Results 1 to 10 of 10
    Veteran Member Three Rings mkemk3's Avatar
    Oct 11 2010
    Central MA
    oil temp gauge not functioning
    oil temp gauge is not functioning any ideas what this is?
    Thanks Guys!
    Jul 26 2009
    00 S4, 01 S4, 93 RX7 LS1/T56
    Dallas
    Probably the oil temp sender since they go out pretty frequently. Get a factory replacement (not aftermarket since they don't usually work). Replace it when you change your oil as it's in the bottom of the pan.
    Chris Sanders
    02 A4 Avant
    01 Noggy S4
    00 BB S4
    1993 RX7 w LS1/T56
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Like was said above, temp sender. Also, to repeat, only the OEM one works on these cars, the aftermarket ones don't work for some reason, so don't waste your time/money trying to get the cheap version.
    -Darrick
    Oct 11 2010
    Central MA
    anyone have an image? and cost of part?
    Jan 29 2007
    08 S4 00 S4
    MD
    It's right in the bottom of the oil pan. You can't miss it. Part number 1J0907660B, between 60 and 90 dollars depending on where you go. Shop it around.
    08 S4- Stock SOLD
    Veteran Member Four Rings S4UCE's Avatar
    Aug 21 2007
    Fairfield County, CT
    Do you have the yellow oil light with "SENSOR" on your center display? As said, you need the OEM replacement. You have to drain the oil to change the sensor.
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by mkemk3 View Post
    http://jhmotorsports.com/shop/catalo...cf8cdc86e2da77
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Oct 11 2010
    Central MA
    thanks guys that is exactly what i thought it was the guy at the audi parts dept to me it was a oil level sensor and neglected to say that it was also the temp sensor thanks again for the help this will be an easy fix
    Veteran Member Three Rings omgwtfbbq!'s Avatar
    Jul 08 2009
    Daytona Beach, Fl
    Yep, drain the oil, unplug, remove 3 10mm bolts and reverse to install the new one, it takes about 10 minutes on top of the oil change.
    01 Sedan /// Brilliant Black ///F4H Frankenturbos w/ tubular manifolds /// J-Fonz stage 3- /// Borla 3" /// Darintake
    I hate: FMICs, flat colors, A-pillar gauge pods, vented hoods, drilled brake rotors, SSAC products, Rotas, you
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by S4UCE View Post
    Not all the cars will tell you your sensor is out the way yours does. If yours is on the fritz like mine was before replacing it, I noticed it would be cold for a good 10-15 minutes, then one day I caught it literally just shoot up to 200. I was like WOW - that's some insane temperature change. Then I changed it, then life was better.
    OP - For the love of God do NOT cheap out and get another brand. Get the one that was linked above from JHM. You need OEM Hella.
