Results 1 to 7 of 7
    Senior Member One Ring RedaudiA4's Avatar
    Dec 07 2006
    Westport, CT
    Audi A4 1.8T Fuel Pressure Regulator Problem
    Hey Audiziners,
    I first want to start by thanking everyone belonging to this community who has enabled so many of my small problems in the past to be fixed. However, I have looked all over the place for assistance with a problem that I seem to be having with my fuel line. I took my A4 to the Audi dealership and they told me it is the fuel pressure regulator. Basically what is happening is every time I turn on the car it emits a whining sound as if the Fuel pump is not operating at its optimum output. I feel no change in performance and I think that the Pressure Regulator has malfunctioned and is now causing this high pitched noise. Has anyone else experienced this problem? The real problem now is that I cannot locate the FPR and everyone says it is near the firewall and I do not see it! Furthermore, when I look up the part to replace it 2004 seems to be a gap year between 2003 and 2005... whats the deal with that? Is the 2003 FPR the same as the 2004? I assume it is but I wanted to locate it and look at it before I purchases it online versus buying it from the dealer. Please if anyone can help me locate it or provide me with a picture because the ones currently online are not helpful I would greatly appreciate it. THANK YOU.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    The FPR is built into the fuel filter. Your issue is probably a clogged fuel filter.
    It resides (on a quattro A4) under the passenger rear seat. Crawl under the car and you can see it just infront of the gas tank on the passenger side. $40 for a new filter and about 10mins worth of work. Should be the same for all B6 A4 1.8TQM.
    -Doug
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Fuel filter DIY: Clicky click
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Wow talk about getting the run-around & trying to scare the crap out of you ... Yeah our fuel regulators are built into the fuel filter.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Dec 07 2006
    Westport, CT
    Gents - I just ordered the replacement from ECS. You are all awesome and it is incredible to have a forum with such knowledgeable and helpful comrades.
    Dec 07 2006
    Westport, CT
    GENTS - I finally got the replacement filter and now I am dealing with the clips with are a pain in the ass - do you seriously just have to push in on both sides and PULL? There is not trick to it?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    -Doug
