Results 1 to 40 of 48
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    Jerky Throttle After Reflash
    I noticed after my APR reflash, my car has been very jerky when I go light on the throttle during rush hour traffic.
    I would be traveling at around 10mph/16km/h and the tach is around 1,000 - 1,500 rpm, I let go of the throttle and the car jerks back and forth.
    Transmission shifts are fine, but its only when I let go of the throttle at low revs (in the same gear) that it jerks around; it feels as if something is disengaging really roughly. This doesn't happen over 1,800rpm or over certain speeds though.
    Did the reflash caused this or is there something wrong with my transmission?
    2010 A4 quattro, Tiptronic, Ibis White
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    have you done a VCDS scan lately?
    Jul 12 2010
    Q5 3.0T
    i did one a week after my flash. um cleared all the codes, everything was fine. i will do one tmr
    Jan 09 2011
    ottumwa, iowa
    Mine is kind of like that in a way. just got my apr installed a few days ago. at a bout 3k it really hits hard now.
    Dec 16 2010
    Salt Lake City
    I am having the same problem. It is hard to describe but it isn't turbo boost...maybe it's a tranny issue or something. I had the APR tune done over a year ago and the issue just started about a week ago.
    Jul 12 2010
    Q5 3.0T
    I am relieved to know that I am not the only one experiencing this out there with the reflash. Phil, i know yours is a manual, so it doesn't affect you at all.
    Mar 02 2007
    Fresno, CA
    Just a thought, but if you guys have the stock program installed as well, switch to it and see if it has something to do with the APR map or your transmission.
    Jul 12 2010
    Q5 3.0T
    was planning to do that tmr, i did not get a chance to drive at all today
    Aug 10 2009
    yep, same thing here... it starts to jerk a bit around 1.4k–1.6k rpm, but I am getting used to it. In stock mode – all good.
    Aug 10 2009
    Dec 18 2009
    2015 Jeep Wrangler JKU
    Atlanta, GA
    There was a TSB for this. APR recommends you update your ECU at the dealer before flashing.
    The other thing you may be feeling is the slight "jerk" as part of the valve lift system changing profiles. You can actually feel this in stock mode too but it is very faint. The extra boost of the software makes it much more noticeable.
    2018 Audi S5 SB - Gotland/Rotor
    Previous Cars █
    2010 Audi A4 2.0TQ 6MT
    2008 Audi TT 2.0T S-Line DSG
    2005 VW Jetta GLI 1.8T 6MT
    Jul 04 2009
    Quote Originally Posted by wyld View Post
    this
    Senior Member Three Rings ms3008's Avatar
    Mar 05 2010
    Quote Originally Posted by ikotua View Post
    Yeah I have that ever since I got the APR flash. Got used to it though...however irritating it may be..
    For me, it happens at low revs and usually in gears 1 or 2.. so getting the ECU flashed back to stock by the dealership and then reflashed by APR would help?
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by ms3008 View Post
    Something to consider for those with '09s is that once the dealer updates the ECU, I think I remember APR saying that re-flash would then have to be done like the '10+ where the ECU has to be removed. No thanks.
    Veteran Member Four Rings ThePiombino's Avatar
    Dec 01 2008
    North JerZ
    I can confirm this.
    09 A4 2.0T Quattro - Tip - Black/Black /// MODS: APR Stage II+ | AWE CB Exhaust | 034 HFC l EC HFIC Pipe | Forge DV Spacer | 3M Di-NOC Carbon Fiber Interior Trim | 3M Chrome Grille Trim | SG Supreme 28 | Debadged | Fly Eyes Kit (f&r) | Needle Sweep | Window/Moonroof control w/Keyfob | Seat Belt Chime Disabled | "Wink" Disabled | Double Unlock "Beep"
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    More power more problems sighs...
    Does the stasis or giac tune experience the same issues?
    -cW
    2023 X3 M40i Alpine White
    Mar 02 2007
    Fresno, CA
    -cW
    FWIW, my car doesn't have the jerky trans (yet?) after APR flash. I drive only in S or manual shift, if that makes a difference.
    Mar 05 2010
    oh I didn't know that. Yeah that's not good then. Thanks for the update!
    really? Let me try this to see if it makes any difference...but driving in S all the time? Wouldn't your mileage drop? I'll still give it a try anyways.
    Jul 12 2010
    Q5 3.0T
    I tried both S and manual, didnt make a difference as long as its in low revs
    Senior Member Three Rings Pip's Avatar
    Aug 31 2010
    Singapore
    Maybe wait a couple more days (with lots of driving) for the ECU to get adjusted ? Just a thought :)
    Jul 12 2010
    Q5 3.0T
    I drove to work this morning back in stock mode and the jerking was significantly reduced. However it is still present when i feather the throttle, but not when i release it.
