Results 1 to 25 of 25
    Established Member Two Rings nyconickk's Avatar
    Jan 30 2006
    area 51
    I must vent!!!! Royal purple content
    So I decided it was time to change some oil...engine oil transmission oil and the rear diff also. I got some royal purple 75w90 for the trans and rear diff. oh BTW.. car is a 5spd 1.8t W/72K. I drained both the trans and rear diff at the same time and filled them back up respectively. 2.9 quarts in the trans and 1.5 in the rear diff. I let the car warm up for about 40mins. Now when I got in I immediately noticed the HORRIBLE difference. I literally had to fight the gear to go in. I was so disappointed, this crap is like 20 bucks a bottle. I thought that maybe I will have to drive it a bit so it can work itself into the the trans.... yea, I was wrong ... I went to drive the car this morning and it was even worse. The car sleeps in a heated garage so it's not like it sat out in the cold. I am disgusted in Royal Purple and would highly recommend NOT using this crap... I do not feel better about venting , but I hope that I can avoid some of you from making the same mistake.
    life goes by to fast to put things off for tomorrow, so boost all you can when u can
    Established Member Two Rings rickadoe's Avatar
    Jun 28 2008
    04 A4 avant 6spd, 99 tdi jetta, 98 beetle 2.0, 03 mazda P5, 03 chevy suburban
    central valley cali
    damn 20 bucks? ever look @this stuff?...https://www.amsoil.com/catalog.aspx?GroupID=213 have this stuff in our jetta and my a4 6spd. no issues.
    mods - GIAC stage1- 2 10" subs in custom trunk enclosure
    if you ain't cheatin you ain't tryin' - Al Davis.
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    One of my neighbors down the street SWEARS by AMSOIL. Been using it for years. He has tried it on his N/A, Single turbo, Twin Turbo engines, and he says he gets the same results across the boards.. Always a positive experience.
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Motul Gear 300 is what I'm but to put in.
    Senior Member Three Rings Outerfroggy1's Avatar
    Nov 18 2009
    Newfoundland, Canada
    Amsoil is good shit. I haven't tried any of their automotive products but I've used their motorcycle products for many years. Their 2 stroke oil is 2nd to none.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Although the RP is a little watery in viscosity, I dont think that it would reject the gear changes. When my fluid gets low (axle seal leak) thats what I experience, make sure that you indeed put the correct amount.
    2019 SQ5 Prestige
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    you're fighting the tranny b/c RP is GL-5 approved which is NOT safe for yellow metals, which our synchros are brass.. Get some Synchromesh in it. My mk3's tranny use to shift HORRIBLE and i thought the trans was going out.. swapped gear oils and it shifts like butter.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    At 130K (mostly Interstate) miles I am past due for a transmission gear oil change. I have had no complaints with the OEM gear oil so I will probably just stick with OEM. I realize that the cost is considerably more but considering I got 7 trouble free years out of the OEM stuff I am not inclined to change.
    Veteran Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    NC
    Quote Originally Posted by black99.5a4 View Post
    ^This.
    The RP is GL-4/GL-5 compliant. You want GL-4 ONLY for your trans(Redline MT90 is a good GL-4 fluid), and GL-5 ONLY for the rear diff(Motul 300 GL-5 is a good choice)..
    Also, the Royal Purple IS good fluid, when used in the right application...
    -Brandon
    APR | Oettinger | KW | iForged | Evolution Racewerks | Labree | Carbinio
    12.9@104mph
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    GM synchromesh ftw
    Veteran Member Three Rings sxman69's Avatar
    Oct 04 2009
    08 CRF250R, BLKMRKT Mob, Giant Glory DH
    Auburn, CA
    Synchromesh just sounds butteryyyyy.
