL/1975 R60/6/alphanumeric soup...
    Phoenix
    1996 and newer, they plug in with scanner and see that 1- no fault codes stored 2- readiness tests pass.
    If the software on this A4 is written to achieve that- it will pass. If not, it won't; having never owned a vehicle subject to this, I don't know if the visual evidence of the catalyst being absent will raise a red flag, or if the inspectors are instructed to adhere to the electronic evidence of "no faults"- I suspect the latter.
    Really no negative consequences to failing, changing something (wink), then passing. Apart from $ and hassle.
    I'd say VAG-COM it and verify that there are no codes and that readiness is set. If so; go ahead and run the test!
    Established Member Two Rings Snooter's Avatar
    Oct 05 2010
    Farmington, CT
    When I bought my A4 in October I had to get emissions on it. I have a stock cat but I don't seem to remember them even looking to see if I had one. Like Type44 said, they just plugged in and looked for fault codes. I was in and out, in under two minutes including paperwork. No downside to failing, except the money.
    Veteran Member Three Rings mrbogangles's Avatar
    Apr 06 2008
    ;p
    phoenix az, bay area
    I just got mine tested, plugged in no cel your on your way.
    They check your vin and the gas cap and thats it.
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Quote Originally Posted by Type44 View Post
    Exactly what I needed to know - thanks. I have the APR Stage 2 tune which cancels any warnings related with test pipes and O2 sensors, and I've VAG-COM'd my car and don't have any warnings or error outputs related to emissions. If they only scan the computer, then I should be all set :)
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Quote Originally Posted by nnnick View Post
    Yep, you'll pass. I had a car once that I literally cleared all codes prior to pulling forward, passed, and then had the CEL come on again as I was leaving.
    Established Member Four Rings matt@oCarbon's Avatar
    Oct 19 2004
    Glendale, AZ
    I think you mean your friend will be all set.
    Established Member Two Rings EuroJunkey's Avatar
    Aug 25 2009
    06 VW GLI 00 S4 (RIP)01.5 PASSAT V6 (Gone but not forgotten) 05 Nissan Sentra Spec-V (RIP)
    Phoenix, AZ
    Emmisions is a joke here. Its more like a drive through at burger king. My s4 passed recently and it had smoke coming from the exhaust.
    Jun 19 2011
    San Antonia, Texas, USA
    Quote Originally Posted by mrbogangles View Post
    That is nice. Thanks for the information. I really like it. :D
