Results 1 to 8 of 8
    Sep 28 2009
    suburb
    is 2 degree off for camber bad?
    I am picking up car lowered with kW coil over. Audi says less 2 degree off camber in front. Is this gonna cause bad tire wear? Is it worth it to get stern camber kit? Or will jjust more tire rotations be sufficient? He says rear is factory speç. Thanks
    Aug 17 2009
    Pittsburgh
    2 degrees is very bad. rotating tires will just cause you to have 4 bad tires rather than 1. get an alignment. if it can't be aligned, get a camber kit.
    Sep 28 2009
    suburb
    Oops I meant .7 degree. Is that bad?
    Sep 28 2009
    suburb
    ok some more info:
    the copy of the alignment shows specified range for front is -1.36 to -0.5
    my left after is -2.06 ( so -.7 off) and right is -1.59 (-.2 off).
    caster and toe are within specifications. rear has everything within specs.
    this was done at audi dealer.
    May 16 2009
    Maine aka Canada Jr.
    no you're fine... i got my car aligned with me in the car and came within very similar tolerances... you wont see excessive wear at -2 degrees
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    Quote Originally Posted by hercfe View Post
    you obviously aren't speaking from experience so be quiet.
    just run 0 toe and you will be fine.
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    Quote Originally Posted by chrissurfr View Post
    x2. i run -2.1 all around.. no excessive wear.
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Mar 02 2007
    Fresno, CA
    I'm also at ~2 all around with no excessive (though slight) inner tire wear. Swap front and rears at every oil change and you'll be even better off.
