Originally Posted by
B6JoeS4
forgot about the ABS/EBD/ESP system. I dont think that will be an issue when you think about people doing bbk upgrades all the time without ABS modifications
I dont think BBK's really affect ABS that much, but in my opinion it could noticeably affect ESP performance (when an ESP event occurs and the driver is not on the brakes at all). The pre-charge motor and dump/isolation valves are programmed/expecting to fill a certain size piston and pre-charge the system to a specific pressure in order to brake a certain wheel just enough to put it into slip before releasing brake pressure...if the caliper bites harder with more or less force than the ABS/ESP module is expecting it might make it slightly less effective.
Even tire size can throw it off for obvious reasons. When I went from 245/75/16 (stock) to 285/70/17 tires and EBC pads/dimpled/slotted rotors on my truck the ABS was noticeably less effective until I reprogrammed (recoded if you will) the EBCM to the correct tire size. The EBD (GM calls it DRP, dynamic rear proportioning) on my truck was all sorts of whacked out as well and the rears would lockup way before the ABS would even intervene. In 2009 when they made ESP (stabilitrak) standard on the GM heavy-duty trucks, guys changing tire sizes and brakes started to notice odd things happening during stabilitrak "events"...thats probably just the difference in the way a car vs. truck ESP system works though.
Im not saying its going to make it so the car "wont stop" or will go totally out of control...im just saying that any time you change something significant in the caliper or master cylinder setup on a vehicle with ESP it can "theoretically" make it less effective....
