Page 1 of 5 123 ... LastLast
Results 1 to 40 of 169
    Established Member Two Rings iloveturbo's Avatar
    Jul 18 2009
    2005 Audi A4
    [Discussion] Gear Ratio for 01E & 01A
    Hi guys,
    I been looking into the possibility of developing a full set of custom gear aiming to improve 1/4 mile time(My setup - HTA3586, 2.1L, B6 3.0 01E). I noticed EVO with has somewhat similar powerband achieve 11s (or even 10s) rather easily in comparison to Audi/vw platform. Now I am not a expert in transmission or anything but I think the gear ratio in those cars are much better suited for that propose (close-ratio). Having said that, I would like to hear your opinion on what gear ratio would you like to see in the B5/B6 platform that would further elevate our platform? I mean think about it. If by swapping out 3rd and 4th gear in the 5-speed 01A would shave off 0.5 seconds, I think it would be a worthy options for the guys who having put so much heart and soul into their builds.
    I took the time to plug the ratios I found around the net into gear ratio calculators. I thought some of you guys may find them useful.
    1.8T 5-SPD B6
    1.8T 6-SPD Quattro (B6, B7)
    B5 S4
    B6 3.0 01E
    B6 S4 0A3 [added 12.15.2010]
    Advanced automotion 01E Close-ratio
    Advanced automotion Drag Race Dog box
    EVO7
    AA suggested gear ratio [added 12.15.2010]
    Looks like Advanced Automtion Dog box recommended gear ratios are fairly close to EVO's offering.
    Please chime in if you have any thoughts or experience in this regard.
    -Howard
    Aug 17 2009
    Pittsburgh
    For the price involved, get a new car if you want a drag car-seriously. Aside from that, though, if the input and output shafts are the same on each trans, I'd just swap the 3rd and 4th from the 5spd into the 3.0 6spd and leave everything else alone internally, then change to a 4.11 final drive. You DONT want a dogbox on a car that you drive everyday, i promise you that. Also, if you look at the ratios vs speed vs rpm, you'll notice that your trans, as well as the B5s4 and the 1.8t 6 spd are all very well suited to an 11ish second trap time as it will put you right at the top of 4th according to your shift point of 7500-i assume your shift points are based on peak power production since you are talking about drag racing. The less amount of times you have to shift the better for sure. The Dog Box is just about in line with that. Honestly, I think a 4.11 final drive would do you wonders alone, without needing to go inside the trans. Also, a WOTBOX will easily knock .5 seconds off of an 12 sec et. The EVO trans is really not designed well for drag racing. It shines in tight corners where it can easily be kept in the sweet spot. You have to remember that transmission gear ratios are designed around the specific power of the engine and its peak power rpm.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Many people run the B5 A4 transmission that have good power (they are cheaper to replace and you will be replacing them when you break yours) which has different gearing (longer 4th and 5th), and as for the post above:
    You won't be at the top of 4th with a B5 A4 tranny for sure, I can't remember how it was with my B6 A4 tranny, I believe I am around 6200rpm (my limiter is at 8000 and I shift around 7800) when I have crossed the line so far at the 1/4 mile. My car will do right at 150mph in 4th at 8000rpm for reference and I think 7500 is at 140mph.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jul 18 2009
    2005 Audi A4
    Quote Originally Posted by hercfe View Post
    True to some degree but then, we are assuming we are sticking with this platform because that's what we love. As for the Dog box, it's out of the question. It's not suited for daily purpose.
    Quote Originally Posted by A4 TSCHUSS View Post
    David, based on your experiences you would say taller 4th helped your time?
    Now, does anyone happen to know the maximum operating temperature is like in 01A /01E transmission?
    Please help as this would greatly affect the type of surface coating we would need to apply. Thank you in advance.
    -Howard
    Apr 24 2005
    E55 AMG, CTS-V
    No I would say the b5 tranny hurt the time, gear is to long and car is lower in the rpm band going through the traps. Another example I can give you is Mike Hood swapped a b5 2.8 transmission (even longer gearing than b5 1.8t, more closely resembling the b5 s4) out of his car for the b5 1.8t again and gained like 7mph and almost a half second if I remember right.
    No matter what you do you are going to have to shift to 4th so I would want the shortest gears to get there.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by iloveturbo View Post
    considering Redline MT90 has a flash point of 465F then I'd probably assume nothing higher than that. Maybe estimate 500F to be conservative? Otherwise, I have no idea. I do know the case is too hot to touch after many hours of usage.
