Results 1 to 9 of 9
    Veteran Member Four Rings Synthetik's Avatar
    Aug 26 2009
    03 A4 3.0L V6 04 YZF600R
    Colorado
    Dome Lights, and Vanity Mirror Lights are not working...
    After my accident, I'm finally putting my car back together and I'm not sure how to go about tackling the issue of my dome lights not working. The body shop guys had to partially remove the front of the headliner to fix the damages, but I dont remember if the lights worked before I dropped them off. Is there a fuse for that anywhere? I'd rather not try to figure out how to take the headliner off if it's something simple, but its the front dome lights, mirror lights - when you slide open the mirror, and rear reading lights. None of them are working and I've checked the connections on the dome lights and they all plugged in. Strangely enough, the sunroof switch works fine.
    Help?
    15% Tint | USP Front End | Graphite Stockers | "Custom" Grills | DICE Ipod | Hardwired Garmin | Alpine Amp w/ 12" Sub | NEXT PROJECT: RS4 Sway Bar
    The B6 A4 DIY Master List
    Senior Member Two Rings TahoeA4's Avatar
    Jan 08 2009
    Kingsville, TX
    Try fuse 24. This thread might help you too:
    http://www.audizine.com/forum/showth...r-LED-Lighting
    Aug 26 2009
    Colorado
    Quote Originally Posted by TahoeA4 View Post
    Nope, 24 is good :/
    I'll check out that thread. Thanks.
    Veteran Member Three Rings PhunkFX's Avatar
    Oct 11 2005
    2019 TTRS, 1989 VW Cabriolet, 1986 VW GLI, 2015 Cayenne Diesel
    Post Falls, ID
    I am having a similar problem. My windows and trunk auto unlock is out too. Subscribed.
    -Ricky
    2019 Audi TTRS Prestige | Stage 3
    2015 Porsche Cayenne Diesel | Stage 2
    2015 VW Golf SEL TDI 6MT | Stage 2
    1986 VW Jetta GLI Wolfsburg Pirelli w/11k Orginal Miles
    1989 VW Cabriolet | 1.8T K04 w/nitrous
    Aug 26 2009
    Colorado
    So update to my problem that is frustrating the heck out of me. I checked all the plugs going into the vanity mirror lights, main front lights, back lights, and trunk light and they're all firmy plugged in. The thing that is absurd is when I turn on my parking lights, the switches light up red but still don't work. Ah!
    To Phunk, there is a fuse for the rear trunk latch, pop open your fuse box and take a look.
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    Quote Originally Posted by Synthetik View Post
    my trunk goes out every now and then...its because the cable that is in the front bumper (drivers side) comes unplugged and causes the horn and trunk pop to stop working. You might try that, but it sounds like you have something different
    Jan 08 2009
    Kingsville, TX
    Have you tried swapping out light bulbs to see if it is as simple as the bulbs burning out? Unlikely, I know, but it is still possible. The trunk uses the same bulbs as the footwell and puddle lights. It is very strange that the switches light up, because that means that the comfort control module is good, and not likely the culprit.
    Aug 26 2009
    Colorado
    Nah, I looked at all the bulbs and they look fine, I cant imagine all 8 of them going bad in a car accident.
    Aug 26 2009
    Colorado
    Could this be a problem with a relay. I know 98% that relay 219, the one controlling the cooling fans is toast because my fans will randomly run full blast after it rains. So I think it's possible that a relay in the same spot could also be toast.
