Results 1 to 9 of 9
    Established Member Two Rings Yeaayouu's Avatar
    May 10 2010
    Honolulu Hawaii
    Does anyone know if the OEM S4 18 inch wheels would fit on a 2011 Golf GTI????
    please advise....
    Jul 01 2010
    MA
    The center bore on the S4 is 66.6 mm while the bore for the GTI is 57mm i believe. Otherwise the specs are similar.
    May 10 2010
    Honolulu Hawaii
    if the bore is bigger , then its should fit over the smaller one right?
    Sep 30 2009
    b
    Quote Originally Posted by Yeaayouu View Post
    lol that's not how it works. You have to have the wheels bored out( machined to spec) for them to fit. The offset may be terrible also, another thing to consider. I don't know what good specs are for the GTi, but I imagine the offset of pretty high on an 8 inch rim so it will not poke.
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    the s4 18s are 18x8 et47, this is perfect for an a3 or a gti in stance. you would run 225x40-18 tires.
    the bore in the rim is larger, so they will not be hub centric, but a shop may have an ideal hub ring to insert into the rim making it 55.7 instead of 66.56
    I have run wheels without hub rings and it was fine, but you should look for the rings.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    May 10 2010
    Honolulu Hawaii
    Okan , I think you are misinterpreting my question. I am trying to put a rim with a bigger bore size onto a smaller bore size fitment. From my research and from Lou's explanation it seems to make sense. You would only have to bore it out if its the other way around. ( using a 55.7 bore rim on a 66.56 mm car)
    May 10 2010
    Honolulu Hawaii
    Quote Originally Posted by L0U View Post
    Thanks Lou. I am thinking of just slapping my stock S4 wheels onto my wife's GTI with the 245/40/18 tires. Thank you for your insight. I think they sell inserts at ECUtuning.com for an hubcentric fit.
    Sep 03 2009
    good and bad news...the 245s won't fit with that et. 235s might , 225s will. 18x7.5 et 54 is the regular rim, 18x8 et47 is pushing the wheel out a lot. you can't put an extra 20mm of rubber under it with the allready aggresive rim et/width. test fit one just to see for yourself, it will be very easy to tell then.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Veteran Member Four Rings Seinsmeld13's Avatar
    Mar 23 2009
    2020 Porsche Spyder
    Niagara Region, Canada
    I agree with Lou, test fit the rims. I don't think this will work. I have a set of new 245-40-18 tires and I also have a GTI with 18" rims. I wouldn't waste my money test fitting them on my GTI as they are just too big. The speedo would be way off, by approx. 2.5% over the stock tires. The circumference of 245's would be 2000 mm and the 225's 2050 mm
    http://www.rimsntires.com/img/blank.gif