    -Doug
    Established Member Two Rings dwalmop's Avatar
    Apr 15 2010
    2013 A6 Prestige, 1990 Audi CQ, Gone: B6 A4 Avant 1.8TQM
    Hudson, WI
    OP, what source did you find all of your ratios from?
    Jul 18 2009
    2005 Audi A4
    Doug, Thanks for the info. That makes sense.
    So shorter gears are better (3rd and 4th). Are you trapping around 116~120mph with your new Precision turbo?
    Quote Originally Posted by dwalmop View Post
    Audigeeks
    Apr 24 2005
    E55 AMG, CTS-V
    116.8mph with my 30r, I had lots of clutch/tranny problems when I went once with new turbo.
    Veteran Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    B6 A4 USP - B5 VR6T Avant
    Buffalo, NY
    I'm interested in helping to make a more even spread(ratio-wise), affordable gearset for 01e's if anyone knows a company that can help. I would love a short 1-2 and 2-3 drop. These cars would be a LOT more competitive then. No sense in even screwing around with 01a's if you're trying to make a strong gearset.
    The AA set would be great, but anything over $5k is too much.
    I believe clint knew some guy............ he never came back with any info though........ ???
    1990 Audi Coupe Quattro - 4.0t 6spd swapped
    4.60 60-130mph Xona 10569s E70
    Jul 29 2008
    2003 A4 1.8TQM5
    PA
    Quote Originally Posted by Haenszel20v View Post
    Why not the 01A?
    Jul 18 2009
    2005 Audi A4
    Brian, if you are offered a chance with full custom gear set for 01E. What ratio will you go with for 1.8T, 2.7T, and your VR6T.
    -Howard
    Jul 18 2009
    2005 Audi A4
    Quote Originally Posted by Kamin View Post
    Why not the 01A?
    After a brief conversation with David and checking out his threads [search under his name, title: transmission]. I think 01A may not be the best candidate for gear buildup. The output shaft could be the weak link, not just the gear itself (to my understanding.)
    -Howard
    Jul 29 2008
    2003 A4 1.8TQM5
    PA
    I just read about that in another thread actually. That sucks.
    Oct 05 2008
    Buffalo, NY
    Why not the 01A?
    at stated earlier the width of the gears simply isn't there. No matter what you do they're going to break because each gear itself isn't wide enough(less material).
    -Howard
    I'm not sure right now. Looking at the AA one it seems to be pretty good, although it requires 4 shifts which isn't the greatest.
    PAR has 2 sets ** the first of which I believe to be what AA is selling.
    Ratios:
    - Option 1: 3.10, 2.18, 1.57, 1.18, 0.96, 0.85
    - Option 2: 3.10, 1.92, 1.31, 0.95
    option 2 has a WICKED spread to keep the quarter in 4 gears(148mph in 4th at 7500). The problem with this is that it still has a ~2800rpm 1->2 and 2383rpm 2->3 drop. Getting first below 2500 and 3->4 closer to 2000rpm drop would help significantly. Obviously brings us right back to the issue of having to shift into 5th again though.
    Veteran Member Four Rings drjonez's Avatar
    Oct 27 2009
    2011 Q7 TDI Prestige, '72 Nova
    The Cheese State
    Some great info here, I'm save those images now!
    What are you trap speeds? Best 60'? Your 19s aren't helping I'd imagine...
    A few thoughts looking at ratios- the first to second RPM drop may be putting you out of the powerband, which will kill your ET. Other than that, you're going to be shifting to 4th regardless of what transmission you're using. Keep the RPM drops reasonable.
    '11 Q7 TDI Prestige
    Function > Form
    Oct 05 2008
    Buffalo, NY
    This might work. Keep stock 5th and 6th so 5th doesn't max out at 147(at 7500), and would cut the cost down not having to buy 2 extra gears. Damn close to evo gearing which has been proven to work well with the same powerband.
    3.1 2226 46
    2.18 2099 65
    1.57 1863 90
    1.18 2034 120
    0.86 1570 164
    0.68 - - - 207
    4.11
    I dunno, just throwing around things in my head.
    Sorry, I can't upload screenshots at work. This is all I got.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Wasn't that Jim? http://www.audizine.com/forum/showthread.php/305365
    Or are you thinking of someone altogether different?
    -Doug
    Oct 05 2008
    Buffalo, NY
    I dunno, Clint was all "Yo bro, I got dis dood in in china dat knows this dood who owns a gear factory, he's totally down bro" one day..... never heard anything more.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Now you have heard.. Its the OP in this thread
    (hahaha.. I can totally see Clint saying that in those words. Complete with the two 'in's. haha)
    -Doug
    Apr 15 2010
    Hudson, WI
    Audigeeks[/QUOTE]
    Thanks - I've been trying to do some research myself.
