Results 1 to 15 of 15
    Senior Member Two Rings PeteStiv7's Avatar
    Apr 09 2010
    Pompton Plains, NJ
    B7 Subwoofer install. Need Help/Opinions
    (yes ive searched and couldnt find enough info)
    Im thinking about install some subs in my A4. I was just wondering how hard of a job it is, the types of wires I need, what to tap into, etc. Im not great with electrical mods so Im wondering if I would be able to do this mod on my own.
    I think Im getting 2 10" Pioneer TS-W258D2|D4's and a Pioneer GM-D9500F amp (my uncle works at Pioneer and can get me their products cheaper). How do you think this setup will sound with my stock Symphony II+?
    Also please post what setups you guys are running, how it sounds, and some pics of your boxes. Thanks
    B7 Brilliant Black A4
    K&N drop in filter // VMR test pipe // Forge diverter valve // 20% tint all around with Charcoal taillights // Yellow Lamin-X fog lights
    Sep 13 2008
    Western Chicago Burbs
    It is not too hard if you use a line level converter and tap off the wires going to the bose sub. then you of course need a power wire going back from the battery, as well as a turn on wire.
    Make sure you dissable the Bose Auto-Pilot system as it will confuse the extra bass for road noise and it will unexpectedly crank the volume on you.
    Veteran Member Four Rings GarrettReid's Avatar
    Oct 26 2010
    Orlando
    I like your car. I'm also considering this but I'm going to redo the whole system (my front speaker is blown).
    (sorry for no useful info)
    2014 Audi SQ5 Black w/Lava Gray and Magma Red
    SOLD: 2007 Land Rover Range Rover Sport Supercharged Black w/Black
    IG: GarrettReid
    Apr 09 2010
    Pompton Plains, NJ
    Quote Originally Posted by GarrettReid View Post
    Thanks hahah and its ok
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by B6JoeS4 View Post
    b6joes4 is correct with everything he says, if you spend a extra doll hairs on a better amp there are some that come with built in line converters and you dont have to mess around with an external one, you just flip a switch from low current input to hi current input and the amp does the rest
    sub install is wicked easy and if you go to a4mods.com it has a great DIY that will work for what you are talking about
    Sep 13 2008
    Quote Originally Posted by mr shickadance View Post
    Great fucking movie. Chuck & Larry FTW
    DUH! an Audi
    los angeles, CA
    being frank, if you have little experience with electrical/sound system installation I would advise you to have a professional do it. It is not very difficult to do it, if you feel comfortable to do it, try it out.
    you can search online how to install it.
    Jul 08 2010
    tucson
    danbury
    glad someone gets the reference...good for a laugh like 30% of the time
    Dec 03 2008
    2005.5 Brilliant Red A4 2.0T
    Ann Arbor, MI
    You'd have to remove the trim pieces in the trunk to access the subwoofer amplifier on the right side of the trunk. From their you simply splice in your RCA cables to the rear right from radio and rear left from radio; then splice into the amp on/off wire.
    By higher quality RCA cables since, they have more wire strands and the strands themselves are thicker. They are much easier to work with then cheap cables.
    Running the power cable was a pita btw. You have to poke the power cable through the firewall liner, remove your glove box, at least loosen all the lower trim that runs along the door, and remove your bottom back seat cushion.
    http://www.a4mods.com/index.php?page...es/stereo.html
    I did mine differently and ran the power under the door trim and fished it under the b pillar trim.
    http://www.audizine.com/forum/showth...ub-Install-DIY
    http://forums.audiworld.com/showthread.php?p=20516095
    Apr 09 2010
    Pompton Plains, NJ
    Anyone got pics of their finished setups?
    Senior Member Two Rings bitskyline's Avatar
    Jul 29 2010
    Edmonton Alberta Canada
    06 B7 A4, APR K04 kit, Exhaust, Intake, HPFP, JHM SSK, H&R touring cup kit, DXD clutch/flywheel, Forge DV, 034 FMIC, Focal/JL audio.
    Oct 26 2010
    Orlando
    Quote Originally Posted by bitskyline View Post
    I'm curious what size speakers did you use for above the dashboard and behind the rear seat?
    IG: GarrettReid
    Jul 29 2010
    i disconnected the center speaker in the dash, and the sub in the rear deck is not hooked up. just the 6 1/2"s and the 12 :) im still loving it.
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Quote Originally Posted by PeteStiv7 View Post
    Here's mine: http://www.audizine.com/forum/showth...-Audio-install
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Oct 26 2010
    Orlando
    Do you happen to know what dimensions they are? I'm thinking about upgrading my system since one of my speakers is blown anyway. I'd sort of like to have all the factory locations filled plus a sub.
    IG: GarrettReid
