Results 1 to 7 of 7
    Mar 18 2010
    Suzuki GSX-R 600
    Virginia Beach
    getting error codes P1071
    hey all, i just recently came off a 7 month deployment and had my car put in storage for the time being. i haven't done anything as far as a tune up yet but i just got error code p1071 on my check engine. any tips or help you can give me before i start spending money. i have a 2004 A4 1.8T B6........any help will do, thanks in advance
    Jun 30 2008
    Erie, Pennsylvania
    Are you sure it isn't P0171?
    Veteran Member Three Rings A4.Rob's Avatar
    Sep 02 2009
    Toronto, Ontario
    yeah i second that. p1071 isnt a code
    Mar 18 2010
    Suzuki GSX-R 600
    Virginia Beach
    yeah, it's P1071.....i googled it and it said something like system lean bank
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    Weird code but this is what I found :
    http://www.resettools.com/audi_vw_dtc_codes
    P1071 Nitrogen oxides (NOX) sensor - heater control - incorrect signal
    Interesting because after searching the net, I also read that it can be either having to do with plugs(Which coincides with the fact that the car was stored for so long), or an exhaust leak, even though the code would be different.
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by bobbyvee20 View Post
    You are being a little confusing with this answer.
    Which is it?
    P0171
    P1071
    The first one is "Fuel Trim,Bank1 System too Lean". That code is almost always caused by a faulty or dirty Mass AirFlow sensor. The second is not a documented Audi code. 1.8T does not have a NOX sensor.
    Feb 09 2012
    stamford,ct,usa
    i have an 03 a4 1.8t and am also getting p1071 just replaced the mass air meter and am still getting a cel for p1071. thanks
    ~BR