    -Sam
    New: 2009 Mazdaspeed 3 GT
    SOLD!!!! Staggared AMG Monoblock // Podi // Magnaflow // Forge // Kicker // Kenwood // JHM stud conversion // Tint //15mm H&R spacers // Hardwired Passport 8500 X50 // 034 Wiring Harness // Hawk HPS // 034 Blockoff Plate // MKIV Euro Switch
    Dec 12 2006
    Charlotte,NC
    pennzoil syncomesh in my 5speed and 6speed both shift good
    MK4 GTi 1.8T converted to AWD
    New 1/8th mile 7.36@102mph-27psi 93 octane, no meth
    New build times 23psi pump 11.9@126mph-96mph in the 1/8th
    04' A4 1.8t frontrak converted to quattro, was RWD for a lil now its quattro finally
    2011 JSW Tdi 6speed manual
    Jan 30 2006
    area 51
    really appreciate all the responses... AMSOIL it is then
    Mar 27 2005
    The Cold North
    The redline fluid is also very good. Been running it in my diff and tranny with track time qand last time we checked it it still looked good. Shifts well. I also run the redline in the motor since the build.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Established Member Two Rings 42no_B6's Avatar
    Nov 28 2010
    05 STI, 05 gsxr 1000
    Ca
    I've used Amsoil with great results. Was gonna try some Royal Purple but another mechanic told me of the horrible results he had on his race car. That was enough to scare me away...
    Veteran Member Three Rings pape's Avatar
    Nov 30 2008
    MIA
    I have used red line, motul, lucas, and mobile. to date the best for me has been the motul gear 300
    Veteran Member Three Rings A4_Mike's Avatar
    Apr 09 2007
    2014%20Audi%20A4%2C%202017%20Audi%20Q5
    Cary%2C%20NC
    I have been using Redline MT-90 for a couple of years with no issues.
    2014 Audi A4 2.0T quattro | Volcano Red | Chestnut Brown | Tip | P+ | Nav + | Sport | B&O
    2017 Audi Q5 2.0T quattro | Ibis White | Ebony | Tip | P
    Mar 31 2009
    NC
    Quote Originally Posted by A4_Mike View Post
    Another local! We need to get all the local guys together for some drinks...
    -Brandon
    12.9@104mph
    Aug 14 2007
    2002 Dodge Dakoto 4.7L & a 1990 Honda Accord that won't die
    Bellevue, WA
    OG.....do you ever experience the "hard to shift into 2nd gear" syndrome at times when the tranny oil is cold? It's been 50K or so (my memory may be foggy on this) when I switched, but when I switched to Motul Gear 300 the frequency of my hard shifts went way down. I still experience it occasionally, but I don't have to double clutch as before, I just baby it in real slow-n-easy.
    OP.....can't comment on the other flavors of tranny/diff oil, but I've been happier with the Motul 300 over what came in the transaxle from the factory.
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Lucas, Lucas, Lucas!
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Oct 02 2006
    Wadsworth,OH
    I vote Redline. My old BMW would hardly go into gear - some Redline MT90 in the gearbox and it was shifting like new, even after 200k miles.
    Right here:
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    i love NEO Synthetics, but have yet to use it on my Audi. on my corolla 2 way diff that oil stays clean and crisp longer than any other oil i have ever used in my life. and can allow for crazy LSD clutch disk lock up for mucho drift action.
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by MMMB00ST_A4 View Post
    ^This.
    ^^^ I agree - Royal Purple oil is a winner in the crankcase
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Junior Member Two Rings
    Nov 06 2020
    Vail
    Quote Originally Posted by nyconickk View Post
    Dude... I’m sorry that happened to you but it saved me from buying this stuff for my b7 s4. It’s Saturday and dealership is closed and from all appearances this hear oil checked all the boxes. I’d be filling my baby up with it right now had I not seen this. Best of luck brother
    Jan 24 2010
    Paramus,NJ USA
    OEM,synchromess or redline. I wouldnt recommend anything else. Just because its expensive AF doesnt mean its good. Best to stick to the tried and true fluids.
    Ziddy Autowerks
