Results 1 to 14 of 14
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    Woah....DIY headlight reflector mod on B8 A4 doable on the S5?! Link inside....
    Has anyone tried this?? I might be the guinea pig if no one has tried it yet....
    http://www.audizine.com/forum/showth...int+headlights
    -Chris
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Oct 08 2010
    CA
    I haven't seen anyone try it. I'll do it if you do it....lol
    Jan 27 2010
    Cayenne%20X5
    Long Island, Queens, LA
    i would pay someone to do that on my car.
    ig: gs.autogram
    Jan 31 2010
    S-Line A6
    East Haven, CT
    DO IT!
    i used a heat gun to pull the lens off my A6's headlights
    its way easier then i thought it would be, soooo glad i did it now
    Apr 28 2010
    2013 RS5 Ibis White w/ NAV / Lunar Silver interior
    Tacoma, Wa
    I did the oven method for my Mini cooper S Xenon Joey mod. I figured my Xenon run hotter than the Oven at 200F for 5 min. Not brave enough yet to do this on my S5 or A4 yet, I may have to try the heat gun method.
    2013 RS5 Ibis White /NAV/B&O
    Oct 08 2010
    CA
    I did this with my 2006 4Runner. Used a heat gun to separate the fixture, blackhoused accordingly, then heat sealed everything back together.
    Although, that was a 4runner. This is a $50k+ car where replacement parts are costly. Dammit. I want to do this mod this weekend...everything makes sense. It is also straight forward. :/
    Previous
    2009 GT-R | 700HP
    2008 S5 | Ibis White
    2008 A5 | Matte Gray
    Oct 08 2010
    CA
    I am going to do this mod right now, I will post results when I am finished
    Previous
    2009 GT-R | 700HP
    Jan 27 2010
    Cayenne%20X5
    Quote Originally Posted by darellconnolly View Post
    apparently an oven will burn out the LED circuits.
    ig: gs.autogram
    Jan 27 2010
    Cayenne%20X5
    Quote Originally Posted by ecrew16 View Post
    really looking forward to the results
    ig: gs.autogram
    Oct 08 2010
    CA
    Here are my results:
    I was very timid at first. Taking the headlight fixture from the body was a bit of a pain for a couple minutes...a lot of wiggling and muscle. The headlight is fitted on tracks so it fits perfectly in the spot where it is supposed to go. Eventually, I could not get the freaking fixture separated with my heat gun. I was going over the sealant for probably 20 minutes without a budge. If I could have just got it open.....damn. Anybody have more experience with doing this sort of thing? The silicone didn't look like it was being phased at all, just a little bit of cracking but that was it. FML..once you have access to the inside of the fixture it is cake from there. When I did this on my T4R you could physically see the silicone melting and you could slowly start separating the lens cover from the fixture after maybe 5-6 minutes of consistent heat gunning. Excuse me if I am rambling, its in the morning hours, had a couple beers, staring at an lcd screen. I just want this to work!!!
    Previous
    2009 GT-R | 700HP
    Veteran Member Three Rings AudisticS5's Avatar
    Oct 03 2009
    LA, CA
    oh goodness I wish I saw this post earlier so i could have stopped you guys. NO... for the A5/S5 our lights cannot be taken apart. They are made by Valeo, and is a different manufacturer from the A4 headlights. The new glue that Valeo uses for our lights is really stubborn stuff.... you'll likely be melting and moulding your plastic before that glue gives in. Even if you do manage to pry them apart I can't imagine what they'll look like when you're ready to re-assemble them. You may end up with sealing issues, and the shape may even become warped. I tried and tried... luckily I was able to experiment with a set of old non-LED headlights that no one wanted so I didn't wreck my own. It wasn't long after that I just invested in a set of ecodes.
    '09 S5 - Phantom Blk, Magma, 6MT, Tech, Nav, B&O, Drive Select, Adaptive Cruise, Carbon Atlas
    H&R Sport Springs, 20" DPE S10, Cargraphic Sound-Export Exhaust, Black optics, Pinnacle F1 film, Ecode headlights, Ecode/LED taillight conversion
    Sep 30 2009
    b
    Maybe you would have been successful with one less beer in you ;)
    Sep 16 2006
    SOLD: RS5
    I think the problem is that you're drinking Coors and Budweiser.
    __
    SOLD: []RS 5
    Suzuka Grey Pearl
    HRE|Bilstein|AccuAir|Capristo
    Oct 08 2010
    CA
    Well there's the issue. The headlights can not be taken apart because they are made by Valeo, end of story.
    E-codes it is.
