Reflective Sound Cancellation allows for maximum exhaust gas flow while completely eliminating in cabin
sound resonance (drone). RSC™ incorporates innovative technologies developed in conjunction with NASA.
With limited use of packing materials and no baffles, RSC™ allows for a completely straight and free flowing
exhaust path through the RSC™ mufflers. Reflective Cancellation bounces the undesirable sound waves into
each other to attenuate the wave and completely eliminate the low frequency tones that create drone.
Each RSC™ muffler is tuned to eliminate specific, undesirable sound frequencies allowing only the engine's
desirable exhaust notes to be heard and improving performance.
3" Design with High Flow Catalytic Converters
APR's 3 inch downpipe with high flow catalyst for the A4 2.0 TFSI is the first true downpipe for the A4 and
the only one that incorporates traditional exhaust performance tuning for the new 2.0 TFSI engine. Other 2.0
TFSI engine applications outside of the A4 chassis have historically enjoyed the following benefits that have
never before been made available to A4 owners:
-3 inch Exhaust Tubing Diameter beginning at the Turbocharger Exit for Maximum Turbocharger Spool and
Peak Horsepower
-Relocation of the Catalyst to Reduce Backpressure and Turbulent Airflow at the Turbocharger
-Incorporation of a 200 Cell Count Catalyst to aid in Turbocharger Spool and Remove Restriction
-Considerable Increases in Peak Horsepower, Peak Torque and Fuel Economy
APR is proud to offer the only true 3 inch full length downpipe available for the 2.0 TFSI A4 which delivers true exhaust Performance Without Compromise.
By utilizing a straight though design, APR is able to maximize power gains when coupled with APR’s Stage 2 ECU
Upgrade without uncomfortable levels of exhaust drone while cruising.
During our development we discovered the exhaust systems flowed so well modifications to the software were
absolutely required when using the new RSC systems. Spool time was significantly decreased and would result in
a rather large overshoot of requested load levels which would cause the throttle to close. This can only be eliminated
by properly recalibrating the engine software to match the hardware changes and APR’s Stage 2 ECU Upgrade is born.
The benefits of APR’s Stage 2 ECU Upgrade with APR’s RSC Dual Exit Full Exhaust System are as follows:
1. Turbocharger Boost Onset Reduced by Over 400 rpm’s!
2. Peak Torque is Increased by Over 100 lb ft when Compared to Stock Exhaust and Programming and by
Over 70 lb ft when Compared to APR’s Stage 1 ECU Upgrade and Stock Exhaust!
3. Peak Horsepower is Increased by Over 50hp when Compared to Stock Exhaust and Programming and by
29hp when Compared to APR’s Stage 1 ECU Upgrade and Stock Exhaust!
We tested both our Dual Exit and Single Exit RSC Exhaust Systems and found the Dual Exit RSC System to
deliver slightly more horsepower in the higher rpm’s as expected.
Now for the numbers as measured by APR!
Stock – 212 HP & 260 TQ
Stage 1 91 Octane – 229 HP & 323 TQ
Stage 2 91 Octane – 239 HP & 353 TQ
Stage 1 93 Octane – 234 HP & 333 TQ
Stage 2 93 Octane – 242 HP & 362 TQ
Stage 1 100 Octane – 268 HP & 338 TQ
Stage 2 100 Octane – 270 HP & 380 TQ
The most impressive aspect of APR’s Stage 1 and 2 ECU Upgrades are the gains they make over
stock at different RPM’s:
Stage 1 91 Octane – 35 HP @ 5500 RPM & 64 TQ @ 2250 RPM
Stage 2 91 Octane – 43 HP @ 2650 RPM & 86 TQ @ 2650 RPM
Stage 1 93 Octane – 40 HP @ 5500 RPM & 74 TQ @ 2250 RPM
Stage 2 93 Octane – 46 HP @ 2550 RPM & 95 TQ @ 2550 RPM
Stage 1 100 Octane – 62 HP @ 5500 RPM & 78 TQ @ 2500 RPM
Stage 2 100 Octane – 64 HP @ 5550 RPM & 114 TQ @ 2650 RPM
Dyno Performance
Please note, single exit and Dual Exit exhaust reported similar gains
Component Overview
Stock System:
The Dual Exit RSC Exhaust system is offered in three versions.
Turboback Exhaust
This system replaces the entire exhaust system starting at the turbocharger.
Catback Exhaust
This system replaces the entire exhaust system starting behind the resonated downpipe.
Downpipe Exhaust
This system only replaces the catpipe and resonated downpipe.
The Dual Exit Exhaust System Features Modular tips and is avilable in Diamond Black or Polished Silver.
More photos on our web site!
Application Guide:
Vehicle: B8 A4
Engine: 2.0TFSI
Transmission: 6MT & Tiptronic
Drivetrain: Quattro
System: Turboback Exhaust System - Polished Silver Tips
Part Number: FE100040A
Price: $2,359.00
Vehicle: B8 A4
Engine: 2.0TFSI
Drivetrain: Quattro
System: Turboback Exhaust System - Diamond Black Tips
Part Number: FE100040B
Price: $2,490.00
Vehicle: B8 A4
Engine: 2.0TFSI
Drivetrain: Quattro
System: Catback Exhaust System - Polished Silver Tips
Part Number: CB100049A
Price: $1,529.00
Vehicle: B8 A4
Engine: 2.0TFSI
Drivetrain: Quattro
System: Catback Exhaust System - Diamond Black Tips
Price: $1,659.00
Vehicle: B8 A4
Engine: 2.0TFSI
Drivetrain: Quattro
System: Downpipe Exhaust System
Part Number: CD100025
Price: $874.00
Product Page
Find an APR Dealer
