So I'm thinking of doing the upgrade to stage 2+ (on Unitronic) since I already have stage 2 since may.
I've searched and researched till i'm blue in the face...
I've read through the war threads such as this one: http://forums.vwvortex.com/showthread.php?4219433
And the comparison threads: http://www.audizine.com/forum/showth...otech-compared!)
And seen the bashing from vendor to vendor: http://forums.vwvortex.com/showthread.php?4221606
So at the end of the day, it seems as though the KMD pumps fail constantly and require cam follower replacement every oil change. The Autotech, eventhough it's a similar design, seems to have less failures although they still fail apparently and the follower needs to be replaced every 10k basically. The AWE solution looks like what I'm leaning towards since I have a brand new pump (so I'm not too concerned with the seals being worn) and can't justify supporting APR's pricing.
That being said, for those of you that have made the stage 2 to 2+ upgrade, I was hoping you could answer a few questions...
1) What pump are you running... any issues? Cam follower wear increased or same?
2) How many miles have you been using it
3) Fuel consumption... did it get worse or better...
4) Power gains..realistically I know it's not like getting chipped again, but is it noticeable like stock cat vs tp
5) IF you are using Unitronic, what is your average highway fuel consumption mpg or L/100km
6) IF you are using Unitronic, what is your average mileage per tank
I can understand fuel consumption goes up with hp to a point, but wanted to know what you guys really get. If I set the cruise at 60mph, I get an average cosumption of about 26mpg vs the 33mpg on stock tune with my mods... And on city driving mixed with some highway, I average 400-450 km's per tank. Seems high to me after reading all your "I average 36mpg" posts. My Uni dealer called support and they tell me that it's not software related and there's something going on, but when I'm on stock tune my mileage is pretty much what you guys get.
