Results 1 to 40 of 57
    Established Member Two Rings chirp's Avatar
    Dec 29 2008
    2008 Nissan Pathfinder 4X4 V8 LE
    ABQ
    Driveshaft Bearing
    You can see my other thread below for all my vibrations sysmptoms, but I have a quick question.
    How much play, if any, should there be in the driveshaft center carrier bearing?
    Mine moves freely about 2 inches in all directions. I am pretty sure that is not right.
    If it's bad, the good news is that I found my sever vibration that I have been chasing for sometime.
    The bad news is, well, you know...
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    afaik there shouldnt be very much play at all, even though its a bearing with what looks like a rubber bushing.
    when I did my piggies i gave my driveshaft a wiggle and theres definately some play there. I do notice a strobe-like sound when cruising 55-60 but it fades before and after that.
    never had violent shaking or vibration, more annoying than anything.
    the sound is exactly the same as the sound this old flat-bed truck I drove made when it had a bad carrier bearing. Changed the bearing and smooth as butter.
    Im interested to hear how you fare as I am going to have to do mine here eventually.
    034 sells the assembly as well as VAST so it shouldnt be too hard to source the part, $85-$100 bucks iirc.
    GL and I hope you figure it out soon!
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Dec 29 2008
    ABQ
    Quote Originally Posted by csosnowski View Post
    Well, I think if I end up changing it, which looks like I will have to, I am going to look into a 1 piece driveshaft.
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    not a bad choice, if I had the dough I would probably go the same route.
    but I dont so I will be hammering the ol' 2-piecer apart and RR'ing a 034 bearing to go with all the other 034 mounts. they need friends, you know :)
    Established Member Two Rings JLH_S4's Avatar
    May 28 2010
    Arab, Al - Lawrenceville, Ga
    I'm interested to see how this plays out for you. I've been getting a baaaaad mystery vibration but haven't had the time to really get at it and figure it out. I checked all the suspension and the front half axles and everything seems right there. I was just looking at drive shafts from ECS and they're ~$1300 - no clue what a solid piece one would be. Good luck with everything!
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    Scotty@Advanced has good prices on SPDS:
    http://www.advancedautomotion.com/pr...products_id=43
    $459+ whatever options you choose. not too shabby to increase reliability.
    I just dont have the cash for that lol, ima poor college boy.
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    heres the links for the VAST and 034 driveshaft carrier bearing pages:
    http://vastperformance.com/shop/prod...roducts_id=130
    http://www.034motorsport.com/chassis...s-p-13696.html
    May 28 2010
    Thank you sir! Now to find a DIY...
    Senior Member Two Rings jms-4's Avatar
    May 14 2009
    2000 Audi S4, 68 Mustang
    Renton, WA
    I posted a diy a long time back.
    Search and you will find.
    Jeff
    2000 S4
    Revo w/SPS3
    AMS TBB, Stern snub mount, Apikol Rear Diff Mount
    3" custom exhaust, Minor lemmi tweaks
    ST Coilovers
    710N, EBC Slotted + Dimpled
    Incognito Piggie Pipes, 034 Density Trans Mounts
    Voodoo MBC Ceramic in MBC only mode
    other stuff
    May 28 2010
    And thank you as well, sir!
    Just in case someone is too lazy to find it:
    http://www.audizine.com/forum/showth...n-a?highlight=
    Great write up man, I appreciate it!
    May 28 2010
    Hm... actually getting the car off the ground and taking a look underneath - when I spin the front tire back and forth the driveshaft has a fairly loud metal on metal "clunk" coming from where it bolts to the transmission. Is this normal? I took a short video if that will help
    May 14 2009
    Renton, WA
    questions:
    Quote Originally Posted by JLH_S4 View Post
    Is the car in gear?
    I believe the wheel should spin freely if it's in neutral.
    The noise sounds like it's in the transmission and not the cv joint, right?
    Secondly, are you talking about the driveshaft or the axle?
    Jeff
    2000 S4
    Revo w/SPS3
    ST Coilovers
    other stuff
    May 28 2010
    Quote Originally Posted by jms-4 View Post
    Is the car in gear?
    My bad, I guess that was a little vague.
