Page 26 of 60 FirstFirst ... 16242526272836 ... LastLast
Results 1,001 to 1,040 of 2386
  1. #1001
    Veteran Member Four Rings audi_s5's Avatar
    Jan 04 2009
    WI, USA
    Quote Originally Posted by rlarsen View Post
    Isn't the old value to find in the log file in "C:\Ross-Tech\VCDS\Logs\" or "C:\Ross-Tech\VCDS\Debug\" ??
    Thanks Renee for the reminder - it was 0
  2. #1002
    Senior Member Three Rings 11move's Avatar
    Nov 25 2007
    Has anyone been able to change their lane change signal light from 3 to say 4? I find that 3 is just not long enough and when I double tap the signal light 6 is a little much.
  3. #1003
    Aug 13 2014
    Glen Burnie MD
    so just got the cable and I know that I want to disable the turning signal blink thing, and I want my windows to all roll down by using the key fob. is there anything else a you would recommend for an Audi noob? I ask because I don't understand what a lot of the things in the list mean.
    I have a 2013 Audi S4 prestige fully loaded bla bla bla so any recommendations, and please explain what they do if they aren't obvious.
  4. #1004
    Nov 25 2007
    Quote Originally Posted by DRTHVDR View Post
    Read the first page most of it is there with explenations and how to do it.
  5. #1005
    Aug 13 2014
    Glen Burnie MD
    I have read most of it, thanks for the info though!
    guess what I am most confused about, since i haven't hooked up to the car/computer yet, is which actually would apply to my s4 opposed to like an earlier model. I'll figure it out though either way, thanks again.
  6. #1006
    Nov 25 2007
    It should all apply to your vehicle, none of it was removed if anything a few other options may have been added, which I doubt at this point.
  7. #1007
    Aug 13 2014
    Glen Burnie MD
    awesome thanks again
  8. #1008
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Their are some that don't work but only like 1 or 2. But most all of them work on the B8.5 S4. I did most of them to mine. You have to do a few other steps to some if you have MMI which i believe you have. Most of them are straight forward. And if your computer savvy and can catch on fairly easy you will see and learn VCDS quickly. Some things a little tricky like the green menu for the MMI with the button presses. But if you need any help I'm like 5 min away from you. I can always help you out. Do you have a ross-tech cable ?
  9. #1009
    Aug 13 2014
    Glen Burnie MD
    Yes I have Ross tech that I borrowed from a fellow marine that no longer has an s4 and lives rather far away. Would you be down to get together soon?
  10. #1010
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    I got anal because the list didn't have everything listed by module type, so you were constantly going back and forth to modules if you checked off the list. I ordered it:
    Audi A4/S4/A5/S5 B8
    VCDS (VAG-COM) codes
    MMI Reset
    5F [Information Electr]
    Enable Hidden menu in MMI
    Disable NAV & Phone warning messages while entering data at speed
    Enable Auxiliary ventilation
    Activate SDS for cabriolet
    Enable Video in Motion on MMI
    6C [Back-up Cam]
    Adjust Back-up Camera Picture
    09 [Cent. Elect]
    Disable After-wipe of windscreen wipers
    Disable amber corner lights
    Disable LED 'wink' on turn signal - pre-facelift
    Disable LED 'wink' on turn signal – facelift
    Adjust LED Brightness
    Dim LED 'wink' on turn signal
    Enable DRL Selectable via MMI
    Enable DRL
    Disable "Lights are on" warning
    Enable Euro parking lights that turn on signal at night
    Enable fog lamp to come on for the same side as that turn signal
    Enable Front Turn Signals as Parking lights
    Enable Headlights on all the time
    Enable Independent Fogs control with high beams
    Enable Rear Tail Lights on with DRLs
    Enable ‘Tourist’ Mode – Headlight Convertor (MMI 2G)
    Set Custom ADS settings
    Set Headlight washer - duration
    Set Headlight washer – cycles
    Enable interior lighting option
    46 [Central Conv]
    Disable bulb error message with LED reverse lights installed
