Page 15 of 60 FirstFirst ... 5131415161725 ... LastLast
Results 561 to 600 of 2386
  1. #561
    May 29 2013
    United States
    I had a local shop VAGCOM my 2011 S4 according to the instructions in this thread. I am having difficulties verifying a couple of settings.
    1. Set Custom ADS settings
    I wanted "Individual" to be the default setting but when I start the car, the indicator on the console shows "Auto" and the car behaves as if it was in auto mode. Is it a programming mistake or is it something else?
    2. Disable LED 'wink' on turn signal
    Once the "wink" is disabled, the LED should not switch off when the turn signal is activated. Is this right for any mode of lighting? It does not switch off when low beams are on and I turn the blinker on. But it does switch off if I have my headlights in auto and it is a bright day outside. In other words, when only the LEDs are on, they switch off when I'm signalling a turn. Is this the way it should be, or was it programmed incorrectly?
    Veteran Member Four Rings achilleas101's Avatar
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    Quote Originally Posted by evolvah View Post
    interesting. what happens when your headlights are off completely? i only tested it while in off position, never even thought to try it while in auto or on. but will do that when i get back into the car.
    Gone but not forgotten:
    2013 S4 Imola Yellow | Black leather/Silver Alcantara | 6MT | B&O | Sport Diff | Silver 19x8.5 Avant Garde m550 | XPel Ultimate full hood/fenders | Eurocode SS
    2003 A4 3.0 6MT;
    1998 Acura Integra GSR 5spd
    Gone and most likely in a junk yard somewhere: 1990 Toyota Tercel
  3. #563
    Veteran Member Four Rings PSYC0TIC ONE's Avatar
    Oct 19 2005
    2022 Mazda CX-5, 2013 HD FatBoy Lo
    Virginia
    Re: VCDS & Hidden menu: The complete list
    The LED DRL should only turn off when your headlights or parking lights are OFF if 'wink' is activated. Disabling the wink feature will stop that from happening.
    -Cliff
    Current:
    B9.5 //S4-Prstg-Turbo Blue on Gray-30% Tint
    B8 //S4-Prstg-6MT-Ibis on Blk-Sprt Diff-35% Tint-H&R OE Sprngs-AWE CatBack
    B6 //S4 Nogy on Nogy-19" OZ SLs-FI NonRes CatBack-Hardwired V1 w/ LIS4 Display & LaserMask-30% Tint-RS6 Pedals-BiXenon ECodes
    B5 //S4 Cactus on Black-Sport Pckg-18" Flik Justices-JHM Shrt Thrw-APR Stg1
  4. #564
    May 29 2013
    United States
    Thank you for your help but I am still confused...
    Let's talk in terms of headlight control switch position, wink active or disabled state, and the turn signal on or off state. Those seems to be the primary controls, even for the auto mode.
    What combinations of these three controls keep LED on and what combinations keep it off?
    Is it a confusing way to state the question? I'm thinking like a computer that controls the LEDs :)
  5. #565
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    and the question to you is: headlights in OFF position, what happens when you put on your turn signal? LEDs wink or don't wink? if the wink was deactivated, they should stay on.
    2003 A4 3.0 6MT;
  6. #566
    May 29 2013
    United States
    I will test this when I get out of the office after work. My use case has always been to keep headlights in "auto" and this is when the LEDs switch off for the duration of the turn signal. Just like it was before the reprogramming. It may behave differently in the daylight and at night. I will need to see later tonight.
  7. #567
    Oct 19 2005
    Virginia
    On my car, headlight switch in off position, indicator on leds stay on.
    Headlight switch in auto position and headlights off indicator on, leds stay on.
    Headlight switch in auto, headlights on are NOT affected by wink feature being enabled or disabled
    -Cliff
    Current:
  8. #568
    Active Member Two Rings barrelman17's Avatar
    Dec 06 2010
    Rockland County, NY
    Quote Originally Posted by PSYC0TIC ONE View Post
    +1
  9. #569
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    checked mine last night. with the wink disabled, the LEDs stay on regardless of headlight status. Off, auto (and within auto on or off), fully on - the LED stays on with the turn signal. so Evolvah, it sounds like whoever coded your stuff didn't do it right.