    Car is in 1'st gear so the driver's side front wheel has a bit of movement each way, but not much. When the wheel is turned the driveshaft, where it exits/bolts to the transmission, is making the clunking noise. Yes the noise is definitely at the point where the tranny and driveshaft meet. I haven't dropped the exhaust and heat shielding to get a clear look at the whole driveshaft yet, that's just the first thing that caught my attention.
    Oct 15 2009
    WI
    Keep the thread updated when you replace it. I think mine's on it's way out, too. Everytime I let off the throttle at lower speeds I get a very odd rattle from around the driveshaft area. I imagine I have the same problem. Mine also has about 1-1.5 inches in play.
    And Rosemary proceeded to Catharin with intentions of a marriage with Theadore. When she arrived, Theadore opened the door and shot a blow in her eye, laughed, and stabbed her in the face with the mystical sword of Gizzru.
    May 28 2010
    Ya I haven't noticed any play in mine at all. I may be barking up the wrong tree entirely with the driveshaft but I'm still checking it out. Something is SERIOUSLY wrong under my car and I can't seem to find anything out of the ordinary down there. It's killing me - it's nice and cool outside I wanna be out driving!
    Veteran Member Four Rings DESPOT D S4's Avatar
    May 09 2010
    8S TTRS
    TriState
    Would a bad bearing/bushings cause a loud bang when hard shifting at what seems to be under the armrest?
    May 28 2010
    Quote Originally Posted by DESPOT D S4 View Post
    That could be engine or transmission mounts or rear diff mounts. There are a lot of points for slop in the factory S drive train. It only occurs under hard shifting?
    May 09 2010
    8S TTRS
    TriState
    Engine mounts are new 034 and I have a dts. I will check the trans and rear tomorrow.
    And yes only on hard shifts so far only happens 3 times in the last few months.
    @iruinaudis
    B5 S4 daily
    8S TTRS fun car
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    if you have the opportunity, crawl under your car and give the driveshaft a wiggle. id be willing to bed that theres some excessive wear on your carrier.
    if everything else is locked down then it would stand to reason that at the point that there is the most wear there will be the most movement.
    I dont have a dts, but I know that when i wind up 1st or 2nd gear there is definately a "pop." probly not the propeller hitting the bottom of the car, but the torque is causing the tail end of the tranny to lift, the driveshaft to deflect upwards and its making something out of whack.
    sidenote: anyone have a better pic of something to use to wedge the shafts apart? im having some difficulty trying to figure out something to use since i havent pulled the shaft to look at how its all set up.
    May 14 2009
    Renton, WA
    Please read this and report back exactly what your symptoms are
    http://www.blauparts.com/audi/audi_d...pair_kit.shtml
    Wondering If You Have A Worn Audi Driveshaft Or Audi Center Support Bearing?
    Symptom: A high pitch whining coming from the center underside of the car. The high pitch noise varies with vehicle speed. Lower pitched at slow speeds and higher pitched at fast speeds. It may even begin to make a screeching noise; especially when driven in cold conditions.
    Repair Solution: To determine the cause of the noise put the vehicle up on a repair shop post lift with all four wheels off the ground. Driving the vehicle on lift and using a stethoscope, confirm that the noise is coming from the Audi center support bearing area (see image below). If it is, replace the Audi center support bearing.
    Symptom: Quattro driveshaft vibration is felt from the center underside of the car, especially when straight line accelerating. Much of the shudder is felt through the shift lever upon acceleration. The shudder worsens when taking off from a stop sign and smoothes out somewhat when the car gains speed and/or when you let off the gas pedal.
    Repair Solution: 1) Make sure the vehicle is turned off and in park. Inspect the Audi center support bearing. Has the rubber that surrounds the middle of the bearing separated from the bearing bracket? If the rubber has separated from the bracket, replacement of the center support bearing in needed. 2) At the driveshaft yoke In the middle of the driveshaft you'll see the universal joint. Grab the front half and the rear half of the driveshaft with your hands. Twisting from side to side, see if there is any play in the Audi universal joint. If there is, replacement of the Audi universal joint is necessary.
    Symptom: Quattro driveshaft vibration is felt from the center underside of the car, especially when turning a corner from a stop sign. This shudder can also be felt through the shift lever when first taking off from the stop sign.