    Disable Key warning (keyless models)
    Enable Adaptive brake lights
    Enable Double Disarm Beep
    Enable Remote Operation windows&sunroof
    Enable Horn confirmation on locking
    17 [Instruments]
    Disable Seatbelt Chime
    Enable DIS with Efficiency Program
    Enable Gauge Test/Needle Sweep
    Enable Lap Timer
    Adjust Consumption in DIS
    Change Language
    Change fuel tank characteristics
    A9 [Structure Borne Sound]
    Disable soundaktuator (speaker on face lifts)
    10 [Park Steer/Assist]
    Enable Optic rear parking for cars without front parking sensors
    Set Audi parking system - Switch OFF Speed
    02 [Auto Trans]
    Enable Automatic Gear selection shown in DIS
    56 [Radio]
    Enable Battery meter *does not appear to work on facelift cars with MMI 3G+ HDD Navigation*
    Enable Speed on chorus, concert or symphony display
    36 [Seat Memory]
    Enable Drivers Memory Seat
    53 [Parking Brake]
    Enable Release Parking Brake without putting foot on Brake
    Enable Release Parking Brake without putting seatbelt
    52 [Door Elect, Pass]
    Enable Reverse mirror tilt
    Hidden Menu
    Adjust bluetooth microphone sensitivity
    Change MMI 3G splashscreen
    Enable Import CDs to MMI's HD
    To increase radio play time after car is turned off
    Enable Ambient Interior Lighting Control
    Others that require additional information
    Enable Automatic Hill Hold Assist 'lite'
    Enable Audi Drive Select without the buttons
    Enable TPMS (Tire Pressure Monitoring System)
    ________________________________________
    MMI Reset
    2g, 3g Setup, center, top right
    3g+ Menu, center, top right
    Enable Hidden menu in MMI 3G
    [5F - Information Electr.]
    [Adaptation - 10] -> Channel 6
    change 0 to 1
    To access the hidden menu, hold down car and setup together for 5 seconds
    Use this hidden menu at your own risk.
    Enable Hidden menu in MMI 2G
    [07 - Control Head]
    [Adaptation - 10] -> Channel 8 -> Change 0 to 1
    Use this hidden menu at your own risk. Caution: Keep away from the "Bootloader"
    [5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
    [5F - Information Electr.] [Coding - 07] -> Long Coding Helper -> Byte 6
    Bit 1 – Set to 1
    [Hidden menu] [car] [cardevicelist] [Auxiliary heating] Enable
    [08 - Auto HVAC] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 3 – Set to 1
    Bit 4 – Set to 1
    Activate SDS for cabriolet:
    5F–Information Electr.
    Change Byte 15 – Bit 0 to 1
    Change Byte 16 – Bit 0 to 0
    Enable Video in motion on MMI
    [5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
    [Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
    [Adaptation - 10] -> Channel 48
    Set to 255
    Reset MMI
    [6C-Back-up Cam.] [Security Access - 16] (enter security code 22351)
    [Adaptation - 10]
    Channel 10 (Brightness)
    Default: 50 (Set between 1-100)
    Channel 11 (Contrast)
    Channel 12 (Saturation)
    Channel 13 (Temperature)
    [09 – Cent. Elect.] [Coding - 07] -> [Dropdown] -> "x ** 8K1 955 119 ** WWS xxxx" -> Long Coding Helper -> Byte 1
    Bit 3 - Remove check mark (1 = active)
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
    Submodule 0
    Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles )
    Disable LED 'wink' on turn signal - pre facelift
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3
    Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
    Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
    Disable LED 'wink' on turn signal - facelift
    09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
    [Adaptation - 10] -> Channel 3 (Heading Wink Brightness)
    Default Value is 26, Setting value to 88 (Makes it identical to normal brightness)
    Adjust LED brightness
    [09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
    [Adaptation - 10] -> Channel 03
    Set between 5 and 100 (5 being lowest and 100 brightest)
    Dim LED wink on turn signal for US cars
    Instead of complete wink off, there is another mod that comes as stock in Europe. There is an LED dim instead of wink.