    2003 A4 3.0 6MT;
  10. #570
    May 29 2013
    United States
    I tried mine and when the light switch is in OFF or AUTO (in the daylight), turning the turn signal on, shuts off the LEDs. So, yes, I will talk to the guy who did the VAGCOM programming to see how he can fix that.
    On the other question, if I had ADS default set to "Individual" and if it was done right, should it light up on the center console instead of "Auto"? Is this how this works for you?
  11. #571
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    the ADS one i don't know about...
    you're not in the DC area are you? if so, i could help you out.
    2003 A4 3.0 6MT;
  12. #572
    Oct 19 2005
    Virginia
    For ADS, YES if you had it VAG'ed to be set at individual when you first start the car it will default to individual
    -Cliff
    Current:
  13. #573
    May 29 2013
    United States
    Thanks again, guys! Tomorrow morning I will come back to the shop and we will see how to fix this.
  14. #574
    Oct 19 2005
    Virginia
    Where do u live? I am in manassas VA and can help, also have latest vag cable
    -Cliff
    Current:
  15. #575
    May 29 2013
    Florida
    Just purchased a 2011 B8 S4. Thanks for posting these awesome settings for the community !
    Anyone know if there a way to turn-off the disabling feature on the DVD player while the car is in motion ?
  16. #576
    Jun 28 2012
    North NJ
    Quote Originally Posted by blues4 (vince) View Post
    It's right there on the first page's list of codes. VIM (Video in Motion)
    2012 S4 Prestige - Ibis and Titanium - 6MT - MMI - B&O - Rear Parking - Advanced Key
    - Clear Bra - Vag Mods - 8500 Hardwire - Intercooler Screen - Roc-Euro Short Shifter - Eurocode Rear Sway Bar - CR-15 - Matte black rear valence - Show N Go Front Plate
    1991 Ducati 851 - 888cc High Compression Pistons - Big Valve Corsa Heads - High Flow Fuel Injectors - Open Airbox - Braided Steel Lines - Corbin Seat - Fast by Ferracci Chip and Mufflers - Carbon Fiber bits
    Hex-Can-USB in Northern NJ
  17. #577
    May 29 2013
    United States
    Thanks a lot for offering your help! I am in North Texas. It would be quite a drive to VA :)
    I had everything taken care of by my mechanic. The wink and ADS settings work as desired. However, he had to do the inverse of what the instructions for "wink disable" say. Weird but it worked.
  18. #578
    May 29 2013
    Florida
    Excellent. My decoder ring was not working with the vmi acronym...
    I've noticed that if the car is locked and you open the trunk only, when you close the trunk it automatically locks. I'm sure this is a great feature for some, but i can see locked keys in the trunk in my future. Is there a way to disable the autolocking feature?
  19. #579
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    Maybe sure you know where the second key fob is when you try this (and make sure they're not in the car), but supposedly if you close the trunk with the key fob in the trunk, the trunk will pop right back open.
  20. #580
    Senior Member Three Rings Creatre's Avatar
    Mar 18 2012
    Summerville, SC
    Quote Originally Posted by Stereodude View Post
    I think that's only with Advanced Key cars.
  21. #581
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    Quote Originally Posted by Creatre View Post
    That would seem somewhat backward. If you have advanced key the key is unlikely to leave your pocket, making it quite hard to accidentally set it down in the trunk.
    However, I have Advanced Key and tried this today on my 2013. I tossed the key in the trunk, and closed the trunk. At the same time you get the thud from the trunk closing the lights flash and you hear the alarm chirp. Then, the trunk immediately pops right back open.
