I've searched and searched and bled and bled and I can't get constant heat in my '03 A4 1.8T. First off, my temp gauge works perfect. It slowly heats up and stays at dead center constantly. I've opened the reservoir cap and it bubbles and I can hear air in the coolant. At idle the air is cool but when I rev the engine it gets warm. The top heater core hose is cool while the bottom is hot. There is either air trapped or the heater core is blocked. I have bled the coolant for hours and pulled the top core hose off several times and filled it directly with coolant.
Last night I hooked up the shop vac and sucked 3 gallons of water through the heater core and not one particle of dirt or debris came out of the heater core came out so I don't think it's clogged. However, how restrictive should the heater core be? I poured water into a clear hose about 18 inches above the top heater core line and let it drain out the bottom (both hoses to the engine were disconnected) and a slow steady stream of water came out. I expected the water to run right through the core but it was rather slow. Is this normal?
I believe I got most of the air out of the system last night and the heat was pretty warm. When I rev'd the engine it actually got hot so I thought I had it and I just needed to bleed a little more air out. This morning I started it, let it warm up, and it's cold again. When I started it I could hear coolant sloshing in the heater core which makes me think I have an air leak. I do think it would have to be a fairly large leak because it sounds like a lot of air in the system. I changed my oil a couple weeks ago and the oil looked fine, I didn't see any coolant in it. I don't see any coolant leaking onto the garage floor, however it's difficult to tell with all of the snow we have here in MN because the car is covered in snow so it melts all over the garage floor, making it more difficult to tell if there's coolant. I'm leaning towards a leaky j-plug but would that allow that much air into the system? Sorry for the long rambling, I think I covered everything but I'm sure I left something out. I've spent 8 hours messing with this and many more hours reading on here and I just can't spend a lot more time on it.
