Results 1 to 13 of 13
    Veteran Member Four Rings rs4 tony's Avatar
    Sep 13 2010
    Long Island, NY
    whats the difference between the white cabin filter and the charcoal filter?
    where is this cabin filter located? and is it a easy job? and also whats the difference? thanks
    2007 Audi Rs4 Daytona Pearl/Carbon Fiber Trim/Navi/Lambo Verde Ithaca Pearl Painted Calipers/H&R Springs/JHM 93 Octane Tune/K&n Drop In/Apikol Red Rear Diff. Mount/StopTech S.S. Lines/Michelin Super Sports 275-30-19/H&R 8mm Front Spacers/MTM 10mm Rear Spacers/JHM Intake Manifold Spacers/SPEC Stage 3+ with LW Steel FW/JHMCatless Downpipes/JHM 2.75" Non-res Catback Exhaust/JHM Lightweight Front & Rear Rotors/034 Torque Mount/
    Instagram: @rs4_tony
    Veteran Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    RS4
    The cabin filter when facing your car (standing in front of your front bumper) is under the hood directly below the windshield where it meets the wipers and directly in front of the passenger seat. There is a plastic cover over it which I believe is fitted with clips only iirc. It's easy to change out, definitely a DIY for anyone imo.
    1. Open Hood
    2. Remove the plastic cowl cover, where the battery would go on an S4. walk to the passenger side of the car and look right by the windshield. You will see a black plastic box with two tabs. Lift off the cover and whalaa, there is the filter.
    It's the box with the diamond cut recession.
    Probably the easiest, effective method way for at home is going to be...
    1. Remove existing dust and pollen filter, leave covers off
    2. Let engine get to operating temp
    3. Turn climate controls to Hi (full heat), max blower speed, Econ, select all vents (upper, mid, lower), don't turn on recirculation
    4. Roll windows up, shut doors
    5. Spray a good amount of Ozium (Pep Boys carries this product) underneath the hood directly into where you dust and pollen filter went (you should see the blower fan spinning).
    6. Hold your breath, open a door real quick and push recirculate, close door - do NOT stay in the car.
    7. Let car run for 10 minutes (without you in it).
    8. Roll all windows down and let remaining ozium fumes air out while car is still running with blower full on etc. Turn off car afer ten minutes, leave all windows down etc for at least an hr.
    9. Install new dust and pollen filter after you turn the car off
    That should kill all the mold on the evaporator and in the ducts, and protect against it forming again.
    I believe the charcoal version does a better job of filtering the minute particles. Just my opinion.
    RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM 3R & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : F Plate Delete : CC Mod
    Feb 01 2008
    04 Audi A4 cab
    Chicago
    Quote Originally Posted by rs4 tony View Post
    Charcoal picks up pollen and stuff I thought?
    Sep 13 2010
    Long Island, NY
    i heard it has a oder sheild..
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Charcoal filters allergens and odors better.
    http://en.wikipedia.org/wiki/Activated_charcoal
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    05 B6 S4, BMW F15 X5
    Southern NH
    I switched to a charcoal filter and the main difference I can report is that if someone smokes in the car in front of me I can no longer smell the cigarette smoke, but something like diesel from trucks or semi’s still gets by
    B6 S4 Winter Beast: Supercharger, Carbonio-hybrid Intake, Fast Intentions DP & CB, CF Vented Hood. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/LW rings) & rear BRK, SS lines. Snow tires.
    Daily Driver: BMW F15 X5 M50d clone, DUDMD tune, water/methanol injection, 38mpg highway
    Aug 14 2009
    RS4
    It has cut down on some outside odors permeating through the vents, forgot about that factor.
    Sep 13 2010
    Long Island, NY
    NY07RS4 thanks for the advice. worked perfectly. smells much better too. you people should try it.
    Aug 14 2009
    RS4
    No problem bud.
    Veteran Member Three Rings maxbhp's Avatar
    Aug 11 2007
    OC, CA
    I just read this thread a few days ago......noticing my car smells a little funky at times so I ordered a charcoal filter from genuinevwaudiparts
    Super easy to replace the filter in just minutes and voila......funkiness gone
    Thanks for the thread guys
    Titanium, Carbon Fiber Int Trim, Front lip, B Pillar, C pillar, and seatbacks, Stasis MS, Stern CA's, H-sport Rear Sway, LI-S4 V1 Stealth Hardwired w/ hidden mute in shifter boot, OEM E- codes, JHM Tune, Hypershift SS, Apikol Rear Diff, Full Clearbra, OEM full Euro Interior in Leather/Racecloth, Quattro Suede Eurowheel, Suede shifter and e-brake, 19x10 Forgeline, 285/30, MTM exhaust, Custom 2.75" downpipes w/ HJM cats, Carbon engine cover, Fenders rolled, Color-matched mirrors, Alcon 370mm, Funk
    Aug 14 2009
    RS4
    I can't take credit, Handyvorb provided me with the 'how to' a long time ago. I saved his info (added some minor tweaks) and shared it here.
    Established Member Two Rings chodemaster's Avatar
    Jun 09 2010
    Flawiduh
    doing this as we speak...
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by chodemaster View Post
    sweeet