    Starting with factory setting:
    Central Electronics 09 -> Coding 07 ->Long Code helper
    Byte 02 - Check bit 6 (Side Marker as DRL)
    If you have already eliminated the winking, the you will need to go to Byte 03 and undo the modification. In other words, the winking DRL options (Bit 7) will need to remain checked/on as it was in the factory setting.
    [09 – Cent. Elect.] -> [Coding – 07] -> Long Coding Helper -> Byte 3
    Bit 5 set to 1
    Enable DRL
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
    Bit 1 = DRL via Front Side markers
    Bit 2 = DRL via High Beams
    Bit 3 = DRL via Fogs
    Bit 4 = DRL via LEDs
    Bit 6 = DRL via Side markers
    Bit 7 = DRL via Tail lights
    Disable "Lights are on" Warning
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 5
    Bit 3 - Set to 0 to disable "lights are on" warning when you open the door.
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9
    Bit 0 - Set to 1
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
    Bit 0 - Check the box or change :Bit 0 set to 1
    Bit 0- Check the box or change :Bit 0 to 1
    Once the change has been made you can enable the front turn signals as DRL's by making the following change:
    Bit 6 - Check the box or change :Bit 0 set to 1
    Bit 5 - Check the box or change (Bit 5 Set to 1)
    Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
    Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
    Bit 7 - DRL's via Tail Lets Active (1 = Active)
    [09-Central Elect] [Coding – 07] [Long Coding Helper] - Byte 4, Bit 6 = 1
    Enables the 'connection' between Cent. Elect and the Headlight Convertor MMI menu item
    [55-Xenon Range]
    [Adaptation – 10]
    [Channel 10] - 0 = Disable 1 = Enable
    Press ‘Test’ and then ‘Save’
    Enables the Headlight Convertor MMI item under the CAR button.
    Restart MMI to see changes.
    Set ADS to specific preset Comfort, Auto, Dynamic or Individual
    [09 – Cent. Elect.][Security Access - 16]
    [Adaptation - 10] -> Channel 63
    Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual
    [Adaptation - 10] -> Channel 64
    [Adaptation - 10] -> Channel 65
    [Adaptation - 10] -> Channel 66
    *Note all four channels needs to be set to the same value.
    Set Headlight washer - Duration
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 6
    change to e.g. 500
    Set Headlight washer - Cycles
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 26
    change to e.g. 10
    Enable interior lighting for facelift cars
    [09 – Cent. Elect.] [Coding - 07] -> [Long Coding Helper] -> Byte 16
    Bit 6 - Interior/Ambience Lighting Adaptation active
    Hidden Menu > car > carbusassignment > Interior Light > change from 9 to 1
    Enable interior lighting option for pre-facelift
    MMI Basic (Symphony/Concert radio) - (NON-MMI - 2G/3G):
    Code:
    [56 - Radio]
    [Coding - 07] -> Long Coding Helper -> Byte 8 Bit 7 - Interior Light Settings active - (1 = active)
    MMI high (2G):
    Code: Enable the Interior lighting (extended) MMI item:
    [07 - Control Head]
    [Adaptation - 10] -> Channel 1 add 2 to the existing value
    MMI high (2G hidden menu as alternative)
    If you choose to use the 2G hidden menu you will find the setting using the following:
    DIAG SETTINGS -> APK 0x01, 0x0B, 0x0C -> Interior lighting (extended)
    MMI 3G and MMI3G+
    This can only be activated through hidden menu
    Enter hidden menu - choose car - choose carmenuoperation - select interior light - set to 5 to allow adjustment whist moving - press return - select cardevicelist - choose interior light and press to fill box in - press return
    *at this point 3G owners do step below, 3G+ go to (3G+ only) below
    (3G only) Reset MMI (press setup, scroll wheel and top right button next to scroll wheel at the same time)
    (3G only) Option will show in MMI
    (3G only) [09 – Cent. Elect.]
    [Coding - 07] - Long Coding Helper -Byte 16 Bit 6 - Set this bit manually to 1
    (3G+ only)
    Facelift needs an extra setting to activate the option.
    Hidden Menu > car > carbusassignment > Interior Light > change from 9 to 1.