  22. #582
    Oct 19 2005
    Virginia
    I want to try this
    -Cliff
    Current:
  23. #583
    May 29 2013
    Florida
    No Advanced Key on my 2011 and it definitely locks with the keys in the trunk. Sounds like Audi may have addressed this in the newer models. Thanks for your input.
  24. #584
    Oct 19 2005
    Virginia
    Mine does the same thing with advanced key on a 2012
    -Cliff
    Current:
  25. #585
    Established Member Two Rings asm777's Avatar
    Sep 25 2010
    Just posted this in the Drive Select thread but thought I'd share here as well since I think it may only be relevant for 2013 S4 models WITHOUT ADS (no sport diff). http://www.audizine.com/forum/showth...-VAG-COM-codes
    Made a new discovery today for the B8.5 FaceLift S4. This will likely only be relevant for the 2013 S4 without Sports Diff as my understanding is that the 2014 models will all have ADS for engine/steering.
    DavidB8 was kind enough to post his updated ADS instructions for the FL models here:
    http://audienthusiasts.com/VagCom_FL_ADS.html
    However, I wasn't able to get the dynamic steering to function properly with either Bit 1 or Bit 4 on Byte 8.
    After comparing coding of [09 -Cent Elect] with a 2013 S4 equipped with Sport Diff, I found that the STEERING in the MMI is controlled by Byte 11 Bit 7.
    Also, from the Factory, the 2013 S4 with Sport Diff also uses Byte 8 Bit 0 to display the Engine/Transmission in the MMI. I haven't confirmed whether this configuration is accurate but in a non-ADS S4, enabling Byte 8 Bit 0 for Engine will switch the Gear Display to "S" from "D" when the "Dynamic" or "Individual" setting with Dynamic Engine are selected. Note that it does not permanently set the gear to "S" mode as it did in pre-FL cars. The FL shifter also doesn't have fixed "D" and "S" positions and instead functions like a toggle switch. After putting the car in "Dynamic" (and having the gear display go to "S"), I found that I could tap the shifter and it would switch to "D" and back to "S" if I tapped the shifter again.
    Lastly, I only found one other bit that was different in the S4 with Sport Diff versus the non-ADS S4. Anyone have any insight as to what Byte 18 Bit 7 controls?
    Current:
    2017 Q7 | 2013 Q5
    2013 S4 | 2011 S4 | 2010 Q5
    **VCDS/VAG-COM available**
  26. #586
    Senior Member Three Rings SE-Chris's Avatar
    May 26 2013
    BMW 328i Sport
    Redmond WA
    I've not been able to get a few of the codes on 8.5 working.
    The interior lights and the Parking Break stuff =(
    Windows and several others appear to be working perfectly
    2014 S5 White - 6MT - MMI - B&O - Black Optics
    2013 S4 White - 6MT - Navi - B&O (Sold)
    2006 Mazdaspeed6 - 6MT - Navi - Bose (Gone)
    1997 Civic - B20 Swap 239 whp (Sold)
    1989 Subaru XT6 - Auto (Dead)
  27. #587
    Sep 25 2010
    Quote Originally Posted by SE-Chris View Post
    Need one additional step in the MMI Hidden Menu for the Ambiance Lighting:
    *For B8.5 [carbusassignment] - Interior Light to [CAN Komfort 1/9]
    Need more details to be able to help on parking brake questions...
    Current:
    2017 Q7 | 2013 Q5
  28. #588
    May 26 2013
    BMW 328i Sport
    Redmond WA
    Quote Originally Posted by asm777 View Post
    I'll play with your suggestions on the Lighting.
    As for the parking break, i'm trying to make it so I can use the button w/o having to press the break. I'd love if I could just push the switch at any time, no matter what, and have it engage or disengage. Similar to having a mechanical lever.
    :EDIT:
    Interior Menu displayed and I can adjust the dial however I don't actually notice a change in the lighting.
  29. #589
    Veteran Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Copenhagen, Denmark
    :EDIT:
    And you have all doors closed, when you try it ??
