Originally Posted by
b5power
so my oil pan is leaking and i want to replace the gasket with a new one but some people are telling me i dont need one and just seal it without a gasket, is that true? or should i just get a gasket to be safe. please let me know and whats the best way to remove the oil pan. Im planning on doing it tomorrow. thanks.
had the same problem on my 1.8t passat. When i took of the oil pan it did not have an actual gasket, it was a gas ket in a tube, and that is what the dealer gave me, an audi brand gasket maker in a tube. Should be the same for u. Same engines.
I had some fun getting the oil pan out after i unbolted it, had to drop the engine with the sub-frame a little but i did all that on a car lift, nothing that hard, will be a bit more toying on the ground and
good luck let me know how it goes.