    Reset MMI
    Steps:
    1. Module 46 Central Convenience > Security Access 16 > 16017 (use this access code, not the one the ross-tech suggests)
    2. Adaption 10 > Channel 181 >Read
    The value you get is 65535 (at least that was mine). When you convert that to decimal it comes out to 1111111111111111. Bits 8,9,10,11 code for the reverse lights (1111RLRL11111111) so when you convert them it becomes 1111000011111111. Convert that back to binary and it becomes 61695
    3. Enter 61695, hit test then save. Done.
    [46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9
    Bit 7 set to 0 (Uncheck)
    [46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
    Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
    Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
    [46 - Central Conv.] [Adaptation - 10] -> Channel 63
    Add 4
    ensure Module 46, Byte 1, Bit 2 is ticked. This activates the alarm audible notification option
    Enable Remote Operation Windows and Sunroof
    [46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
    Bit 2 - Set to 1
    [46 – Cent. Convenience.] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 2 - Check the box or change (Bit 2 Set to 1)
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
    Bit 2-4 – Seat Belt Warning
    Enable DIS with Efficiency Program for MY2010+ (Not a complete Program without the Start/Stop System)
    [17 - Instruments] [Adaptation - 10] -> Channel 77
    change 0 to 255
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 0 - Check the box for "Gauge Test/Needle Sweep active"
    Enable Lap Timer
    Bit 3 - Check the box for "Lap Timer active"
    [17 - Instruments]
    change 100 to xxx (see samples below)
    Sample 1 - Calculation based on volume per distance (e.g. l/100km):
    DIS: 9,3 l/100 km.
    Real: 9,8 l/100 km. (100 * 9,8 / 9,3 = 105,38)
    Channel 3 will be changed from 100 to 105
    Sample 2 - Calculation based on distance per volume (e.g. MPG):
    DIS: 23 MPG.
    Real: 24 MPG. (100 * 23 / 24 = 95,83)
    Channel 3 will be changed from 100 to 96
    Select language in DIS:
    17 - Instruments
    Byte 8 -> Bit 0-4 - ->
    Select the language.
    Change fuel-tank charasterics:
    17 - Instruments
    Adaption - change channels 30 and 33
    To mute the Soundaktuator
    Adaptation 10
    At Channel drop down choose "Volume of structure borne noise actuator" (only choice)
    Enter a value in the proper box (0% = mute )
    Enable Optical rear parking for cars without front parking sensors
    [10 - Park/Steer Assist] [16 - Security Access - 71679] do it [07 - Coding] Byte 0 - Bit 4 change 0 to 1
    [10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
    Set to 20 (max value in km/h)
    [02 – Auto Trans] [Adaptation – 10]
    Select “Single Gear Display” from top channel drop down menu
    Select “D on/S on” from New value drop down menu
    For MMI equipped cars
    [Hidden menu] [car] [cardevextdevicelist] [Battery] Enable
    [Hidden menu] [car] [carmenuoperation] [Battery] Set to 5
    Reset MMI
    or
    [56 - Radio] -> Adaption -> Channel 39, add 16 to your value
    For symphony, Chorus and Concert
    Select module 56 - Radio
    Select “Adaptation – 10
    Select channel 39
    Add 16 to the present value
    "test"
    "save"
    “Done, Go Back” and "Close Controller
    [56 - Radio] ->Adaptation - 10
    Channel 2 --> change 0 into 1 (driving school mode active).
    New menu item: Under Radio Setup "ON/OFF" driving school mode.
    36: [Seat Mem] - 07 Coding - Long Coding Helper - change Byte 2, bit 0, to 1
    Seat memory will be there however greyed out in MMI
    Press and hold down unlock button on key fob for 5 seconds for the windows to come down
    Press and hold down lock button on key fob for 5 seconds for the windows to go back up
    In MMI, Seat Adjustment you are now able to find Driver's seat, you can set Key memory on/off. Set it "on" for both keys separately.
