Results 1 to 9 of 9
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    2004 Yamaha R1 $3000
    long time no see guys,
    i've got a 2004 yamaha r1 w/ salvaged title up for grabs. it needs slight tlc for you gear heads easy fixes. i prefer a 600cc supersport over the 1000cc superbikes
    first $3000 picks her up
    pictures can be found on my ad, or i can send you bigger pictures.
    details:
    2004 yamaha r1
    miles: 25,000
    registration: was to expire dec 2010, just renewed to dec 2011
    title is salvaged, title in hand
    damage is from the previous owner
    the fairings:
    the original owner had a low speed low slide, the sliders did their job and saved the bike. there are a couple light scrapes and scratches and a piece of fairing or two that are cracked.
    - front fairing, cracked and broken off *see picture
    - missing lower gas tank cover
    - tiny rock dent in tank, hardly visible
    - new tires are needed, currently equipped *see picture
    rear: 200/50/17 dunlops front: 120/70/17 pirelli diablo corse
    - it needs a new ignition coil for cylinder 3. the knocking noise is coming from the clutch, something is slightly rubbing against the clutch cover. once you pull in the lever to engage the clutch the noise goes away, i've already tried adjusting the clutch cable.
    - there is a oil leak from where the clutch cover and crankcase meet, the gpsports guys said where the cover and crank meets is not flush. needs a new cover w/ gasket. thats why its leaking oil.
    - could probably use a new ape cct, and a valve adjustment. oh and the right front turn signal doesn't work, bulb probably went out. all other electrical components are in working order. also have the 04-06 service manual in pdf form if you guys need it.
    recommend you find a motorcycle trailer or pick up, because of the faulty ignition coil it'll start up fine and idle but may cut out when you attempt to ride it home.
    aftermarket parts
    - rk racing chain
    - vortex fuel cap
    - rear stand spools
    - BMC airfilter
    - Yuasa batter
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Veteran Member Four Rings AsianA408's Avatar
    '10 A5 S-line, 07 Sline A4, 99 A4q, 2002 S4,2000 S4, 2008 335i
    San jose, CA AXION BETA
    ill take it.
    1999 audi a4q(Sold)
    2007 B7 S-line A4(current)
    2002 B5 S4 Santorin / 06 Ninja ZX-10R
    _________________________
    |.....Overnight.......................|.|\
    |........PARTS FROM........-....|.|||";,__,
    |_...__...JAPAN_______=====|.|_|..|...|
    "'(@)'(@)""'''''''"'''''''l''/(@)(@)*****(@)"
    TEAM|AXION
    "Are you a good sticker putter?" - Dino/S-POWER
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    serious? we can talk details through pm's or feel free to txt my phone.
    let me know john.
    2006 600RR
    my photos
    lost yer # stacey.
    1999 audi a4q(Sold)
    TEAM|AXION
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    you got pm heading your way.
    2006 600RR
    my photos
    Veteran Member Four Rings 97B518TQM's Avatar
    May 31 2009
    CA. USA
    This makes me wish I was more experienced with motorcycles. I don't think a R1 would be a good first bike for me :). Looks great though, great deal.
    SOLD: B5 S4 Tial 770s with meth @652hp
    Current: C7 S6 - SRM +4mm RS turbos, SRM inlets, SRM fuel lines, DS1 stage 4 custom tune, HPFPs, X-pipe, H&R lowered
    Veteran Member Three Rings wesS4's Avatar
    Nov 29 2007
    1966 Mustang
    San Jose, CA
    I wish, that price is awesome GLWS
    Stage 2 B5 A4 Avant | AWE | GIAC | H&R | OEM+ | BBS | Raven MS | 034 | DDM
    The Auto Shop
    TEAM|AXION is dead. RIP LOL
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    haha wait until you see what i'm replacing the r1 with.
    2006 600RR
    my photos
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    PRICE DROP, need to sell this to pick up new bike.
    $2800
    i fixed the ignition problem, it runs and is ridable. still needs some tlc work and leaks oil, someone pick her up quick!
    2006 600RR
    my photos
