(x1 pair) License Place Light Bulb (P/N 6418); sold in pairs
LED Bulbs, Pic 1
LED Bulbs, Pic 2
(x2, optional) OEM Audi Lense & Screw Assembly (P/N 8E0-942-021-B); screw not sold separately, the head was already starting to strip out on one of mine
Tools:
1/4" Hex Drive Mini Ratchet (Craftsman, P/N TBD)
#1 Phillips Screwdriver Bit
Procedure:
1.) Open trunk lid.
2.) Remove Phillips head screw; it's recommended to use the ratchet and #1 driver bit so that you can push into the fastener head while using the extra torque arm of the ratchet to break the fastener loose. If you choose to use a regular screwdriver, you have a greater chance of stripping the Phillips head.
3.) Remove lense and bulb assembly from trunk lid. The bulb is connected to the lense. Audi chose to use a surface contact type of connection that houses the bulb on the lense with a pair of prongs that contacts surface mounted pads in the trunk lid.
4.) Remove old bulb.
5.) Install new bulb. I chose to use LED bulbs.
6.) Re-install lense-bulb assembly, side opposite of screw goes in first.
7.) Tighten fastener.
8.) Switch lights to ON to verify light output.