    [53 - Parking Brake][Security Access - 16] (Enter code presented by program)
    [Adaptation - 10] -> Channel 4 Set to 0
    [Adaptation - 10] -> Channel 7 Set to 0
    [52 Door Elect, Pass.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 4
    Bit 3 and Bit 2 set to 1
    Hidden menu
    Diagnose
    Settings
    Mic sensiblity - choose -6db/0db/+6db
    Change MMI 3G splashscreen...
    Enable through the "hidden menu":
    - navigate to 'car/carcodingvehicle'
    - choose the model of choice in 'configuration line'
    - select 'Update Splashscreen'
    - restart MMI
    Main/Diagnose/Settings
    Import Media
    Set to 4 of 4 "Copy/Ripping"
    To increase radio play time after car is turned off:
    In the Hidden Menu:
    MMI 2G:
    "MMI->SETTINGS->Standby Timer" - will allow you to hear e.g. Radio or CD longer before MMI shutdown (if ignition is OFF) - default 10 min. and the max. is 60 min.
    MMI 3G:
    From the main screen select 'onofftimer', set 'Standby delay'. The maximum value is 30 minutes
    [Hidden menu] [car] [carmenuoperation][interior light] Set to 5
    [Hidden menu] [car][cardevicelist] [interior light] Enable
    Reset MMI
    Enable Automatic Hill Hold Assist ‘lite’*only works on certain abs modules - see below link*
    [03 - ABS brakes][Security Access - 16] (Enter code presented by program)
    [Coding – 07] -> Long Coding Helper -> Byte 1
    Bit 6 set to 1 to enable hill hold assist.
    http://www.audienthusiasts.com/VagComABS.html
    By far the best guide is here - http://www.audienthusiasts.com/Project_ADS.html
    Enable TPMS
    * only works with certain ABS modules - see below link *
    There are 10 kinds of people in this world, those who know binary and those who don't.
  11. #1011
    Jan 14 2009
    pasadena md
    Yea shouldn't be a problem. Im actually out of town right now for a wedding but will be back monday. So Just shoot me a pm and we can figure something out. I have to go to apple the following weekend to get my battery replaced in my iPhone.
  12. #1012
    Veteran Member Three Rings 13ttaz's Avatar
    Apr 29 2013
    Arizona
    Quote Originally Posted by infinkc View Post
    Audi A4/S4/A5/S5 B8
    MMI Reset
    6C [Back-up Cam]
    09 [Cent. Elect]
    Enable DRL
    46 [Central Conv]
    17 [Instruments]
    Enable Lap Timer
    Change Language
    02 [Auto Trans]
    56 [Radio]
    36 [Seat Memory]
    53 [Parking Brake]
    Hidden Menu
    MMI Reset
    change 0 to 1
    [07 - Control Head]
    Bit 1 – Set to 1
    Bit 3 – Set to 1
    Bit 4 – Set to 1
    Set to 255
    Reset MMI
    [Adaptation - 10]
    Submodule 0
    Bit 5 set to 1
    Enable DRL
    Bit 0 - Set to 1
    [55-Xenon Range]
    [Adaptation – 10]
    [09 – Cent. Elect.]
    change to e.g. 500
    [09 – Cent. Elect.]
    change to e.g. 10
    Code:
    [56 - Radio]
    MMI high (2G):
    [07 - Control Head]
    MMI 3G and MMI3G+
    (3G+ only)
    Reset MMI
    Steps:
    Add 4
    Bit 2 - Set to 1
    change 0 to 255
    Enable Lap Timer
    [17 - Instruments]
    DIS: 9,3 l/100 km.
    DIS: 23 MPG.
    17 - Instruments
    17 - Instruments
    Adaptation 10
    Reset MMI
    or
    Select channel 39
    "test"
    "save"
    Hidden menu
    Diagnose
    Settings
    - restart MMI
    Import Media
    In the Hidden Menu:
    MMI 2G:
    MMI 3G:
    Reset MMI
    Enable TPMS
    That's great, thanks for organizing this.
  13. #1013
    Senior Member Three Rings Audi403's Avatar
    Apr 26 2013
    Audiville
    So to access this I need to buy the license for the VCDS software from Rosstech and also a cable? Which cable works with our B8 S4 and which software is necessary?