    Jul 25 2009
    I remember reading that too. so +1
    Oct 01 2007
    Chicago
    I'm having the same exact issue as described with my modded 2010 Audi A5
    http://www.audizine.com/forum/showth...e-accelerating
    Jan 06 2011
    NC
    If this is related to the transmission as someone earlier guessed, then I would assume people with manuals don't have this issue? Can anyone confirm?
    Oct 01 2007
    Chicago
    I have 2010 A5 manual
    Veteran Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    Either I didn't feel this, or I don't have it. But I never felt any more jerkiness in the throttle response before/after APR.
    Are you guys talking about the slight dip in power as it gets moving around 1-2?
    Ryan - flickr
    Oct 01 2007
    Chicago
    Mine feels like it's almost choking when I'm accelerating. I can here the whistling of the turbo, but it doesn't sound as one whole whistle, it gives a like 3 little whistles almost like it's choking. Sorry, but that's the best way I can describe my situation. I can hear it pretty good because I have an intake.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    That's not good. Same thing in stock mode? Or can you not run stock because of the HFC?
    -cW
    Oct 01 2007
    Chicago
    I have not put it in stock mode, I going to take it to a shop to get some diagnostics done on it.
    Jul 12 2010
    Q5 3.0T
    -cW
    I go back into stock mode and the jerking is less noticable but it is clearly still there. I think it might have something to do with the HFC, it also makes my butt/seat rumbly at low revs.
    I also notice that it happens often over low gears (1-2)
    Jul 12 2010
    Q5 3.0T
    Quote Originally Posted by Ryan_T View Post
    ryan,
    try going on the 401 during rush hour, guarantee it will shake your brain out!
    Aug 27 2008
    Houston Area
    If you guys sit at idle in neutral and just barely add pressure to the throttle (try to take 15 sec to smoothly go from 800 rpm to ~1500 rpm) is the rev increase smooth or does it kind of stutter?
    Is it worse when the engine is "cold" but after the warmup high RPM time?
    2013 6MT S5 - Monsoon/Black
    Prem+ | Sport diff | Adaptive dampers | Nav | B&O
    Res AWE exhaust | USP intake | USS Sways | OEM 19" speedline | AluKreuz | 034 Trans mount | Interior LED | VCDS tweaks | F1 tint | Xpel PPF
    Previous : 2009 6MT A4 | Quartz/Black | Prem+ 2001 5MT A4 | Silver/Black | Premium pkg
    Dec 04 2009
    North Jersey
    the ECU stock is supposed to be "adaptive" in that it tries to "learn" your driving style. idk if the apr flash retains this feature, i was actually wondering that earlier, but maybe since they cleared your programming its trying to re-adjust.
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    Quote Originally Posted by dracolnyte View Post
    ryan,
    I've been in rush hour many times...I don't remember getting shaken to the point that I remembered it.
    Ryan - flickr
    Jul 12 2010
    Q5 3.0T
    what do you have on your car?
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    Stg I only.
    You're making me curious. Maybe we should meet up sometime and let me ride in your car.
    Ryan - flickr
    Jul 12 2010
    Q5 3.0T
    Stg I only.
    sure come ride and try it out with me. but i think the problem has something to do with the HFC/stg II
    Jul 07 2009
    Lebanon
    I experience a very similar jerking that you speak of; it is normal!
    I'm guessing you have the S-tronic gearbox - these dual clutch systems react very similar to a MT.
    When you are moving at such low speed as you mention, the clutch is completely intact.
    For those of you who have driven a MT, you would experience the same feeling if you were to speed up to about 10 mph, release your feet from the pedals and let the car slow down independently.
    Nothing to worry about imo
    SOLD: 2010 A5
    Established Member Two Rings kmjmrq's Avatar
    Apr 19 2009
    DFW, TX
    I only had jerky throttle when I had stage I flash, and it was only from 1st to 2nd gear change.. but after HFC and Stage II, that went away. Its very smooth at any level..
    2010 A5 2.0T Meteor Gray. Prestige/S-Line/Driver Assist
    -30% Huper Optik/E-Codes/Exterior&Interior LED's/Hartmann HS5 19"/AWE FMIC/APR ECU Stage II/034 HFC/Eurocode HFIP/AWE Quad Exhaust Black Diamond Tip
    Jul 12 2010
    Q5 3.0T
    Quote Originally Posted by Wah View Post
    no we have the tiptronic which has a torque converter