    Oct 22 2005
    Reppin the Mitten.
    raf out roud
    Jul 18 2009
    2005 Audi A4
    Taiwan... not China... but whaeva that "dood" Clint iz referring to would be me yo... (in Clint's voice)
    3.1 2226 46
    2.18 2099 65
    1.57 1863 90
    1.18 2034 120
    0.86 1570 164
    0.68 - - - 207
    4.11
    Brian, that looks good. But for the pure performance perspective, I say AA dog box ratio is pretty close to optimal for quarter mile.
    -Howard
    Jun 22 2009
    Dundalk, MD
    FYI, doing a little more research on the subject but it appears that to do a 6 speed B6 S4 swap all you would need is the trans and linkage and every single other thing would bolt right up. They can handle some serious power
    EDIT: It has a slightly longer first and second, and a shorter 3rd and 4th
    Jul 18 2009
    2005 Audi A4
    Quote Originally Posted by [email protected]. View Post
    Clint, does that mean you will be joining the 01E bandwagon soon too?
    Do iiiit!
    -Howard
    Veteran Member Four Rings a408's Avatar
    Nov 06 2008
    Orange County, CA
    in
    @Boden_AutoHaus
    2021 Merlin Purple RS6 Avant
    2021 Grigio Scuro F8 tributo
    2020 Aston Martin Vantage
    Apr 24 2005
    E55 AMG, CTS-V
    Pretty sure Jeff Lee has the B6 S4 tranny in his car, he could tell you for sure what needs to be swapped and how it works. The gearing is the same (final drive was, 3.89) but is the rear diff the same as in size wise unlike the B5 S4 how the front is longer? And the axle connection points are the same size or are pressed in like the A4s and can be swapped with ours?
    ~David~
    CTS-V 9.6@148
    Established Member Two Rings AfourQ's Avatar
    May 27 2005
    B7 RS4
    Montreal
    That is what i want to use as well! Not so easy to find at a reasonable price.....could always steal my wife's though :P....
    SRM BB RS6 K24 3.0T (2.7T stroker) swap by Rombotis Tuning.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Do iiiit!
    -Howard
    No, because the B6 S4 is not an 01E.
    You need shift linkage, shifter, trans, trans mount, prop shaft and maybe front driveshafts (not sure on that one). Rear diff should be the same as your 5spd.
    -Doug
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Jeff has an 01E.
    -Doug
    Sep 12 2008
    South Central PA
    isnt the B6S4 trans a 01X or something?
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Jul 18 2009
    2005 Audi A4
    Opps, my bad. Thank you for clearing it up.
    Quote Originally Posted by Dan[FN]5857 View Post
    0A3
    Source: JHM rebuild thread
    May 16 2008
    South Texas
    But not nearly as much as the 01E. Also the 01E was installed in the B6, so you can use those parts to make it a drop in.
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    Ugh so much misinformation with transmissions, it makes my head hurt. Not saying I know anything about 'em, just that everyone is posting something different for gear ratios, final drives, transmission codes, and requirements for swaps. I guess I'm just stating the obvious though.
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
    May 16 2008
    South Texas
    Ratios:
    Yes we have PAR make all our custom stuff but that is about to change, for the better and less expensive.
    I've put the following ratios in a few cars that look very good on paper.. These work GREAT for the larger engines that have some torque, but the high first gear might be detrimental to a 1.8. The 4th gear is just tall enough to avoid a shift into 5th with a slightly elevated rev limiter.
    First 2.8
    Second 1.75
    third 1.23
    Fourth .97
    5th .81
    6th .68
    The cost for one of these with the stock S4 5th and 6th gears is right near $5,000 bucks.
    Oct 05 2008
    Buffalo, NY
    Quote Originally Posted by vintagespin View Post
    I don't see much misinformation at all besides speaking of the b6 s4 trans which was like two posts. This is a brainstorming thread about creating a better gearbox.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    and guess who started that?
    -Doug
    May 16 2008
    South Texas
    Our thermometer registers 210-230 degrees on our test bench with no air cooling at a 8KW load and 3500 rpm. Under abuse 300 degree temps are likely not out of the usual.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Scotty@Advanced View Post
    I was a little too conservative then. Not a bad first guess though.
    Glad you are contributing to this thread, Scotty. Your expertise is warrantied.
    -Doug
    Sep 15 2008
    CO
    I didn't mean this thread specifically. It was more of a blanket statement for what I've seen in the B6 section.
