Results 1 to 23 of 23
    Active Member Two Rings bpodnar's Avatar
    Feb 06 2009
    u Slatni
    A4 B6 - How to renew interior parts (middle console coating)?
    Recently I bought A4 year 2003, and first thing that I've noticed is worn middle console edges arround handbrake and lighter. Passenger side is worn a lot. Is there a way to renew that part to look like new? Interior color is gray and worn place is very ugly because base plastic is black.
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    yeah, buy new ones. lol. if you had a black interior it may have been possible to get it to look decent, but you will never get a good enough color match on the other colors. not to mention that there is no good touch up coating for the parts that i know of. If you want the interior to look good, buy a new console, new climate control unit, headlight switch, and window switches as needed. sorry for the bad news
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
    Senior Member Two Rings Dirty(30)v's Avatar
    Nov 10 2009
    03 A4 3.0L
    North NJ
    good question
    Red ultra suede Trim
    clear corner/stealth bulb/ yellow fogs
    DONZ 19''/vmaxx coils/15mm spacer*/ rs4 swaybar/ custom intake
    votex rear*/ usp front*/ DTH side skirts/ trunk lip/ badgeless grill
    I have a bunch of stereo stuff for sale wanna get ride of it asap
    http://forums.vwvortex.com/showthrea...vd-cd-mp3cd%29
    Senior Member Three Rings Hotel Guy's Avatar
    Oct 07 2007
    Chicago
    yea its much easier to replace some of the smaller parts such as the window switches and surround, the headlight switch, and the A/C unit, but the center console is obviously a larger project. It can definitely be done though. As of now, there is no real touch-up paint to match the rubbery platinum grey coating.
    Veteran Member Three Rings mattg1.8's Avatar
    Sep 16 2009
    San Diego
    i used leather cleaner and blue scoth brite pad very lightly on my center console, door handles, and middle arm rest and they came out like new.
    Deactivated Three Rings
    Apr 11 2008
    So you're telling me that you can replace the AC part of the center console? My raise temp button (+) isn't working anymore on the drivers side, you need to pretty much pound on the thing to get it to raise the temp. Sucks in the wintertime!!
    reference: http://img365.imageshack.us/f/15022009762th6.jpg/
    I can't even use the passenger one because of dual climate control >=|
    Veteran Member Four Rings Styleprojekt's Avatar
    Nov 17 2006
    Salt Lake City
    Quote Originally Posted by swrt83 View Post
    Yes you can easily replace it with a new unit. Pull out the radio and the climate control unit should come out easily. Use the part number on it to find a direct replacement
    Jul 14 2009
    Pasadena
    theres currently a climate control setup in the classifieds.... no peeling
    IG: @matthewee
    Dec 07 2009
    1980 kz750ltd
    adjust with the pasanger's side then hit the "auto" button above that side. that will do it.
    And you can remove the coating and the paint will be the same color (or very close) underneath, yes but you will lose the rubbery feeling.
    Diode Mod!!
    -Andrew
    Veteran Member Four Rings Gaberossi's Avatar
    May 12 2009
    Volcano Black Audi A4 pte5857, 2022 Outback, 97 civic ex(blew up), 95 Toyota pickup(sold)
    Parkland,FL
    use some rubbing alcohol if you have a STICKY climate controls works like a charm
    99.5 A4 1.8TM AEB Fronttrak - Volcano Black Mica - AutoFlex'd Signal Green - E85 - Clutchmasters 725 series twindisk - ID1000cc - Precision 5858 cea Ball Bearing Turbo - JE Pistons/IE Rods - EurodyneMe - Coilovers - AWE DTS - 034 Mounts - Team Dynamic Wheels -Nitto INVO -Working @ DipYourCar.com - Usp Motorsports -
    Click>>>>>My Build Heel-Toe'n the b5 everyday =P
    Dec 07 2009
    1980 kz750ltd
    Quote Originally Posted by Gaberossi View Post
    be careful though. even water can make the rubber/paint peel off, let alone alcohol.
    Diode Mod!!
    -Andrew
    May 12 2009
    Parkland,FL
    dont know about B6 interiors but this seemed to work pretty well and made my buttons feel like new again, If you want add a tiny amount of water to dilute the rubbing alcohol, I would suggest you purchase a rubbing alcohol with no more than 70% isopropyl alcohol. try it on a small area wait an hour and see what it looks like.
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    set them to the same temperature via the passenger side, hold down the AUTO button for 2 seconds, then adjust via the passenger side. they should be synced. you can also turn AUTO off after this.
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
    Feb 06 2009
    u Slatni
    Quote Originally Posted by alpinestar180 View Post
    Yeah, that crossed my mind but searching in ETKA for a new console part didnt give any results. Does anyone have part number or ETKA aplication to look for it? I cant find it my self. As you know ETKA have part numbers and images of the last screw from many car makes and models but didnt find anything about central console.
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by vintagespin View Post
    Audi is too smart for their own good on this. I use auto all the time but once a passenger adjusts the temp on their side the sync is lost. Pretty sure others are the same too.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Feb 06 2009
    u Slatni
    Quote Originally Posted by A4SoftWalker View Post
    That's because you didn't synced climate control on passenger side. Do the sync like other told you with push and hold auto button on passenger side and then the both sides are set over passenger control buttons.
    Established Member Two Rings Codiac's Avatar
    Apr 26 2011
    B7 S4
    would you guys recommend painting entire console (if black) with plasti-dip, I personally think with good prep and cleaning it should work =] opinions welcomed.
    Veteran Member Three Rings Audiguy1234's Avatar
    Aug 28 2011
    North Chicago
    I did plasti dip on my peeling console. It looked better and is a close match kind of. I then switched to a b7 console for the cup holders. B7 console ftw.
    Veteran Member Three Rings G.AUDI's Avatar
    Dec 07 2008
    MK6 GTI
    SGV, CA
    Quote Originally Posted by Codiac View Post
    You can go with plasti dip, however the color won't match and over time, the plasti dip will end up be coming off...
    The what I and the guy above me did and go with the B7 console... No soft rubber coating that will peel over time and as the B7 gets older, they are becoming more common and cheaper to get ..
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    Columbus, Ohio
    I would just get a B7 console. I did pick up some paint said to match perfectly before. It is rustolem(sp) Matt camo paint that Old Guy found. Might look that up to be sure. I'll find my can later today.
    Apr 26 2011
    B7 S4
    Quote Originally Posted by Audiguy1234 View Post
    well my console is only wearing where i rest my right knee. it isn't that bad but I kinda wanna try plasti dip
    Feb 06 2009
    u Slatni
    I solved the problem with my console. Sold b6 and bought b8 s-line. No rubber coating anywhere in the car. ;)
    Sent from my HTC One X using Tapatalk 2
    Veteran Member Four Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    WELL that's one way to fix your problem...congrats on the new car!
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