    Repair Solution: Make sure the vehicle is turned off and in park. Inspect the front driveshaft CV joint (located on the end of the driveshaft where it connects to the tailshaft of the transmission - see picture below). Grab the driveshaft with one hand and the outer cage of the front CV joint in the other, twisting from side to side to see if there is any play. If you detect any play in the CV joint, replacement is necessary. Due to the close proximity of the front driveshaft CV joint to the catalytic converters, the grease in the CV joint cage hardens and looses its ability to lubricate. This lack of lubrication accelerates wear on the driveshaft CV joint. When lubrication is lacking, the joint will begin to bind during acceleration when engine torque flex occurs. This driveshaft torque flex is magnified when turning your Audi left or right.
    Symptom: Quattro driveshaft clanks near the hand e-brake area. This occurs on acceleration or deceleration.
    Repair Solution: Make sure the vehicle is turned off and in park. Inspect the Audi center support bearing. Has the rubber that surrounds the middle of the bearing separated from the bearing bracket? If the rubber has separated from the bracket, replacement of the center support bearing in needed.
    Symptom: Quattro driveshaft has loose rattling noise coming from the underside of the car. This noise sounds like loose pocket change that would be jiggling around in your pockets. You'll hear this noise as you transverse the gears, upshifting between 1st and 3rd gear. This noise also occurs at deceleration when you let off the gas pedal and slow down.
    Jeff
    2000 S4
    Revo w/SPS3
    ST Coilovers
    other stuff
    May 28 2010
    Awesome post! Thank you.
    Unfortunately (and possibly fortunately as well.. we'll see) none of those are really anything like what's going on for me.
    After driving 30+ miles my car develops an intense vibration. The vibration is felt in the shifter to start with but soon is shaking the whole car. After the vibration persists for a bit I start getting a loud "clunk", that I can feel as well as hear, from what seems to be under the driver's side floor. The vibration and "clunk" are both vehicle speed related, not engine/tranny speed, as the noise and vibrations persist even when in neutral. This obviously leads me to believe that the problem lies with something that is spinning as the wheels do regardless of gear. I have checked the 1/2 axles, all the suspension components, and everything else within sight under there and nothing seems broken, damage, or loose. I'm at an absolute loss.
    I believe I finally almost broke whatever it is that's causing this problem because now the vibrations and "clunk" occur when pulling out of the driveway and beginning driving. I really need another set of jackstands. That way I could get the car completely in the air and have someone get it up to 10-15mph and see what is happening.
    Dec 29 2008
    ABQ
    Sounds like we have the same issue. At this point, i am really leaning towards the driveshaft carrier bearing. Although mine is still there, the rubber does not have much rigidity to it. I can very easliy move the drive shaft around the inside of the carrier bearing rubber. I believe the clunk is the driveshaft hitting the metal ring of the carrier bearing.
    I believe this could also be caused by a bad CV joint at either end and the combination of the worn rubber in the carrier bearing.
    I am going to take the plunge and by a rebuilt driveshaft. I hope that will solve my issue and I don't spend all that money and still have a vibration.
    I am going to change my motor mounts in the near future as well. Even though I don't see anything leaking out of them, it seems to me that my motor vibrates just a little too much sitting at idle.
    I'll keep you up to date in hopes of helping anyone else with this issue.
    I should have eveything installed no later that the first of the year. (What a way to spend Christmas break, lol)
    May 28 2010
    Quote Originally Posted by chirp View Post
    I just got my car off the jackstands and went for a little drive. Once again, it took a few miles fro the problem to kick in but this time I was really really searching. I'm pretty sure my problem is NOT coming from the driveshaft. What it sounds the most like is a bad CV on the front left. The only problem with THAT is that the whole 1/2 axle was replaced ~5k miles ago! If that's the problem I'll be thankful and happy because it's an easy fix, but then I'll be insanely pissed because something is very wrong there to wear out in that short of time.
    And yes, please keep us updated. I'll be doing the same.
