Results 1 to 9 of 9
    Nov 30 2010
    WV
    Turbo Wastegate Malfuction?
    Hey all, just got an 04 audi a4 1.8t quattro 2 weeks ago and I love the car. However, I was traveling on the interstate on Friday and the CEL came on and it was a P0243 Turbo wastegate solenoid malfuction. I cleared the code at Advanced Auto and started up again and it came back. I couldn't find any troubleshooting information on this particular code so I was looking for some advice. N75 valve? Some other problem? Seems that I have very little or no boost but I don't have a gauge to confirm that. Any help would be appreciated!
    Also, thanks to all for the good info I've been reading so far.
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    10 A4 Avant S-line, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    Sounds like an N75. The likelihood of the actual wastegate failing is much less likely. Especially since n75's dying is a fairly common thing.
    If the N75 valve fails it can't block the signal going to the wastegate actuator so the full pressure signal is always acting on the wastegate. It's a failsafe....the n75s fail open.
    ~Chris
    I sold my Audis and bought a Touareg... Catch me over at Club Touareg
    My B6 Avant GT2871R build
    Tumblr
    "Robert Bosch don't fuck around"
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    unplug the N75 and see if you get around 6-8lbs of boost.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Nov 29 2005
    Edmonton, AB
    Quote Originally Posted by Audi Skate Snow View Post
    Quote Originally Posted by joshsill View Post
    It's going to be hard to sort this out without being able to see results.
    ~Chris
    Tumblr
    Mar 31 2004
    CA
    shit didnt see that. ahah I swear EVERY turbo car in the world.... stock or modified should have a boost gauge. It is the best diagnostic tool there is!
    Mar 27 2008
    Denver
    So true^
    Nov 30 2010
    WV
    I ordered a vag cable and it should be here today. Can I read or log boost with the free software version? Which is the best site to purchase a new N75 if I have to? I also see mixed reviews about which to get, revision e (stock?) or f (?) or g (performance). What would be recommended? Everything is all stock in my 1.8t and I'm not too worried about increasing HP or anything. Are there any other tests I can perform to make sure it is the N75? What voltages or resistances I should be getting across the n75 itself or the harness plug?
    Thanks for all the help!
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    You won't be able to do much other than read and clear codes with the free software. If you replace the N75 go with the stock one. You can check resistance on your N75 to see if it checks out. You should be able to find a part number on your N75. If it isn't in the recommended range replace it.
    058-906-283-C 20-30 ohm
    058-906-283-F 25-35 ohm
    034-906-283-H 25-45 ohm
    034-906-283-J 20-40 ohm
    034-906-283-K 20-40 ohm
    Nov 30 2010
    WV
    Great info, thanks! I'll give that a check. Also, if I check the harness plug coming from the car to make sure my wiring is OK, when should I be reading voltage? Key on, off, when starting, running?
