Results 1 to 9 of 9
    Jan 04 2009
    2004 A4
    Las Vegas
    Temp gauge goes down when heater turns on
    Everytime I turn my heater on my tempature gauge goes 1/4 lower on the guage. Also my car takes long to heat up. I have no leaks and I my coolant level is good. Is this my thermostat?
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    10 A4 Avant S-line, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    sounds like your thermostat
    I had debris in my engine block coolant passages that kept getting into my thermostat and not allowing the valve to full close which allowed coolant to the radiator. My car would take forever to warm up and sometimes just wouldn't. I changed the thermostat and it didn't solve the issue. I finally found out what the culprit was when i inspected my old t-stat as well as when I tore down the block to do my engine build.
    ~Chris
    I sold my Audis and bought a Touareg... Catch me over at Club Touareg
    My B6 Avant GT2871R build
    Tumblr
    "Robert Bosch don't fuck around"
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    ^x 2 on thermostat. Had same issue with mine.Took about an hour and all was good!
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
    Veteran Member Four Rings s6sputnik's Avatar
    95 S6 rs2//13 A6 3.0T//12 S4
    Austin Texas
    Quote Originally Posted by krisko View Post
    It is probably your thermostat, but do keep in mind that it is the coolant that is used in your heater so things change once you turn it on! I would check your coolant level and keep your eye on the gauges for a few days!
    Shawn
    2222 & 620 Austin TX
    // 95 S6 RS2 // 13 A6 3.0T // 12 S4 3.0T
    Active Member Two Rings rawkey's Avatar
    Mar 26 2006
    Ottawa
    $130 for thermostat at the dealer
    get some G12
    replace the Jplug part# 06B-103-033-A since you're in there
    http://www.audizine.com/forum/showth...at+replacement
    Jun 08 2008
    Calgary AB Canada
    I had the same problem last year and replaced the tstat ant everything was great. This year its not as bad but still cools off a bit while idling with the heat on.
    Could a faulty coolant temp sensor be affecting how the tstat opens and closes?
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    yes, def. thermostat
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Mar 26 2006
    Ottawa
    Quote Originally Posted by onceover View Post
    From my understanding the CTS on the coolant flange sends signal to ecu for temperature monitoring and CTS on rad contols fans.
    Jan 04 2009
    2004 A4
    Las Vegas
    Update.* Im about to change my t-stat but now when I first turn my car on my radiator fans both turn on for about a 10 minutes then will shut off when the car starts to warm up? Whats causing this issue is the temp sensor hooked into the thermostat?
