Results 1 to 18 of 18
    Senior Member Three Rings Aureus1's Avatar
    Feb 06 2010
    06 Mustang GT, 2006 F350 Diesel, 1997 Jeep Grand Cherokee, 2012 Focus SEL Hatch, 1991 MK1 Cabriolet
    TheCommonWealth
    Cost to replace clutch and flywheel?
    Hey guys just curious as to what you've been quoted labor-wise to replace your clutch and flywheel. Finally got my brakes done and now my clutch is starting to slip...
    "You love your car as much as you hate it..." - my GF
    GSE www.granitestateeuropean.com
    Team Sad Panda
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    are you a DIY'er?? ..that would be my suggestion. im guessing like 13 hrs labor is what a shop would charge.. that or more...so probably 1100-1400 bucks labor plus parts..
    RS6 hybrids and corn
    Jul 25 2010
    Ma
    it was 500 for labor to do my clutch flywheel and slave cylinder this summer
    Sep 28 2009
    ky
    Quote Originally Posted by b6nukka View Post
    where?? so pretty much $35-40 an hour.. IDK where you can get that price. we are being realistic here.. no optimistic, best friend or neighbor across the street prices..
    Jul 25 2010
    Ma
    hahaha I forget the name of the shop only been there once but the guy got my clutch and flywheel in the shop friday morning and had it done that after noon so he knew what he was doing. I'm just saying how much it cost me but if Auresu1 looks around he should be able to find something under a grand.
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    Find someone that will charge you 60 bucks an hr because they will prolly charge you up to 13hrs labor. Its a pretty extensive job. Otherwise expect to pay up to 1100+ plus cost of parts. Make sure flywheel is resurfaced or you buy new flywheel or your going to have a slipping or poor operating clutch soon after the job is done.
    Senior Member Two Rings nycion's Avatar
    Nov 30 2009
    AVWDIS
    Empire State
    $400-$500 labor max at german shop. Everything except flywheel is $350 and it takes about 2.5 hours.
    Feb 06 2010
    TheCommonWealth
    Yeah I was planing on going with the ECS stage 3 clutch kit with lightweight flywheel. http://www.ecstuning.com/Audi-B5_S4-...ES1329/Notify/
    There are a few shops around me, I'm going to make some calls on Monday to get some prices. Thanks for all the input guys!
    Team Sad Panda
    May 16 2008
    South Texas
    Quote Originally Posted by Aureus1 View Post
    I can help out with a Southbend clutch and LWFW Setup. The parts are in stock at our warehouses and ready to ship, unlike other companies.
    Veteran Member Four Rings morris400's Avatar
    Dec 18 2008
    2016 VW GTI, 1994 Audi S4
    Alberta, Canada
    I paid 2600 in January 2008 for clutch and flywheel.
    Senior Member Three Rings werewolves182's Avatar
    Jul 01 2008
    Annapolis, MD
    I'm taking my lunch break right now from changing a clutch and flywheel in an A6 2.7t, just about to put the trans back in. If you have a lift it really doesn't take that long, however, I can tell you that book time for changing a clutch on a S4 or A6 2.7t is 16.6 hours. That should give you a reference to see what other shows charge.
    1999.5 Volcano Mica A4 1.8t: SOLD
    2000 Nogaro S4 6sp: RIP thanks to a very icy road. PARTING OUT!
    1999 Santorin A6 Avant: SOLD
    2000 Gold A6 4.2 Sport: Parting out
    2001 Black A6 4.2 Sport 6sp
    Sep 11 2009
    NE
    The funny part is that once you have a lift and tranny jack, the book time is pure abstraction and an example of how to overcharge people. With the lift+jack, you're literally looking at fairly straightforward job:
    - undo bellhousing/started bolts, 8-10 total?
    - undo slave cylinder - 1 bolt
    - undo both front axles - several bolts each
    - undo prop shaft - several bolts
    - undo your shifter box from inside of car, it will come down with the tranny.
    - disconnect two sensors (maybe three, don't remember)
    - down it goes, watch for O2 sensor wires, some might be zip tied to tranny.
    Rest is very quick and simple clutch swap:
    - undo 6 pressure plate bolts, clutch pops right off.
    - undo 8 flywheel bolts
    - new parts install is reverse of above but observe torque ratings (use new bolts for flywheel and pressure plate!) and use alignment tool and putting pressure plate back on.
    Do input shaft seal while at it, takes 5 minutes with 4.5 minutes of thinking how to get at it if this is your first time.
    Even with pulling the engine out with tranny you could easily take less than 16.6h.
    Veteran Member Four Rings adr3naline fix's Avatar
    Dec 17 2008
    Sold 01 1.8T, 05 Mini Cooper S JCW, 04 ZX10R Track
    Milwaukee
    My philosophy on big labor jobs:
    Tools + your Weekend = New knowledge & "free" tools!
    My car is SOLD
    2001.5 1.8TQM || GT2871R Hybrid Elim @ 24psi | Unitronics Custom | 307awhp | etc | $15k+ in parts alone
    Veteran Member Four Rings Dutchsider's Avatar
    Aug 19 2010
    NEPA
    Quote Originally Posted by adr3naline fix View Post
    That's a great way to look at it. It doesn't involve any real technical abilities, just basically unbolting stuff and then putting it all back together.
    But FYI, I contacted AP Tuning and they quoted me 1100-1200 for the job with an RS4 clutch kit and resurfaced flywheel. They said that it was an 8-9 hour job on the book.
    Dec 17 2008
    Milwaukee
    Quote Originally Posted by Dutchsider View Post
    w/ Parts & flywheel turning that's not bad.
    My car is SOLD
    Aug 19 2010
    NEPA
    I agree, but i wanted to do this myself to be able check everything out in the engine bay while I was at it.
    Sep 16 2005
    Asheville, NC
    I should really make this my sig. Kudos for putting my thoughts into words.
    2000 S4 - SSP tuned Stage 3
    CrtchRktRcr: You could turn it into a unicorn with a gigantic pink dildo and i'd still love a b5s4.
    Sep 28 2009
    ky
    mitchell quoted 13 hrs for the job. not sure about alldata..