  14. #1014
    Jan 14 2009
    pasadena md
    Quote Originally Posted by Audi403 View Post
    You need the Can + Hex usb and the cable has the license in it. It comes with a serial number imbedded in the hardware the software picks up and you are good to go. The software is free you just need a legit cable to use it. The fake cables work but only with legacy software and can't use the updates.
  15. #1015
    Aug 25 2008
    Boston, MA
    i picked up a used 2010 S4 and have a VAGCOM cable on order due to arrive this monday. however, i just realized that the needle sweep is activated, and the wink feature is disabled. just need someone to sanity check my opinion that the prior owner probably made these changes as this is not the stock configuration.
    am i correct in this assumption?
    cant wait to start playing around with the cable! first thing on the list is the 3G+ MMI upgrade!
  16. #1016
    Jan 14 2009
    pasadena md
    yes they are not factory
  17. #1017
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    The Needle Sweep is stock, the other isn't
    Sent from my iPhone 5S using Tapatalk
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
  18. #1018
    Jan 14 2009
    pasadena md
    Quote Originally Posted by stereojorge View Post
    I don't think needle sweep was factory with the B8's it is on the B8.5 Im just going by the Vag com mod list. Its in the list to add the needle sweep. My B8.5 already had it enabled from factory
  19. #1019
    Mar 28 2009
    Minneapolis, MN
    ^^^That
  20. #1020
    Oct 15 2013
    Tampa, Florida
    VCDS & Hidden menu: The complete list
    Gotcha! Mine already had it, weird! Or maybe previous owner did it and was the only mod he did.
  21. #1021
    Senior Member Three Rings ob_1jr's Avatar
    May 05 2012
    Clinton, UT
    Needle sweep was standard on my 2012 (I bought it new)...I think it wasn't before that though.
    2017 SQ5 Premium + | weathertech floor mats | 20% tint
    Sold:2012 S4 Premium + | 6MT | comfort key | supercharged badges | weathertech floor mats | 15% tint | Gunmetal VMR 710 18x9.5 w/ bridgestone potenza RE970AS from PYSpeed| Roc-Euro intake | Alu Kreuz | Eurocode Meisterwerk ASTS | 034Motorsport Transmission Mount Insert | Spulen Rear Differential Mount | ECS GEOMET Slotted and Drilled rotors | Hawk Ceramic pads
  22. #1022
    Senior Member Three Rings sworksone's Avatar
    Oct 11 2009
    Quote Originally Posted by ob_1jr View Post
    It was standard on my 2010.
    2005 TT S-line, Papaya, 3.2, DSG
    Retired 2014 S4 Technik, Glacier, Black Optics, Black/Magma, Sport Diff, DSG
    Retired 2010 S4 Premium, Ibis, Black/Magma, ADS, 6MT
    Retired 2006 A4 S-line, Quartz Grey, 2.0T, 6MT
    Retired 2002 A4 S-line, Brilliant Black, 1.8T, 5MT
  23. #1023
    Jan 14 2009
    pasadena md
    Quote Originally Posted by sworksone View Post
    Maybe it wasn't on the A4. I dunno just stating what i read before. Guess i was wrong ohwell. But the non winking is not factory. I think the winking is weird but i think probably has something to do with lighting laws in the states.
  24. #1024
    Established Member Two Rings pkol666's Avatar
    Aug 27 2014
    so can anyone tell me if theres a way to run the fog lights without the headlights being on?
    Blk B8 S'Fo Sport, Blk S/C Badges, S-Line TDI Bumper, Murdered RS4 Grille/Fog Housings, B8.5 S4 Shifter, RS4 Pedal Set, Ecode Amber Delete Headlights, PIAA Yellows, Vag'd, 15% Tint, Sittin SO Clean On Kw1's w/ 10mm Spacers, Roc Euro Intake +
  25. #1025
    Veteran Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by pkol666 View Post
    As DRL
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 21.9.0 (HEX-V2)
  26. #1026
    Mar 28 2009
    Minneapolis, MN
    Here's how:
    Enable DRL
  27. #1027
    May 05 2012
    Clinton, UT
    do you want to run the with the DRL and fogs only? You just put the switch to the position past auto to the right (parking) and turn on the fog lights.
