Results 1 to 22 of 22
    Established Member Two Rings Rollout's Avatar
    Sep 13 2010
    Long Island
    Car stopped working after drive thru car wash
    Today I decided to take my car to car wash after having it dirty from snow and what not. Car was running fine going into it no lights on or anything. I noticed it took exceptionally long for the car to come out but I thought nothing of it at the time. I get home realize that the ESP and ECP lights are on and figured they would go away if I turned the car off and back on. Turned it back on lights didn't go off and now the check engine light is on. I decided to leave the car be for a little bit to see if it would go back to normal. I come back an hour later car won't even start up now. So I give it a jump, turns on, I go inside and decided I'm gonna take a ride around the block and the car won't start up again. Any ideas on what's wrong guys??
    Veteran Member Three Rings rvca3112's Avatar
    Aug 08 2010
    brick/nj
    Have u scanned it?
    2003 Porsche 911 turbo 623 awhp
    2009 Porsche Cayenne s 317 awhp
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    battery is fried? scan with vag-com
    Sep 13 2010
    Long Island
    Do you think the car wash could've caused that? And I don't have vag-com guess I should look into buying it
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    how high pressure was the car wash....if your seals were bad water could have gotten into the ecu?...idk seems odd
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Sep 13 2010
    Long Island
    I've used it plenty of times before, never had a problem
    Jul 08 2010
    tucson
    danbury
    sunroof? i know audi has a recall for a bad seal on the passenger side of the roof, somehow water can end up in your electricals and mess some stuff up...other then that idk?
    [CENTER]Scott
    2011 S4
    Established Member Two Rings Titanems's Avatar
    Jan 25 2010
    North NJ
    take it to autozone and get it scanned. Can you try jumping it again and then driving straight to AZ?
    Established Member Three Rings mo17k3y85's Avatar
    Oct 23 2010
    B7 A4, lexus RX330, F150 Roush
    carbondale il
    happened to me before, LONG TIME AGO....with a hondaaaaa. It was the distributor that got fried, seal wasn't good water seeped in. Doubt that's the case with our cars.
    06 Quartz Grey B7 - Lowered, 19" RS4 Reps, S-Line front bumper, Color matched Cupra Lip, Smoked reflectors, Spyder R8 led headlights, Hoen yellow fog lights, Led interior, Magnaflow exhaust, In.pro mirror caps, Tinted
    Senior Member Three Rings WasGTIguy's Avatar
    Jun 09 2009
    Orangeville, Ont
    Quote Originally Posted by mo17k3y85 View Post
    We have coil packs. I had this problem before too. If you were recently chipped. I had my old MKIV Jetta TDI chipped and water got into the computer after the upgrade and stuck my into idle. No throttle what so ever.
    2003 Jetta GLS TDI (upsoluted) Eibach Longbeach Phatbox SOLD
    2007 GTI (DSG ftw) APR goes weee SOLD
    2007 A4 Avant Quattro 3.2 S-Line Titanium 6MT
    Check out my 3000km roatrip
    Veteran Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-150 Platinum 6.2L, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    Have it scanned.
    2007 Audi A4 S-Line 2.0T FSI - APR Stage III GT2871R, APR HPFP, Carbonio intake, AWE FMIC, BSH CC / PCV delete, OEM "D" DV, APR downpipe, Neuspeed exhaust, H&R coils, ECS Stage 4 BBK, JHM 4:1 center diff, Neuspeed short shift, RS4 rear sway bar, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, black rear valence, Cupra R lip, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas with H&R Trak+ spacers
    Sep 13 2010
    Long Island
    Jumped the car EPC and ESP shut off CEL is still on, currently at the gym and the car died on me again. If it's any help cars completely off keys not in the ignition and my fan keeps turning on and off, on and off non stop, any ideas why this is happening. And this is the 3rd time the cars died today
    Veteran Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    Sounds like water got where it wasn't supposed to be, could be the sunroof problem mentioned above
    RIP QG TI B7 A4
    Veteran Member Four Rings Korrect414's Avatar
    Northern CA
    I would definitely get it scanned ASAP. Once you get the codes you will be able to go from there and narrow it down.
    Let us know what codes come up.
    Also, you should probably buy yourself a Vag-Com for Christmas. It will pay itself off very quickly.
    Aug 18 2009
    A Unicorn
    Portland, OR
    Sucks dude. Yet another reason why I only hand wash my car.
    Sep 13 2010
    Long Island
    With help from my sisters boyfriend he found out that water was leaking into where the ecu is and building up, thus frying a few fuses in there. Dried it out replaced the fuses and car works fine. Gonna stick to hand washing from now on haha
    Veteran Member Four Rings bmc333's Avatar
    Feb 12 2009
    NoVA
    Merry Christmas ur car works!
    2015 S3 - Panther Black P+ / LED Lights / B&O / APR Stage 1 ECU & TCU / APR Turbo Muffler delete / CTS Turbo Inlet/Discharge/Intercooler Pipes / X34 Intake / Superpro end links / VWR springs / 35% Tint / ED CF rear diffuser / 034 CF engine & fuse box covers / ECS CF battery cover / BBS SR's
    Northern CA
    Quote Originally Posted by Rollout View Post
    Glad to hear it. Yeah, I think you learned your lesson :). It could of been an extremely costly mistake.
    Jul 08 2010
    tucson
    danbury
    when it gets warmer u may want to look at where else water is getting in and causing damage
    [CENTER]Scott
    2011 S4
    DUH! an Audi
    los angeles, CA
    yikes! i would go back to the car wash and complain.
    Aug 22 2008
    Finland / Vasa
    Mine did this after a carwash last winter... I got all kind of fault codes and it jumped and shook all over the place. I found out the last owner had broken a big plastic piece of the ECU cover lid so water got int to my ECU box and fried two relays on the bottom of the ECU box.
    I bought 2 new relays for 20 bucks and dried out the ECU box and bought a new lid after that no problems at all.
    My tip is check the ECU box!
    Damn didn't read that you already found the problem...
    Happy holidays!
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    My coilpacks got ruined from a car wash once
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
