Results 1 to 14 of 14
    Active Member One Ring G'sS4's Avatar
    Sep 14 2007
    Sacxramento
    Different size wheels on a quattro; is it bad?
    Well I have 19x8.5 wheels on the front & 19x9 on the back of my car. I wanted to go get new tires 235/35/19 for the 19x8.5 on the front & 235/55/19 for the back on the back 19x9 wheels????
    I WAS TOLD BY THE TIRE SHOP THAT THE SIZE DIFFERENCE WOULD DO DAMAGE....
    Please Help Audi friends......
    Aug 31 2010
    09 R1 Track Weapon
    Greenacres, WA
    You need to have the same circumference, same as 99.9% of AWD's on the road. So yes, your tire shop is actually saving your differential from destroying itself.
    Fronts would be 80"
    Rears would be 91.7"
    05 B6 S4 Avant 6MT
    06 Touareg V8
    09 Yam R1, full race
    71 Honda Z50 88cc (pit bike of death)
    64 Ducati Mountaineer 90 (in restore mode)
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by Jengel451 View Post
    Fronts would be 80"
    Perhaps the rear tire size typed is a typo? If not then the shop is correct, you would likely incur damage to your AWD system if you were to go with that setup.
    Typically, if the outer diameter of the fronts and rears is close enough, it is considered "safe" to run a staggered setup.
    Brandon @ VMR Wheels
    Sep 14 2007
    Sacxramento
    So then it is ok to run an 19x8.5 on front and a 19x9 on the back with the same size tires all the way around
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    You want the diameter of the wheel/tire combo to be as close as possible, with in a few %, can't remember the the exact #. I'm running 19x8.5 (235/35) and 19x9.5 (245/35) IIRC the tire size to achieve this. If you use the same tire size on the back as the rear it will be stretched do to the wider width and will be smaller than the front which you don't want.
    Veteran Member Three Rings J0HN_R1's Avatar
    Jul 05 2010
    completes me...
    Calgary, Alberta
    Quote Originally Posted by G'sS4 View Post
    So then it is ok to run an 19x8.5 on front and a 19x9 on the back, with the same size tires all the way around
    Yes... Absolutely...
    The problems your shop told you about would come from the diameter (not width) of the new tires not being the same.
    The front & rears need to be within 3% (diameter) of each other, regardless of width.
    But width also needs to be scrutinized somewhat, as too wide of a tire will rub either the fender (during suspension travel) or suspension components (during any rotation).
    From all accounts I've read here, a staggered wheel combo for B6/B7 can take up to 245fr/255rr depending on rim width & ET.
    But a 235/35fr & 245/35rr set-up might be better, which is within 1.1% diameter of each other...
    Sep 14 2007
    Sacxramento
    I guess I should just try to get new rims all the way around to save the head ache.
    Veteran Member Four Rings JEmm's Avatar
    Apr 27 2009
    No reason. Just get 235/35's all around. You'll be fine. The slight stretch on the rear won't change the circumference enough to cause damage, you will be absolutely fine.
    -Jeff
    Sep 14 2007
    Sacxramento
    You think???? I dont want to mess anything up. NO MORE WARRANTY!!!
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    8.5-9 is very minimal in the difference, you'll be fine, just go with the recommended tire size above. Lots of people run staggered set-ups with out issue, with even wider rears, with lots of camber and what not. Good luck and post pics.
    Jul 05 2010
    completes me...
    Calgary, Alberta
    I think you'd be happier with the 235/35 & 245/35 combo, and would be totally safe doing so (1.1% difference in diameter)...
    235's on a 9" wide rim would have some stretch... 245's would fill the rear out more, and compliment the wider wheel...
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    but ask yourself this....why would you put a smaller tire on the front of a car that carries 60% of the total vehicle weight?
    Cheers,
    Jim
    Established Member Two Rings TN82's Avatar
    Jun 12 2010
    so what would be a good tire size for the front if you have 265s on the back?
    Established Member Two Rings wolfs21t's Avatar
    May 26 2010
    Pensacola/FL
    I used to run 265s on my setup with no problem, 19x8.5\235x35 Front and 19x9.5\265x30 R. I did notice the rear height was lower than the fronts. I recently upgraded the rear to 275x30 and they are almost perfect rolling diameters now.
    Here is a pic of the before setup with sport suspension.