    2000 IY S4 6MT
    APR 93oct Flash
    May 28 2010
    Quick video while driving. This noise is coming from driver's front, and every time it "clunks" I can feel it in my feet. Normally this is accompanied by an intense vibration, however today it did not get to that point. This was just a few feet from my house on some little back roads so I'd be close if anything happened.
    http://smg.photobucket.com/albums/v2...rent=CLUNK.mp4
    And yes I have a brake light out... I just can't find the freaking bulbs I bought...
    2000 IY S4 6MT
    APR 93oct Flash
    Dec 29 2008
    ABQ
    Order a remanufactured driveshaft today. Hopefully have it on next week.
    Will keep you guys posted for all the others that have a similar vibration.
    Keep your fingers crossed for me!
    May 14 2009
    Renton, WA
    under your feet? Not a driveshaft in my opinion.
    Possibly lower control arms or some sort of frame/sub frame bolt that might be loose. Heck, at this point, maybe even motor mounts, but those are not near your feet.
    Does the situation worsen when turning (if so, probably out cv or wheel bearing).
    I'm betting cv joint since the problem seems unrelated to engine speed.
    Jeff
    2000 S4
    Revo w/SPS3
    ST Coilovers
    other stuff
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    I had a front axel go bad and the entire car would vibrate at low or high speed, OP gl either way
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    May 28 2010
    Sorry I jacked your thread chirp! I just figured since we're all having similar MYSTERY vibrations it might help to keep all the data piled into one thread. Good luck with your install, man, I hope it fixes it for you.
    2000 IY S4 6MT
    APR 93oct Flash
    Dec 29 2008
    ABQ
    I feel mine under my feet as well. I also hear/ feel the driveshaft hitting the right under my arm rest. The rubber in the carrier bearing is so wore out that it is allowing the driveshaft to smack the metal ring that holds the carrier bearing.
    We'll see for sure. Driveshaft will be here Fri. I hope I have time this weekend. If not it will be in the first of next week.
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Did you get this fixed?
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Dec 29 2008
    ABQ
    Quote Originally Posted by Dimcorner View Post
    Mine is up on jackstands right now with a new driveshaft. I gotta hang the exhaust here in a few minutes and take a test drive. I am pretty sure my center bearing on the driveshaft was the root of my 65+ mph vibration. However, I think i also have an engine vibration, which may have caused the center bearing to wear out.
    With the car on jackstands, in gear, at idle, I have a slight thumping sorta vibration. Could be a cylinder missfiring or maybe the motor mounts.
    Plans are...
    Test drive to see if I got rid of the highway speed severe vibration
    Engine mounts and spark plugs next week.
    I think I may have had 2 vibrations. The highway vibrations would happen even if I took the car out of gear and let it roll down the highway, so I don't think that sever vibration is the same that I am now feeling at idle.
    More to come...
    May 28 2010
    Good update, chirp, and good luck with your ongoing work.
    2000 IY S4 6MT
    APR 93oct Flash
    May 16 2008
    South Texas
    We had a couple cars come in with the replacement center rubber bearings broken after about 2 years. The replacements don't appear to last as long as the factory pieces. Hence our motivation to offer single piece units.
    Technically after dissassembly your also supposed to have the driveshaft rebalanced.
    Sep 27 2007
    Columbia, SC
    Scott, sent you an email and I'm probably going to order the drive shaft (my center support can be deflected about 1" by pushing the drive shaft). Are they on hand?
    96 Soarer GT - Gone
    Dec 29 2008
    ABQ
    Well, back to the drawing board. Although the new driveshaft did take some slop out of my drivetrain, it did nothing for my vibration.
    Feb 06 2010
    Albuquerque NM
    oh man sorry to hear that, im having similar problems and dreading finding out its either the diff or tranny :(
    May 16 2008
    South Texas
    I'm out of the steel shaft but have an aluminum unit in stock.
    Sep 27 2007
    Columbia, SC
    did you replace the cv ends as well?
    96 Soarer GT - Gone
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    Quote Originally Posted by Scotty@Advanced View Post
    Remember I do have a set of ends you can use if he opts for steel, Can be put together very quickly. Also have cvs here to repack. Just need the end caps.
    Mar 21 2005
    2019 RS5 SB / 2025 SQ7
    RI
    Is there any added vibration with the single piece units? IIRC some people tried single piece units in the past and had vibration issues.
