Results 1 to 19 of 19
    Senior Member Two Rings ChipsöfSix's Avatar
    Nov 28 2010
    2008 A4 2.0T / 2002 A4 1.8T / 2002 Passat b5.5 1.8T
    Guelph, Ontario, Canada
    Cell P0011 "A camshaft position (bank 1) timing over advanced"
    So i got this yesterday when i was going to work.
    Went to work got the code reader from the guy I work with , cleared the code drove home didnt get it, went to go out again last night got it again, cleared it and then got it one more time cleared it. Now it hasnt came back yet.
    From what I can see mostly B5 and B6 guys have this issue with there 1.8Ts havent saw anyone with a B7 yet.
    What im I've read and need to look into is :
    Timing belt jumped a tooth.
    My question(s):
    Could it be something else?
    Now the car isnt running like shit and dosent sound horrid or anything...So i dontthink it has jumped a tooth. Im going to pull the car into the garage and bring the engine to TDC and see if everything matches up.
    Veteran Member Three Rings bengtc's Avatar
    Mar 13 2009
    2012 S4
    Dallas
    I had this when my timing belt was off a tooth
    Jan 24 2007
    how many miles on you car? I believe your timing has jumped but try to clear it and go for a ride and see if the cel comes back on to verify it.
    Nov 28 2010
    48 000 miles, so deff not even close to replacing yet. Cleared it and went for another drive it came back, just brought it into the garage gonna let the snow melt off and then see whats up/
    Nov 28 2010
    So after messing with the car for a while found out it was actually caused by low oil presure! Problems all solved now!
    May 08 2009
    Iowa
    I just got this code, how did you fix it?
    Oct 16 2008
    South Florida - Ft Lauderdale
    It is almost impossible for a timing belt to slip a tooth. You can only have this code after an incorrect belt replacement.
    If you did not touch at your belt, this code is triggered by something else
    Phil
    Established Member Two Rings Provistic's Avatar
    Apr 16 2010
    Waco, Texas
    Quote Originally Posted by ChipsöfSix View Post
    I currently have this code, how did you take care of the low oil preassure?
    Thanks
    Oct 06 2008
    San Diego
    I am getting this code now. Interested in knowing how you resolved your low oil pressure. Dirty oil filter?
    Veteran Member Four Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by audiglenn View Post
    Unlikely. Probably the result of a bad cam chain tensioner. If the plastic guides are missing/broke. they can potentially clog your oil pickup. Won’t necessarily cause an oil pressure light, but can restrict flow enough to cause problems with the VVT system.
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by a4lownslow View Post
    Feb 15 2016
    Cambridge,Ontario
    If i was getting that code id shut her down till its fixed. Could be minor like n205 or broken timing control rings. But it could also be impending doom if that tensioner lets go
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Oct 06 2008
    San Diego
    Quote Originally Posted by bengtc View Post
    How did you adjust your timing belt? I tried moving the exhaust cam back one tooth and the vehicle wouldn't start. Which way did you move your exhaust cam?
    Apr 19 2020
    NW Indiana
    I'm confused to what the fix was for you guys with this code/ oil pressure issues. I've had a cam follower fail, replaced cams, timing chain, tensioners etc. As well as removed all the metal debris, pulled oil pan, replaced pickup tube etc. I'm still have this same issue.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Ksimsb91 View Post
    i would suggest starting a new thread with what your exact issues are with as much detail as possible. There is many details that must be looked at before an accurate suggestion can be made. Anything else is people just guessing blindly.
    1976 Yamaha XS 360
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    it could be N205 valve failure or exhause cam sprocket installed incorrectly.
    Junior Member One Ring
    Jan 30 2021
    Minneapolis Minnesota
    Can you specify on how exactly the exhaust cam sprocket can be installed incorrectly? There is a little keeper/insert that ensures there’s only one way it can go on.. right?
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by 06AudiA4Quattro View Post
    Yes, it has a keyway. This thread is also 5+ years old, and that dude was a bit "special"..
    Have seen those keyways break before though. That's why it's good to inspect everything when doing a cam chain service. Some people remove cam cradle, but can't go over everything.
    Sent from my CPH2611 using Audizine Forum mobile app
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Jayz691 View Post
    lol yeah special sums it up pretty good.. usually the cam stays on the sprocket so its good , its just the timing chain is bit tricky on the sprocket. i had a thread somewhere on this. look for " that's all she wrote" in a search
    1976 Yamaha XS 360
