Results 1 to 18 of 18
    Veteran Member Four Rings Akronnnnnnnn's Avatar
    Jun 21 2010
    04 Audi A4 1.8TQ, 90 Camaro RS
    Akron, OH
    Getting into car with dead battery & doors locked?
    So I went to drive my car tonight and much to my surprise, my battery seems to be dead. The alarm is "set"(the light on the door is solid red instead of flashing) and the doors are locked. My key fob doesn't work either(obviously). I have tried putting my key in the driver's door to unlock manually but that doesn't even work. The key turns but doesn't unlock. The key opens the trunk, however. Does this mean I only have a valet key? I only looked briefly but it doesn't appear that we can get into our cars from the trunk. Hopefully I am mistaken. If I can, I'll just pop the hood and charge the battery.
    Help me??
    -Brian
    Aug 17 2009
    Pittsburgh
    if its on the fob, its not a valet key. it should unlock regardless of the alarm. if it doesn't unlock, your mechanism may be jacked-in which case your SOL.
    Oct 09 2008
    Yes you sound to be SOL.
    The Awesome™
    Jun 22 2009
    Dundalk, MD
    thats really weird your key should manually unlock the driver's door
    Jun 21 2010
    Akron, OH
    nope, it never has either! there's really no way to get in through the trunk though?? :(
    -Brian
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    Not unless you can somehow remove the seat backs, which needs to be done from inside the car. That is really weird though that manual won't do it. Is it the key in your fob? Cause if so that really should do it.
    - Justin -
    Senior Member Three Rings Dubdaze's Avatar
    Jan 20 2010
    03 a4 1.8t
    Tampa Fl
    I unlock my door with the key everytime i get it my car, my fob isnt programmed.
    Jun 21 2010
    Akron, OH
    yep, key in the fob, it turns but nothing unlocks. I don't even know how to go about dealing with this, do I have to break the window and pop the hood just to charge the battery?
    -Brian
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    even with dead/disconnected the keyblade locks and unlocks the doors so it sounds like your locking mechanism is trashed
    Jul 04 2008
    Seattle, Washington
    You might have to. Cause the seat backs need to be folded down to remove them, so you're not gonna get in through the trunk. And if you're key doesn't work, i don't know what else you really can do.
    - Justin -
    Veteran Member Three Rings SKIDMRK's Avatar
    Sep 14 2006
    Monroe, WA
    Put your key in the door lock, turn counter clockwise to unlock position. Continue to hold in unlock position and see if you have enough power to roll down your windows.
    epitome - Like McCormicks, we're seasoned
    achtuning - podi
    Jun 21 2010
    Akron, OH
    well apparently my dad was able to get in through the ski hole in the head of the trunk enough to unlatch the rear seat. We will throw the charger on overnight. Phew, I did not want to break a window.
    I still don't know why my key doesn't unlock my door either. Also, it never rolled down my windows like my B5 did.
    -Brian
    Veteran Member Three Rings karp's Avatar
    Feb 04 2008
    2012 STG2+ S4 and Triumph Daytona 675
    New York
    Quote Originally Posted by Akronnnnnnnn View Post
    thats wat i was about to suggest trying to fold the seat from the ski bag hole haha
    Jul 04 2008
    Seattle, Washington
    Where is this ski bag hole? Is it that plastic door behind the rear armrest/cupholders/first aid kit? I didn't know that's what it was, but it makes perfect sense now lol.
    And that's awesome that you got it. Saved a whole lot of hassle.
    - Justin -
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Lol mine doesn't have a ski bag hole... I was just about to say you should just use the key to roll the windows down.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    Couldnt you have also used a slim jim or w/e?
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Your key should unlock the door manually, if it doesn't your mechanism is broken.
    You can also pop the hood latch from underneath the car if you have a very long screwdriver so you can get to the battery.
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    I haven't had much success with slim jims on newer vag products... especially the audi that doesn't have an actual lock exposed. Most of the time the lock on vw/audi are behind the window parts so you can't get to it.
