So had a new engine dropped in the car. I had the compression checked at 200psi accross the board, we replaced the timing belt, valve cover gaskets, valve tensioner gaskets, and such. Car has no codes popping up. we checked the clutch and it was still in good shape as well as the rest of what we can see. all this was done by a certified mechanic (one of my good friends and kind of the S4 guru in NE Iowa) guy knows his stuff and knows s4's.
heres the problem as he took the car for a second test drive a noise popped up that was intermittant and didn't really change through the revs and nothing in particular brought it on. the sound is not metallic, sounds like plastic. theres no vibrations/clunks or anything in the body, pedals, or clutch. we dont know what it is but he's said if its not gone by the end of next week i gotta go back to driving my jetta, and the car goes back on the lift for no extra charge and have the trans cracked from the engine and see what we can find. I need to know what this might be, and if it will go away and is literally just some stupid plastic.