  28. #1028
    Jan 14 2009
    pasadena md
    I think he wants to control the fog lights independently from the headlights. I know the B5 and B7 you could do that. I think he wants to turn on the fogs with just the drl's on without parking lights on.
  29. #1029
    Oct 15 2013
    Tampa, Florida
    Quote Originally Posted by chaos2984 View Post
    What he wants can be in the B8/8.5, he just has to look at the instructions/list and it's right there. :)
    Enable DRL
    Sent from my iPhone 6 using Tapatalk
  30. #1030
    Jan 14 2009
    pasadena md
    yea but thats just having the fogs come on as drl's not being able to push the fog button and have them come on regardless of headlight switch position. Thats not what he said the way i take it.
  31. #1031
    Feb 03 2013
    Central Pennsylvania
    Does anyone know if it's possible to disable the "anti-stall" feature via VCDS? I haven't read anything indicating this is possible, so I assume the answer is NO, but would like to confirm.
  32. #1032
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Quote Originally Posted by eieiou22 View Post
    I believe thats called keeping the clutch in...
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
  33. #1033
    Aug 27 2014
    PAH! i didn't even think about the fact that they would be considered DRL... but I'm pretty sure thats wha I'm looking for, like the parking brake - LED lights on, fogs on.
    so, thank you everyone for clarifying that for me i jus having trouble processing the DRL thing because at first i was jus thinking that i wanted to run the fogs independently.
  34. #1034
    Oct 15 2013
    Tampa, Florida
    Glad we could help! :)
  35. #1035
    Oct 30 2012
    Oxford, MS
    Quote Originally Posted by S4twister View Post
    Guys, am I retarded or what? I can get through these steps:
    [Adaptation - 10]
    generating and entering security code, which is accepted.. but when I try to select any channels 63-66, all of them are unavailable..
    And yes, this should be a sticky along with "rear differential" leak thread.
    Was there a work around for this? I have the same problem.
    ... may have found the solution. Now to try it out.
    http://www.audizine.com/forum/showth...=1#post5020059
    And, yes. It worked. I had to follow the instructions I've pasted in below before I could change channels 63-66. Charisma was enabled (step 1), but other part needed changed (step 2). From the other thread:
    "for MMI 3G go to the secret menu, Select "Car" menu, Select “cardevicelist”, scroll down and check Carisma.
    Now, go back, and still in the "Car" menu, select “carmenuoperation”. Scroll down to Carisma. It will be set to 0 you will change it to 1 then push the scroll wheel to set it.
    Restart MMI."
  36. #1036
    Aug 27 2014
    Houston, TX
    Anyone knows if we can have Unlocking Confirmation with LED DLR instead of just turn signals ?
    2011 Audi A4 Black on White:
    Gloss Dipped 17 inch 7 spokes OEM | Gloss Dipped grille and splitter | 15% all around | VCDS | Matching Foglight & License Plate |
  37. #1037
    Dec 16 2008
    Delmarva
    OP - can I suggest you add that you need to enable it in the MMI settings for this one?
    Bit 2 - Set to 1
    Many people do the VAG-COM coding but then it doesn't work without doing it. May be helpful to have that right in the instructions.
    Also - for this one: Enable Optic rear parking for cars without front parking sensors
    Does the picture appear on top of the backup camera or does it replace the video feed of the backup camera?
  38. #1038
    Dec 16 2008
    Delmarva
    My DRL's turn on when I unlock. They don't blink but they remain on. This is an MMI setting if you don't have it enabled.
    Quote Originally Posted by longvo55 View Post
  39. #1039
    May 05 2012
    Clinton, UT
    Quote Originally Posted by chichum View Post
    Check the coming home feature. Mine by default was DRLs and Fog lights. I changed it ti DRLs only
  40. #1040
    Aug 27 2014
    Houston, TX
    I don't have MMI nor Auto in light switch, but enabled Coming Home menu from VCDS. Everything is enabled but only turn signal blinks.. I want to see her eyes stay on!