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 21.9.0 (HEX-V2)
  30. #590
    Jun 28 2012
    North NJ
    :EDIT:
    In my '12 even at night on the brightest setting the footwell lighting is fairly subtle. If you have another bright light source nearby (garage lights, outdoor flood light nearby etc) you may not even notice it. This may not need to be said but Ambiance lighting is only the foot well lighting, not the overhead etc.
  31. #591
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    and what problem are you running into? are you able to code it but it's not working? or are you not able to code it? and if not, what step are you having problems with. i have a post a few before this (post #549) where i detailed my experience with my '13 - the process is different.
    2003 A4 3.0 6MT;
  32. #592
    Established Member Three Rings Madbusy168's Avatar
    Mar 25 2013
    Philadelphia
    Hi Guys, Im trying to do Video in Motion for my 2013 S4 with navi,, Im computer retarded and cant seem to find a very very simple and straight forward way of doing it. Can anyone help me out? sort of like a baby step by step process tutorial? Thanks
  33. #593
    May 03 2013
    Quote Originally Posted by achilleas101 View Post
    ok, i finally got into the parking brake module with security access. followed the order - security access, enter code (78713 for the 2013s for those still looking for it), close, go to adaptation. i want to change it so that i don't have to depress the brake pedal to release the parking brake, but the channel list is not by numbers per se. it's a drop down. the one that seems right is "manual release", as it has 2 values possible "with button and brake pedal depressed" or just "with button". the first is what's selected currently.
    edit: summm bitch, i figured it out. went to another control module (did the DRL blink one) and it had 0635 in there for workshop number. so i used that in the parking brake module and it worked. FINALLY. So not sure if that workshop number will work for everyone or if you have to see whats in your car specifically, but apparently, you can't just use 12345.
    Thx man, this worked for me for the release parking brake without seatbelt.
    I can confirm the security code in my B8.5 to be 78713. My workshop number was 06325 (I think you may have a typo there?), so it looks like it's common to all B8.5 as well.
    2013 | Lava Grey | Black Interior | DSG | Premium Trim (Canada) | Sport Diff | LED Interior | P3 | 35% Tint | VAG-COM | Opti-Coat | BBS CH-R 19x9.5 Titanium ET45 | Höen xenonmatch | ???
  34. #594
    May 03 2013
    Quote Originally Posted by Madbusy168 View Post
    Did you extract the security access code properly and code it as per the instructions from the first post?
    Enable VIM on MMI
    [5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
    [Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
    [Adaptation - 10] -> Channel 48
    Set to 255
    Reset MMI
  35. #595
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    Quote Originally Posted by rocque View Post
    glad to be of help! and i think you might be right about the typo. Will have to check that when i get a chance and correct it accordingly.
    edit: yup, you were right, i did have a typo. fixed the original post for posterity.
    2003 A4 3.0 6MT;
  36. #596
    Mar 25 2013
    Philadelphia
    Enable VIM on MMI
    Set to 255
    Reset MMI
    Hehe, this is where I'm confused, I know how to get the serial number, I don't understand the security access part enter digits 6,13,10,14,11 of the 1st serial number part.
  37. #597
    May 03 2013
    It's literally taking the 6th, 13th, 10th, etc. digit of the serial number, to form the 5-digit code.
    This page has it spelled out in great detail, even has a "calculator" to formulate the access code: http://www.audienthusiasts.com/Articles_VIM.html
    HTH
  38. #598
    Mar 25 2013
    Philadelphia
    HTH
    Thanks!! I think that I get it now, gonna give it a try tomorrow morning.
  39. #599
    Sep 30 2012
    I am planning on getting a couple of VAGCOM mods done, specifically the LED wink disable, remote operation of windows/sunroof, and ambient lighting. Have any of these codes changed for the 2013s?
  40. #600
    Mar 25 2013
    Philadelphia
    Quote Originally Posted by willa1975 View Post
    Nope
